  • persei8
  • persei8's Avatar
11 Mar 2026 17:57
Replied by persei8 on topic Tool Manager
Tool Manager
Seems like a cool project but not really relevant. My tool manager is just a plugin for the QtDragon screen to manage metadata for the linuxcnc tool table. It is not concerned with synchronizing other tool table formats, though if it did, I think Fusion360 and Vectric databases would be good candidates.
  • PCW
  • PCW's Avatar
11 Mar 2026 17:50
  • PCW
  • PCW's Avatar
11 Mar 2026 17:37 - 11 Mar 2026 18:54
Mesa 7i76eu output_sink and output_source confusion
Category: Driver Boards
Unlike sserial pins, you can only "setp"  sserial parameters (like the source and sink masks) in LinuxCNCs hal file,
they cannot be  changed dynamically. This is true of all sserial parameters, that is, they are only updated on driver startup.
The output modes are something typically set to match the interfaced hardware, so do not need to be changed dynamically.
  • TAKUYA
  • TAKUYA
11 Mar 2026 17:34
Replied by TAKUYA on topic Ethercat random jitter fix
Category: EtherCAT
Installed the latter. So far so good, didnt do any major tests but multiple power cycles. Also, with the ClockSyncCycles set to 5 and syncToRefClock=true, my servos are now instantly OP. no waiting for them to be ready which caused some amplifier errors when i was too quick with the power button recently.
no idea if thats because of the new linuxcnc-ethercat version or because of those parameters.
one thing to note though, the dc-phased pin never went high for me.
  • Badger1875
  • Badger1875
11 Mar 2026 16:50
AI generierter G-Code wird in LinuxCNC völlig verkrüppelt dargestellt...
Category: Deutsch
Hallo zusammen,
hatte jemand von euch schon mal dieses Problem?
Ich bin noch recht neu im CNC-Bereich und kenne LinuxCNC (MiniMill 2.9) noch nicht so lange. Ich brauchte eine Aufwärmroutine für meine Maschine und habe daher mithilfe von AI eine Datei generiert.
Ich habe den Code in meinen Windows-Editor importiert und die Datei als <Name>.ngc gespeichert.
Ich hatte zuvor selbst kürzere G-Code-Dateien geschrieben, gespeichert, auf die Maschine übertragen und geöffnet: Sie funktionierten sofort.
Als ich jedoch versuchte, den G-Code mit den von AI generierten Teilen zu öffnen, waren die Zeichen im Code völlig verstümmelt – der gesamte Code war unlesbar!
Als ich die Datei mit dem „gedit“-Editor unter Linux öffnete, sah alles einwandfrei aus.
Hat jemand Ideen, Tipps oder Lösungen?
Viele Grüße
Freddie
  • TAKUYA
  • TAKUYA
11 Mar 2026 15:54 - 11 Mar 2026 15:55
Category: EtherCAT
Gotcha. i will try to get this (github.com/linuxcnc-ethercat/linuxcnc-et...84ef36b53f0b734eaedf) installed first, with syncToRefClock=true and ClockSyncCycles set to 5 to see if my jitter issues go away. they are very random as of right now.
Or should i use this patch with the settings above?
github.com/grandixximo/linuxcnc-ethercat
  • DerKlotz
  • DerKlotz
  • liutas4x4
  • liutas4x4
11 Mar 2026 14:15
Replied by liutas4x4 on topic some qs about Axis tuning
thank you,
I have custom PyVCP on right side of Axis. Will I need rewrite this panel is the case I will move to QtVCP or gmoccary?
  • Clive S
  • Clive S
11 Mar 2026 13:43
  • garmanarnar
  • garmanarnar
11 Mar 2026 13:10
Hello all, I am trying to configure `output_sink` and `output_source` pins for my Mesa 7i76eu and I am running into some surprising behavior. My goal is to put `hm2_7i76e.0.7i76.0.0.output-11` into sink mode.
Long story short, putting `setp hm2_7i76e.0.7i76.0.0.output_source 0x0000F7FF` and `setp hm2_7i76e.0.7i76.0.0.output_sink   0x00000800` in my HAL file after loading `hm2_eth` does not seem to have any effect, output-11 remains in sourcing mode. I spent some time debugging this and found some surprising results.
The first thing I did was attempt to setup the pins manually without changing anything in my HAL file. For this test, my HAL file did not set `output_sink` or `output_source` at all. On a fresh power cycle of both my computer and the mesa card, the following works correctly (causes output-11 to sink when TRUE).
halcmd setp hm2_7i76e.0.7i76.0.0.output_source 0x0000F7FF
halcmd setp hm2_7i76e.0.7i76.0.0.output_sink   0x00000800
halcmd setp hm2_7i76e.0.7i76.0.0.output-11     TRUE
I can toggle output-11 back and forth between TRUE and FALSE and it appears to work just fine. The strange part is that if I set output_source = 0x0000FFFF output_sink   = 0x00000000 (going back to the default value), `output-11` remains in sinking mode, it does not switch back to sourcing mode. The only way I can get it to switch back is if I power cycle the Mesa card.
The second thing I tried was setting `hm2_7i76e.0.7i76.0.0.output_source 0x0000F7FF` and `setp hm2_7i76e.0.7i76.0.0.output_sink   0x00000800` as part of my postgui HAL, the thinking being that maybe there is some timing issue for when you configure the output pin modes. This does seem to work as long as I do a power cycle of the Mesa card and computer, but it feels like a bit of a hack.
I'm using this setup to control activation of a wireless probe receiver which needs `output-11` to sink to ground in order to activate the probe, so my main worry is that I'm just hiding a timing related issue by doing this in postgui and will end up running into a crash down the line. If anyone has some insight into how `output_source` and `output_sink` are supposed to work, that would be appreciated!
Thanks!
  • ihavenofish
  • ihavenofish
11 Mar 2026 13:05 - 11 Mar 2026 13:06
Replied by ihavenofish on topic motion channels for robotic atc library
neat. this is the current state of the robot. xyz (and call be point to point one axis at a time). a drawbar (air) and a pivot for the arm (air?) and the door opener (air?).
grr. how do i NOT embed the video? its stripping out the time index. 2:41.
  • ihavenofish
  • ihavenofish
11 Mar 2026 12:09
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
helo, give me your contact.
join the discord
discord.gg/PRkQbQ2wmZ
  • elisilva
  • elisilva
11 Mar 2026 11:15
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
Hi!Will upload! but photos not very good ! so hard to extract from case box.
  • tivoi
  • tivoi's Avatar
11 Mar 2026 10:58
Replied by tivoi on topic Mini wannabe datron build
  • DerKlotz
  • DerKlotz
11 Mar 2026 09:41
Wiring Leadshine DM856 Ena+ and ENA- -> Mesa 7i76e
Category: Milling Machines
Please see attached file
Can i just use one Mesa output for all three driver or do i have to use three outputs? One for each driver. In the LinuxCNC configuration i can set enable for x, y and z axis.
Displaying 5896 - 5910 out of 12544 results.
Time to create page: 0.404 seconds
