11 Jun 2026 18:01
Replied by tommylight on topic mirror backplot
mirror backplot
Category: AXIS
MIN_LIMIT = -380
MAX_LIMIT = 0.01
Wrong for Y axis, should be reversed.
Might also need to change direction and/or homing directions, by adding - in front of the scale and HOME_ values.
  • Fastfred
  • Fastfred
11 Jun 2026 17:01
Replied by Fastfred on topic How to enter tool lenght
Never mind I was able to figure it out.
  • billykid
  • billykid's Avatar
11 Jun 2026 16:29
Replied by billykid on topic mirror backplot
mirror backplot
Category: AXIS
Here they are, I changed TCL with a modified one but it's not its fault, it does the same with the original one.
11 Jun 2026 12:45
mirror backplot
Category: AXIS
hal and ini ?
  • billykid
  • billykid's Avatar
11 Jun 2026 11:57
mirror backplot was created by billykid
mirror backplot
Category: AXIS
I've had this CNC with a closed-loop DC servo for a long time, and it works well for both movement and backplot with the home dot at x0 y0 as seen in the photo. The only problem is that it only works well with the y-axis inverted; the y-axis moves away in a negative direction. I decided to set the axis to positive as the x-axis, but the home dot moves to the left, and I haven't found a way to set them in step... basically, the plot moves outside the work area. Could it be that I changed the order of the pwmgens to match x and spindle on a 7i40hv and y and z on another to use two different voltages for the motors?
  • GRY_ES
  • GRY_ES
11 Jun 2026 10:11
Looking for 7I76EU firmware supporting standard 7I85 and 7I74
Category: Driver Boards
Hello PCW,
Thank you for your advice.
You were absolutely right — I did not need the 7I74.
I connected the 7I85 to the 7I76EU P1 port and then connected two 7I84U boards directly to the Smart Serial ports on the 7I85.
Everything is now working correctly:
* 7I85 is detected and provides the expected MuxedQCount resources.
* Both 7I84U boards are detected through Smart Serial.
* Inputs and outputs on both 7I84U boards have been tested successfully.
* LinuxCNC sees both boards after enabling the corresponding Smart Serial channels.
The final configuration is:
* Mesa 7I76EU
* Mesa 7I85
* Mesa 7I84U #1
* Mesa 7I84U #2
using the firmware:
7i76eu_7i76x1_7i85x1d.bin
Thank you for pointing me in the right direction and helping me simplify the system.
Best regards,
Roman
  • WKS-3D
  • WKS-3D's Avatar
11 Jun 2026 09:50
Nach Umzug der LinuxCNC-Konfiguration auf neuen Rechner sporadische Positionsfeh
Category: Deutsch
Ich persönlich würde ganz von vorne anfangen und direkt alles erledigen was in den Antworten bereits geschrieben steht.
Jetzt versuchen alles aufzuräumen und die Gefahr etwas "entscheidendes" zu vergessen, ist einfach zu groß m.M.n.
Wahrscheinlich gehts sogar schneller.
Gruß
Olli
  • PCW
  • PCW's Avatar
11 Jun 2026 05:13
I can make 7I76EU  + 7I85 + 7I74 firmware but not sure why you would need the 7I74
as there are 6 available Sserial ports with just the 7I76EU (1) and 7I85 (5).
7i76eu_7i76x1_7i85x1d.bin is the firmware for a 7I76EU and a 7I85.
  • GRY_ES
  • GRY_ES
11 Jun 2026 04:48
Hello,
I am using a Mesa 7I76EU board and would like to know if a firmware configuration exists that supports simultaneous operation with a standard 7I85 board and a 7I74 board.
My planned hardware configuration is:
* Mesa 7I76EU
* Mesa 7I85 (standard 7I85, not 7I85S)
* Mesa 7I74
* Two Mesa 7I84U boards connected through the 7I74
I have successfully tested the following firmware:
The firmware was loaded successfully, and LinuxCNC correctly detected all six MuxedQCount channels provided by the 7I85.
After loading this firmware, LinuxCNC reports:
* 6 MuxedQCount channels
* 1 MuxedQCountSel channel
The 7I85 board will be used to connect four RS-422 linear scales (X, Y, Z, and W).
The 7I74 board will be used as a Smart Serial Hub for two 7I84U I/O expansion boards.
While reviewing the Mesa firmware archive for the 7I76EU, I could not find a ready-made firmware configuration for:
However, I found the following VHDL source file:
PIN_7I76x1_7i85sx1_7i74x1D_51.vhd
which suggests that a configuration for a 7I85S + 7I74 combination exists.
I would appreciate advice on the following:
* Is there an existing firmware configuration for the standard 7I85 and 7I74 combination?
* If not, is it possible to obtain such a configuration from Mesa or build it from the available source files?
* Are there any FPGA resource limitations on the 7I76EU that would prevent simultaneous use of both the 7I85 and the 7I74?
Any information or recommendations would be greatly appreciated.
Thank you.
10 Jun 2026 17:36
Where do I find ARC starting signal - Stahlwerk CUT 60 P Digital
Category: Plasma & Laser
No ARCOK signal on those, use the derived signal (mode 0 or 1, i forgot) so no need for it, and it works perfectly fine with those plasma sources.
But first, check if the torch starts in mid air.
  • chtis
  • chtis
10 Jun 2026 17:22
Hi everyone,
I'm currently building my plasma CNC setup with LinuxCNC and need some help with wiring. Maybe someone here has the same plasma cutter.
Hardware:
- Plasma cutter: Stahlwerk CUT 60 P Digital
- Motion control: Mesa 7i96S
- Voltage sensing: THCAD-2
My main question:
I'm trying to understand where to find the ARC starting signal on my plasma cutter. The signal that tells LinuxCNC: "The arc is burning, movement can begin."
In many tutorials or forums, I read about a dedicated ARC OK output on the plasma.
(See Attachment: the plasma cutter signal control has 4 pins 1, 2, 3 and 4)
On the Stahlwerk CUT 60 P Digital, I only find:
1. THC interface
2. The control socket (where the hand torch trigger normally plugs in) (pin 3 and 4)
3. I can´t find pins 1 and 2 or find anything to how to get the arc signal otherwise
My specific questions:
1. Does the 2-pin THC output not only provide the voltage for the THCAD-2 but also a signal that tells me whether the arc is stable?
2. Do I need to get ARC OK somewhere else? I read in another forum that some plasma units don't have a dedicated ARC OK and you have to use a current sensor (e.g., Hall sensor) to detect whether current is flowing. Could this be the case with Stahlwerk?
3. What about the control socket? When I unplug the hand torch from the control socket, I have the contacts that previously connected the trigger. Does the Stahlwerk send any signal back through this socket that I could use as ARC starting signal? Or is it really just a passive input for the trigger?
4. Generally what should I do?
What I already understand:
- The THCAD-2 connects to the THC interface (the 2 pins) and then to the encoder input of the Mesa 7i96S. That's for THC voltage measurement.
- Torch start/stop ill get it directly of the cable
- But what about ARC starting signal output? How does LinuxCNC know the arc is actually there and can safely start moving?
How would you solve this with the Stahlwerk CUT 60 P Digital?** Is there a hidden ARC OK output I'm missing? Or are you all working with a current sensor?
Any help is appreciated – photos or pinouts would be great if anyone has them!
Thanks in advance
  • andrax
  • andrax's Avatar
10 Jun 2026 17:22
Category: Deutsch
eigentlich nicht.
Solange du nicht irgendwelche Systemeinstellungen verbogen hast, solltest du erst mal die Schritte von rodw ausführen.
  • Muecke
  • Muecke's Avatar
10 Jun 2026 14:54
Category: Deutsch
Zunächst einmal danke fürs Feedback. Ich habe den Eindruck, dass es sich um etwas Größeres handelt, da ich bei der Installation von Ethernet recht viel herumprobieren musste. Ich habe so langsam den Eindruck, dass ich mir einige Stolpersteine selbst in den Weg gelegt habe. Wie bekomme ich das System wieder aufgeräumt?Oder wäre es besser, das System neu aufzusetzen und von vorne anzufangen?Noch ist keine Maschine darauf, die darauf laufen muss. Es ist ein neues System, das erst noch hochgefahren werden muss.
  • spumco
  • spumco
10 Jun 2026 12:29
Replied by spumco on topic Measurement Only Axes
Category: Basic Configuration
Maybe look in to extra joints:
linuxcnc.org/docs/stable/html/man/man9/motion.9.html
The optional [b]num_extrajoints[/b] parameter specifies a quantity of joints that participate in homing but are not used by kinematics transformations.
You can set the joint to home-in-place in the INI file so LCNC doesn't try to move it.
Displaying 3151 - 3165 out of 12540 results.
Time to create page: 0.283 seconds
