  • RotarySMP
  • RotarySMP's Avatar
03 Apr 2026 18:35
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
Oh. Doh!!!!!
Thanks a lot. I was so focused on the comp, I missed the obvious.
  • spumco
  • spumco
03 Apr 2026 18:30
Replied by spumco on topic CSS/G96 for other than X-axis?
Hmm.  I didn't check on a sim, just my real hardware.
My backplot jumps when I do the switchkins switch, but no amount of fiddling could get the hardware X-axis to move when I had velocity set to zero.
  • andrax
  • andrax's Avatar
03 Apr 2026 18:13
Replied by andrax on topic Ethercat SDOS to XML
Category: EtherCAT
I understand.
I would have chosen that approach.
First, set up a system where the module runs, and then read the communication data.
I think it’s very consistent of you not to use Windows.
Respect.
As far as I know, there are also system managers that run on Linux.
Would that be an option?
03 Apr 2026 18:06
Replied by tommylight on topic Schaublin 125-CNC retrofit.
Category: Turning
Are looking at the right file? The error is in 'turret.hal' (ie the hal file) NOT 'turret.comp' (the component)
Yes, this.
  • bill.anderson
  • bill.anderson
03 Apr 2026 17:54
Can't install Linux 2.9.8 hybrid alongside Windows 11.1
Category: Installing LinuxCNC
I went through all the recommended steps on the forum with the exception of clearing the disk of Windows and partitioning the whole disk as MBR and then reinstalling windows.
  • Aciera
  • Aciera's Avatar
03 Apr 2026 17:54
Replied by Aciera on topic Schaublin 125-CNC retrofit.
Category: Turning
  • RotarySMP
03 Apr 2026 17:54
Category: Turning
You still have the:
.turret.hal:1: Unknown command ''
error, there is something on the first line of that file causing the error.
Try running it through a dos/win to Linux script, might be some strange character there.
Yeah, I see that too.
I tried a few different ways to identify and remove strange characters, and even completely rewrote the code by hand into visual code studio. It compiles without error and runs without error in Halrun, but only fails as part of a full linuxcnc start.
  • andypugh
  • andypugh's Avatar
03 Apr 2026 17:44
Replied by andypugh on topic Schaublin 125-CNC retrofit.
Category: Turning
If I fall back on somehing like 2.8.4 buster ISO, do I loose your latest macros layout?
I think that it should work as long as you have GTK3
03 Apr 2026 17:43
Might have better luck searching the Debian forums with this, although win11.....
03 Apr 2026 17:39
Replied by tommylight on topic Nice small 5 axis machine with some nice features
Category: Show Your Stuff
Bump.
They post plenty of new videos, but i did not have time to watch them.
  • Aciera
  • Aciera's Avatar
03 Apr 2026 17:39 - 03 Apr 2026 17:44
Replied by Aciera on topic CSS/G96 for other than X-axis?
Interesting. Just checked on a sim on 2.10pre and setting ini velocities to 0 does not quite work for me. The tool moves to the start of the spiral and then moves back. A bit strange really:
Same on 2.9.8
  • Lcvette
  • Lcvette's Avatar
03 Apr 2026 17:26
Replied by Lcvette on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
thats true, i did that because we now listed everything here in the docs. I will remove the machine setup file ini since it can be copied directly from the docs page instead and will be kept more current. good looking out susan-parker!
03 Apr 2026 17:10
Category: Turning
You still have the:
  • RotarySMP
03 Apr 2026 16:33 - 03 Apr 2026 16:43
Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie
Category: Gmoccapy
Hans contacted over the github bug tracker, to have me run the Gmoccapy lathe sim, and sure enough, there is no scaling error behaviour there.
So I also tried the Gmoccapy Lathe_Macros sim, and that has the scaling behavior error.
When I created my current config, copied my old 2.8.2 config files, and cut paste the lathe macro files from this sim. Any ideas where I need to look for corrective action appreciated.
Cheers,
Mark
  • RotarySMP
03 Apr 2026 16:30
Category: Turning
I tried running just the turret.comp under halrun, and have the same result as Andy. It works.
But when I call it from my custompostgui.hal, it errors out. See attached error logs.
Cheers,
Mark
Displaying 4966 - 4980 out of 12541 results.
Time to create page: 0.326 seconds
