  • masawee
  • masawee
07 Apr 2026 06:15 - 07 Apr 2026 06:17
Replied by masawee on topic Raspberry with LinuxCNC direct interface
i think NOT need this HAT, i think can build own "hat" mean connect to gpio pins shift level converter tx108 chip module, input is 3,3V and this module convert output to 5V and this 5V signal can wired to stepper driver board DM556 etc, step pin and dir pin and enable pin. but problem have how i setting rpi4 linuxcnc all gpio pins ? rpi4 and has installed linuxcnc but if looking have only config wisard and this can only setting paraller port pins, and pnconfig tool has only how setting mesa card pins, i not understand how can setting rpi4 gpio pins all step, dir, enable and all input pins home, e-stop, limits, probe, etc pendant encoder, rotary SW, axis select, scale select. i have installled linuxcnc to rpi4 and software/image working ok, but how setting gpio pins ?
  • grandixximo
  • grandixximo's Avatar
07 Apr 2026 03:23 - 11 Apr 2026 14:03
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I was wrong, on closer inspection the planner can stay within the jerk limit without falling back to a full stop.
It was a bug in the jerk budget split during Bezier blends. Tangential jerk (Ruckig along the path) and centripetal jerk (curvature change through the blend) were budgeted independently, 50% and 100% of the per-joint limit respectively, assuming they're orthogonal. They are in Cartesian space, but not per joint axis, where they add as scalars. For @ruediger123's octagon: 25k + 50k = 75k on a 50k limit, matching the ~47% overshoot in the HALscope trace.
Fix: subtract the tangential share before allocating centripetal. 25k + 25k = 50k, exactly at the limit, no overshoot, no wasted headroom. Corner velocity drops ~20% vs the buggy code, but it's the true physical maximum.
@PCW was right, the TP should always obey constraints. Fix is in the 9d branch.
Edit:
the artifacts at the end of the page.
I'm also looking at what Automata had reported, I think I can improve merging of small segments, I'll put some effort into that
Edit:
I think the previous build maybe have some issue because I merged master without being careful
New build, still working on speed, not ready yet
delete link, this had issues too
  • spumco
  • spumco
07 Apr 2026 01:32
Replied by spumco on topic Lathe C axis homing
Lathe C axis homing
Here you go.
Again, it's complicated.  Feel free to ask questions if something is unclear.
A few thoughts:
  • Still a work in progress, but the part(s) you want works.
  • HAL files are broken up by major components of the config.
  • Lots of comments - you should get a sense of the uncountable number of times I've tried or tweaked something.
  • Signal names are all upper case because LCNC's halshow sorts by case first, then alphabetically.  Drives me nuts searching for signals if they're all jumbled due to upper/lower case.
  • Sub-spindle is not connected to an axis.  LCNC doesn't have duplicate rotary axes like UVW for XYZ.  I found (so far) M19 works fine for the sub.
  • Main spindle motor is a SZGH 'servo spindle' - an induction motor with a pretty smart drive.
    • The drive has position, velocity, and torque modes, just like a brushless PM servo
    • I believe @Aciera switches his drive between velocity and position when he switches LCNC between spindle and C-axis.
    • I found that position mode had a bit of dither at stand-still, possibly due to the induction motor characteristics.  So my drive/motor is always in velocity mode, unlike @Aciera's example.  This may help you with your Schaublin's spindle drive.
  • --Matt--
  • --Matt--
06 Apr 2026 22:58 - 06 Apr 2026 23:01
Replied by --Matt-- on topic Does auto-leveling for Probe Basic exist?
Category: QtPyVCP
You may find that the user tab for Z-compensation is suitable for PCB machining (that is what I intend to use it for)...
forum.linuxcnc.org/qtpyvcp/56808-surface...asic?start=13#339938
This lets you probe the surface with a grid and then when compensation is enabled it applies an interpolated Z offset so that it tracks the surface. This way you don't actually have to modify the g-code. (Should make engraving depth more consistent if the bed isn't perfectly level).
  • --Matt--
  • --Matt--
06 Apr 2026 22:42
Replied by --Matt-- on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
I'd given up on this for a while and only just noticed the replies here, thanks!
After updating linuxcnc and probe basic I was then able to get the user tab working very quickly. I should be able to have a go at some PCBs now.
Thanks all for your help.
  • PCW
  • PCW's Avatar
06 Apr 2026 21:55 - 06 Apr 2026 22:05
Spindle encoder configuration (with G76 threading command and Mesa 7i96s)
Category: HAL
is spindle.0.at-speed  true?
Also does the index work?
Test by (either in halshow or with halcmd -kf)
sets spindle-index-enable true
watch  spindle-index-enable in halshow
it should go high with the sets command and then low when you rotate
the spindle past the index position.
  • slowpoke
  • slowpoke
06 Apr 2026 21:38 - 06 Apr 2026 21:40
Category: HAL
I made a new configuration using pncconf and compared the spindle & encoder 0 section.
I don't see anything that's different, other than naming conventions (see attached)
I have a quadrature spindle encoder connected encoder (0) input. A & B
I now also have a 1PPR signal, connected to the encoder.0. index pin.
In Halshow
- spindle.0.revs counts up as expected when the spindle is rotated forward
- spindle.0.speed-in appears correct
- spindle.0.index-enable shows disabled
In my SM-10.hal file I have:
net spindle-index-enable <=> spindle.0.index-enable
IF I comment out this line, I can then enable spindle.0.index-enable manually in Halshow, that makes no difference when trying to open the file below (same error)
Regardless when I try to open the following 2 line G76 program I get the following error: "Chosen spindle(0) not turning in G76"
Program:
G0 X0.45
G76 P0.0625 Z-0.5 I -0.005 J 0.008 K 0.0503
What does the error message actually mean and/or what is Linux missing that it needs?
It has the quadrature encoder signals and it has the index pulse, that I can see toggle as the magnet passes the sensor once per rev,
The revs counter is counting up 1 per rev.
  • jetbadger
  • jetbadger
06 Apr 2026 19:30
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
Oh whichever is easiest for you, I don't have a parting slide and C axis at this moment is all I'm trying to do. I'm immensely grateful anyway :)
  • COFHAL
  • COFHAL
06 Apr 2026 19:15
Replied by COFHAL on topic Help with Lichuan drives
Category: EtherCAT
You can try these examples that I have working with some of those ETHERCAT servos
File Name: EC-Axis-C.rar
File Size:45 KB
File Name: EC-position.rar
File Size:20 KB
File Name: EC-position-vel.rar
File Size:21 KB
File Name: EC-Spindle.rar
File Size:44 KB
  • ewlsey
  • ewlsey
06 Apr 2026 17:51
Replied by ewlsey on topic Cubic Interpolator
Cubic Interpolator
OK. I'm having a really hard time understanding the code base. The files don't seem to have any comments explaining what they actually do, what leads to them, or where they lead to.
If the cubic.c is only for non-trivial kinematics, how does the interpolation work for normal cartesian machines?
I was assuming that every servo period it pulls a target position and velocity from the trajectory planner creating 1ms stair steps of constant velocity, but I really can't tell.
  • Dudelbert
  • Dudelbert
06 Apr 2026 17:51
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Good to hear that you managed to get your toolchanger working.
I would hope that the PID settings can be constant. I did think that the error term can be scaled.
We know the state of the backgear and the output (spindle encoder). With the analog output, we can have at least a good estimate of the motor RPM. So back-calculating the ratio of the variator should be possible, at least to a degree.
If we scale the error term with the overall transmission ratio and tune the PID at that state, it should give reasonably good behavior over the whole range, wouldn’t it? I am not sure of this. Doing this would give a wonky error at startup (estimating the variator would take a few rotations, I think), but it should be fine before the spindle is fully started up, I think.
But I may have an error in my thinking. Control theory is not my strong suit.
  • andypugh
  • andypugh's Avatar
06 Apr 2026 17:32
Replied by andypugh on topic RRW Lab SPI with raspberry pi 5
Category: Driver Boards
Might be worth asking in the Remora thread.
  • RotarySMP
  • RotarySMP's Avatar
06 Apr 2026 17:27
Category: Turning
I am working on a similar solution, but want to do it as a comp, since I got my comp for the turret working this weekend.
Gear ratio can be inferred from spindle speed / commanded voltage, corrected to frequency, corrected to RPM. (You are a step ahead of me there, with your vfd frequency out put).
I expect we will need a constantly changing set of PID settings, as the inertia varies over the entire speed range.
I always wondered whether the back gear can change gear with the spindle running, but it would be pretty pointless, given the huge 6.5:1 spindle speed change, so I will only trigger it stationary.
Cheers,
Mark
  • andypugh
  • andypugh's Avatar
06 Apr 2026 17:19
Replied by andypugh on topic W axis machine config
And you see the pin iocontrol.0.emc-enable-in toggling high?
Maybe something odd with the amp-fault pin for the W-axis?
joint.N.amp-fault-in
  • RotarySMP
06 Apr 2026 17:15
Replied by RotarySMP on topic Can't find M1 - optional stop switch
Category: Gmoccapy
Yeah, I would also happily sacrifice full screen for M1.
Displaying 4846 - 4860 out of 12541 results.
Time to create page: 0.368 seconds
