  • cob.charles
  • cob.charles
17 Jun 2026 10:32
Replied by cob.charles on topic 7i92 cnc motion controller from aliexpress?
Category: Driver Boards
I am having a problem configuring the 7I92 card that I bought on AliExpress.
From what I understand, it's a cloned card. My problem occurs when I configure the P1 and 7i76-Analog Output tabs, the error appears as shown in the last photo.
However, when I only configure the P2 tab, nothing happens; the card works and the EasyServo devices operate.
Now I need to configure other outputs to make the motor or spindle work, but this error occurs.
Has anyone else experienced a similar problem?
  • cob.charles
  • cob.charles
17 Jun 2026 09:31
Configure 7I92 Zhulong card on AliExpress. was created by cob.charles
Hello,
I'm leaving the link to where I bought it.
aliexpress.com/item/1005010164851154.html?spm=a2g0o.order_list.order_list_main.50.12fecaa4j6tb61&gatewayAdapt=glo2bra
  • Masiwood123
  • Masiwood123's Avatar
17 Jun 2026 07:19
Replied by Masiwood123 on topic Axis 2 - touchscreen version of old friend
Category: AXIS
I fully understand, I even tried to hook up a 32 inch external monitor without touch function, however it gives the image from rpi4 via mini hdmi, and regardless of the resolution of the large screen the numbers on the preview tab are still quite blurry, yes it would mean that we try. thanks
  • zack
  • zack's Avatar
17 Jun 2026 07:01
Category: AXIS
We can enlarge those fonts but I think we are compressing too much info on such a small display
I have done a Aus where the touch screen was for control and a separate monitor like an old 15” was used for preview only
Ie dual screen one touch one display
So can do if u interested
  • timo
  • timo
17 Jun 2026 05:23 - 17 Jun 2026 05:43
Replied by timo on topic Maschine faehrt Endschlter nicht an
Was ist denn kaputt?
Um da irgendwie weiter zu kommen im Forum wären mehr Infos über die "verdächtige" Karte hilfreich.
Vielleicht hat ja jemand einen Alternativvorschlag, wenn die Hardware bekannt ist. Oder eine Möglichkeit weitere Tips zur Fehlersuche zu geben.
Die Endschalter kann man irgendwo in hal und ini außer Kraft setzen. Ich habe z.b. Die a-Achse ohne Referenzschalter.
So ein Ding? Da kann man mit Sicherheit eine Alternative finden, die vertretbar ist.
Das wird nicht billig, aber auch nicht unerschwinglich teuer. Ich schätze ein China Break out board (20€) und drei getrennte preiswerte Motor-endstufen (10€ - 30€) pro Stück.
Viel Erfolg!
  • timo
  • timo
17 Jun 2026 05:04
Replied by timo on topic Linux system is weird
I will read through that once again. Thank you.
  • djdelorie
  • djdelorie
17 Jun 2026 04:54
one job, multiple files, one directory was created by djdelorie
Is there any way to split a job into multiple files, not including the "designate one directory as a working job directory for everything" ?  I want to keep each job's files in separate directories, but linuxcnc doesn't seem to look in the same directory as the calling file, for subroutine files.
I really just need to do a series of G92 (or G10L2 etc), run file A, G92, run file B, etc.
  • DarrenAlberta
  • DarrenAlberta
17 Jun 2026 04:54
Replied by DarrenAlberta on topic Potential All-in-One Single Board Computers
Is anyone running AllwinCNC on a working machine?
  • BraveBoy
  • BraveBoy
16 Jun 2026 22:23 - 17 Jun 2026 00:03
Migrating My CNC Machine Controller to a Dedicated Linux PC and Hardware Selecti
I have been running my small hobby CNC router on a older Windows based controller setup for about three years and the decision to finally move to LinuxCNC has been sitting on my to do list for longer than I care to admit. Last month I committed to making the switch and what I assumed would be a straightforward hardware selection process has turned into a surprisingly deep rabbit hole.The core challenge is that LinuxCNC is uniquely sensitive to hardware in ways that most Linux installations simply are not. Latency performance from the hardware directly affects how cleanly the software can generate step pulses and a machine that runs Linux perfectly for general use can produce completely unacceptable latency numbers for CNC control work. I learned this the hard way after pulling an old Core i5 desktop from storage that I assumed would be more than adequate and running the latency test only to get numbers that would cause real issues at the feed rates I want to run.Motherboard and CPU combination selection seems to matter enormously with certain chipsets producing dramatically better latency results than others and the documentation around which specific hardware combinations are known good versus problematic is scattered across forum threads spanning years with no single consolidated reference that feels current.I have also been going back and forth on whether a parallel port based setup or a Mesa FPGA card approach makes more sense for my specific machine. The Mesa route offloads the timing critical work to dedicated hardware which should make the host PC hardware selection less critical but adds cost and complexity I was hoping to avoid initially.Been sourcing and comparing compatible hardware options through www.amazon.com/ and found some information about the performace of different components and found these components on reasonable price at Link removed alongside a few other places and the pricing on suitable older Intel platforms that the LinuxCNC community tends to recommend has been reasonable enough to make dedicated controller hardware financially sensible rather than repurposing whatever is available.Has anyone recently gone through hardware selection for a LinuxCNC build and found specific motherboard and CPU combinations that consistently pass the latency test without extensive tuning?
  • karlhe
  • karlhe
16 Jun 2026 16:22 - 17 Jun 2026 05:59
Replied by karlhe on topic linuxcnc ohne endschlter
Hallo Aciera,
ich habe nach Deinen Anweisungen in meiner Probe Maschine
[traj] NO_Force_Homing = 1 eingetragen. funktioniert auch .
Man muss nur den Verfahrraum beachten.
Danke
  • awallin
  • awallin
16 Jun 2026 16:16
Ethercat installation from repositories - how to step by step
Category: EtherCAT
And follow this process which I have tested with 2.98 in the last week or so.
github.com/linuxcnc-ethercat/apt
Thanks, this repo works for me on 2.9.8 (the default is in the file /etc/apt/sources.list.d/science_EtherLab.list and gives errors)
  • karlhe
  • karlhe
16 Jun 2026 16:12
eine neue Maschine mit stepconfig erstellt eine Simulationsmaschine.
Hallo Toomy,
hat funktioniert, danke.
Wenn dort simulationsmaschine stehen würde, wäre das sicherlich
besser zu verstehen..
Karlhe
  • endian
  • endian's Avatar
16 Jun 2026 15:56
Replied by endian on topic EL7221-9014/15 LCEC Driver Support
Category: EtherCAT
/** @file el7211.c
 * @brief Driver for the Beckhoff EL7211/EL7221/EL7201-9014 servo motor terminals.
 * Implements CiA-402 velocity-mode control for Beckhoff BLDC servo terminals.
 * The driver reads the 16-bit status word (0x6010:01), 32-bit actual velocity
 * (0x6010:07), 16-bit actual torque (0x6010:08), and 32-bit encoder position
 * (0x6000:11), then writes a 16-bit CiA-402 control word (0x7010:01) and
 * 32-bit velocity command (0x7010:06) each cycle.
 * The EL7201-9014 variant additionally exposes digital inputs (info1) and
 * an extended error word (info2) via two extra TxPDOs.
 * @copyright Copyright (C) 2018-2026 Sascha Ittner <sascha.ittner@modusoft.de>
1- Is the EL7221-9014 module actually compatible with the lcec_el7211.c driver? - y
2- Would I have to use the driver, configuring the ethercat_conf.xml file for the EL7201-9014 module, even though the actual module is the EL7221-9014? - tell me more about it
3- Does anyone have experience with an EL7221-9014 module who could offer some help? - n but I can take a look
I saw that in a previous post on this forum you mentioned wanting to try an EL7221 module. I'd like to know:
-- Which driver did you use, lcec_el7211.c? - future custom own driver with probing, no because it has no homming internal subroutine and I plan to code my own..
-- Do you have the same hardware, EL7221-9014? - yes I have some of them and I want to use it in the near future .. just after I will finish driver to @zmrdko
let me know
Displaying 3061 - 3075 out of 12539 results.
Time to create page: 0.624 seconds
