  • Ismacr63
  • Ismacr63
12 May 2026 19:41
Help reassign pins 7i92 was created by Ismacr63
Category: Driver Boards
I have a Mesa 7i92 card with the firmware file 7i92_5ABOBx2D.bit loaded, using a Chinese 5-axis breakout board on connector P2. Pins 16 and 17 are currently taken up by stepgen. Is there any way to reassign them so I can use pin 17 to control a relay and pin 16 for mist coolant?
  • eraserhd
  • eraserhd
12 May 2026 19:18
Replied by eraserhd on topic Remora for RP2040
Remora for RP2040
github.com/scottalford75/Remora-RP2040-W5500/pull/15
I haven't solved PIO yet (I went down a path that was interesting but did not work), but this PR allows stepping a little faster (50KHz), but also allows a lot more precision in step pulse generation and configuration of steplen, stepspace, dirhold, dirsetup, and dirdelay on the RP2040.
It also documents my future idea about PIO. I know how to make it work now and hope to get to it soon.
  • scsmith1451
  • scsmith1451's Avatar
12 May 2026 18:52
Replied by scsmith1451 on topic Launching gladevcp panel with gmoccapy
Category: Gmoccapy
Thanks for the information HansU, I'll update my glade and fix the errors.
The GMOCCAPY documentation indicates that if no EMBED_LOCATION is defined, the the glade VCP will be floating. Is that no longer valid?
  • spumco
  • spumco
12 May 2026 17:43
Replied by spumco on topic LINUXCNC TURN
LINUXCNC TURN
What specific errors are happening?
Are you getting failed posts, or g-code that doesn't work?
Keep in mind that the generic F360 post will require editing for machine-specific M-codes and other features.
I did have to modify the post to output G43 properly.
  • COFHAL
  • COFHAL
12 May 2026 14:03
Replied by COFHAL on topic Qtvcp GUI and hal pins
Category: Qtvcp
After reading it a bit more closely, I think the current QtDragon documentation regarding Bridge_HAL is clear. It would only be helpful to add an example of the use of Oword subroutines to the [MDI_COMMAND_LIST] section, so it's understood that in addition to macros like G0 Z25;X0 Y0;Z0, subroutines can also be used.
Something I'd like to see, though I'm not sure if it's possible, is that AXIS has some functions that are executed through Key Bindings, which are very restricted in QtDragon. For example, in my case, I designed a control panel with a keyboard and external buttons. AXIS has the function to clear the plot, and if there's an error, a window appears on the screen indicating it. In AXIS, you can simulate closing this window with an external button, but in QtDragon, you can only close it using the mouse or the touchscreen. The same applies to deleting the plot; in QtDragon, you can only delete it by clicking the button.
  • meister
  • meister
12 May 2026 09:37
HalView was created by meister
HalView
Category: Other User Interfaces
little tool to see the hal-values in realtime:
  • northernstepper
  • northernstepper's Avatar
12 May 2026 03:37
Replied by northernstepper on topic Stepper Driver Enable Pin
Category: Basic Configuration
Will do thank you. How would they be connected to estop, for future reference
  • Venker
  • Venker
12 May 2026 03:15
Replied by Venker on topic LINUXCNC TURN
LINUXCNC TURN
BTW linux 2.9.1 version
and new fusion linux cnc version
Also some guidance on troubleshooting issues "like" this would be deeply appreciated.
  • rodw
  • rodw's Avatar
12 May 2026 03:14
Replied by rodw on topic Stepper Driver Enable Pin
They are actually disable pins, not ensable. Its best to leave them disconnected as you have enough to worry about for now. Sometimes they are useful for estop but as Tommy says leave well alone for now;
  • Venker
  • Venker
12 May 2026 03:13
LINUXCNC TURN was created by Venker
LINUXCNC TURN
I’m having a lot of trouble configuring my LinuxCNC turn profile with Fusion 360. Could someone explain how they set theirs up? Does the standard post/profile work properly on your machine? I keep running into a ton of errors, even when trying the example files. Any guidance or working configurations would be really appreciated.
12 May 2026 03:07
Replied by tommylight on topic Stepper Driver Enable Pin
Or should I leave them unconnected.
Yes, at least for now, till you get the machine working properly.
  • Twitchy88
  • Twitchy88
12 May 2026 02:57
Replied by Twitchy88 on topic GRUB bootloader failed
Category: Installing LinuxCNC
Thanks for the help.
Installing it on another computer worked. At first it gave the same error because it didnt have the drivers for the wireless card. Plugged it in and it installed no problem.  Im wondering if I wasnt getting internet on the cnc, it said it connected successfully and internet worked when I booted live.
  • northernstepper
12 May 2026 02:44
Stepper Driver Enable Pin was created by northernstepper
Hello all, I have a question about the enable pin on my stepper drivers, I have 4x DM542T stepper drivers from Stepper Online connected to my Mesa 7i76EU. Is it recommended to connect the enable pins to the Mesa, and if so where should they be connected to. Or should I leave them unconnected.
  • grijalvap
  • grijalvap's Avatar
12 May 2026 02:30
Replied by grijalvap on topic Best way to do external controls for LinuxCNC
Any bpdy in the forum heve used this gRPC
github.com/dougcalobrisi/linuxcnc-grpc
not sure if it is real time but I think is an interesting aproach sinse GRPC is lenguaje agnostic
prety well supported and i think the c++ or RUST version can run deterministic
  • grandixximo
  • grandixximo's Avatar
12 May 2026 02:11
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Should be fixed
Displaying 3781 - 3795 out of 12541 results.
Time to create page: 0.339 seconds
