  • smc.collins
  • smc.collins
24 Apr 2026 13:18
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
Category: Turning
check the angle on the bar, and be sure of your tip height, both will break most threading insert, been there got the t shirt
  • rodw
  • rodw's Avatar
24 Apr 2026 11:59
Replied by rodw on topic HAL component for tangential knife
Category: HAL
This appeares to be working now
checkout  the state-tags-arc from my repo to test
github.com/rodw-au/linuxcnc/tree/state-tags-arcs
There is some house keeping to sort out. I need to work out how to use equate G_1,G_2  etc in motion (control.c) I remember the devs last time I tried, they did not like this  but I have not got a solution yet. Its just housekeeping and will only be an issue ig the equates for gcodes are ever changed.
  • cmorley
  • cmorley
24 Apr 2026 04:14
Replied by cmorley on topic Qtvcp GUI and hal pins
Category: Qtvcp
Have you run linuxcnc from a terminal so you can see any errors?
you need python3-zmq package on the system.
macros are defined under heading:
[DISPLAY]
MACRO=
MACRO=
I'll have to check later to confirm all work properly.
  • Metalurgent
  • Metalurgent
23 Apr 2026 22:12
Replied by Metalurgent on topic Adding additional i/o beyond default
Thank you, Peter.
I did as you suggested and I was able to see the dio listed in halshow.
I spent all day trying to understand how to access and setup the inputs and outputs using the M64+ commands.
I think I figured it out after hours of frustration.
My issue was understanding the syntax of how the actual screw terminals of the 7I77 connected to the input of an MDI command of say M64 P4.
I needed to get my head around the random name that I had assigned to an output [ say Digital out 4], the terminal on the 7i77 ( that could be terminal 8..) and the call sign [say M64 P3] that i put into MDI . Understanding how to link them all together in hal to get a predictable result was a head-wreck.
Watching that single halshow dot finally turn from brown to yellow made my day.
Easy once you know.....as usual.
Thanks.
  • rodw
  • rodw's Avatar
23 Apr 2026 21:09
Category: HAL
Having looked at this a few times, I think that the best place to do it is actually in a G-code filter. ie calculate the heading from the G-code and insert / append C axis moves as appropriate.
Actually, there is a use case that needs motion pins. A plasma cutter cutting bevels. An additional joint is needed to tilt the torch and there are complicated tilting torch holders that keep the torch tip axial to the Z axis (single axis bevel head). I was just chatting to a user with one who uses the post processor approach.
But picture a simpler torch holder design where the torch tip position moves when tilted. A component could take the bevel angle and calculate the offset x,y,z positions of the tilted torch tip and then apply external offsets to locate the torch on the cut path in real time. This way, the machine could consume simple 2D x,y gcode (which is the norm for plasma cutters) and enter plasma cutting nirvana with bevelled holes.
23 Apr 2026 20:37
23 Apr 2026 20:33
Replied by tommylight on topic Mesa 7IA0 inputs threshold
Category: Driver Boards
Yes using level shifters, but if it works properly with the resistor just use that, it is OK.
www.google.com/search?num=10&client=fire...286&bih=974&dpr=1.33
23 Apr 2026 20:28
New Youtube chanel for CNC .... anything ! toma cnc
Category: Show Your Stuff
I do know the password - i just cannot type it in.
Can you elaborate on this?
  • Glite
  • Glite
23 Apr 2026 19:25
Mesa 7IA0 inputs threshold was created by Glite
I found a situation with inductive sensors where default input threshold of 3.5 V is to low, as those sensors are 4.5-5.5 V in OFF state.
For one sensor I mitigated it with adding 10K pulldown resistor. Is there any better way to do that?
  • emresensoy
  • emresensoy
23 Apr 2026 18:51 - 23 Apr 2026 19:20
 CAM232 - 2.5 Axis CAM Software (First 2 Code Free, than 1$ for each)
A 1-month free Pro membership will be automatically added to any account upon first login.
If you experience any problems, please write here.
  • smcivor
  • smcivor
23 Apr 2026 18:25
Tom I came across your videos looking for information on a Messer plasma table. I have an older machine year 2000 that I bought from a John Deere factory in Iowa that was running the day that I purchased it, I am trying to get it up and running but don't have software or the computer cables etc to fire it up. Everything is hooked up but its looking for a password. Has an older Navigator control that looks good but I cannot get past the password as I cannot type it in. I do know the password - i just cannot type it in. Messer is no help, they just keep saying it is obsolete. If you could point me in the right direction or be of any help I would greatly appreciate it. Thanks Sean
614 309 6854
  • daro
  • daro
23 Apr 2026 18:24
NoHAL - Visual editor for LinuxCNC machine configuration
Category: Configuration Tools
HI,
I wanted to share with you a tool I've built to make my life easier and I think it has reached enough maturity to be used as a real tool.
It is be no means perfect and some of it is not as polished as i wish it was, but I thought it'd be nice to have it reach more people.
The project's name is NoHAL and as the same suggests - it's supposed to make you not write HAL anymore.
https://github.com/b0czek/noHAL/blob/main/docs/public/screenshots/editor.png?raw=true
It does that by visualizing HAL network as node editor - with an added benefit of making repetitive parts of your HAL configuration templatable through sheets.
I've built it around what I work with, so it might not match your workflow perfectly but issues/pull requests are open for suggestions.
There is Mesa configuration utility built-in but I've only defined a limited set of boards - only those I have used.
Here's a link to repo with it:
And here's a guide I've written on how to use it:
b0czek.github.io/noHAL/
Please let me know what do you think of it.
  • JT
  • JT's Avatar
23 Apr 2026 18:15 - 23 Apr 2026 18:18
Replied by JT on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
Yes, Flex has full manual spindle controls for all 8 spindles. I'm working on updating the documents.
Just to prevent any search engine from finding incorrect information I deleted the posts with the incorrect information.
JT
  • mclien
  • mclien
23 Apr 2026 17:48
Replied by mclien on topic retrofitting a Proxon for coin die milling
Category: Milling Machines
Thanks for all the hints.
And because I hate to abandon discussions out of nowhere, let me just say our family was hit with quite a tragedy and I can't say when there will be time and mental energy to get back to this project.
greetings mclien
  • papagno-source
  • papagno-source
23 Apr 2026 17:20
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
I will do one last test with an Advantech Aimb 505 card with an i5-6700 processor. I tested the latency with Trixie and under stress it does not exceed 40 microseconds with a maximum delta of 2. I asked the customer if I could do this test and he will give me the machine available. Also because, now the only solution we are waiting for is a new version of Ethercat that is adapting Grandixximo?
Displaying 4216 - 4230 out of 12541 results.
Time to create page: 1.522 seconds
