27 Feb 2026 01:27
Replied by tommylight on topic 7I77D over heat
7I77D over heat
Category: Driver Boards
Moved to "driver boards".
Check the wiring, or post pictures of the wiring here so we can have a look.
  • okielaxplyr
  • okielaxplyr
27 Feb 2026 01:20
7I77D over heat was created by okielaxplyr
7I77D over heat
I am using a optocoupler (from amazon) between my 7i77D output and a solenoid valve for a spindle break in the sinking configuration, the output is over-temperature faulting for some reason.
using TB8 OUTPUT0. Field voltage is 24Vdc and driving the relay with the same 24 power supply.
I set up the opto relay on the bench and it only draws 2.2ma on the input in low position.
I'm kind of at a loss, the manual says the outputs can take up to 350ma.
Please advise
John V.
26 Feb 2026 22:01
Replied by tommylight on topic Just When You Couldn't Hate Government More
Let's see how long it takes for such cr@p to reach Europe...
  • Hannes
  • Hannes
26 Feb 2026 22:01 - 26 Feb 2026 22:02
Replied by Hannes on topic XHC WHB04B development?
I just had an idea: I don't need A/B/C, so I wired the feeds to these channels. It works way better anyway and I can use the jog wheel.
You can not use this in MDI mode due to when jogging, the WHB automatically changes to manual mode.
In auto mode with linuxcnc 2.9.8 without my patch, you probably will get a lot of error messages due to the whb wants to change from auto to manual. But this is gone with this fix:
github.com/LinuxCNC/linuxcnc/pull/3810/c...f939ee3cfb99275R1344
See
File Name: xhc_whb04b_6.hal
File Size:15 KB
after:
#Rewire feeds to A/B/C
  • tar_san
  • tar_san
26 Feb 2026 21:53 - 26 Feb 2026 21:56
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Thank you so much,  This video is helpful.
And I counld not find ESI upload function in SigmaWin+.
I agree that using SigmaWin would be better if I could use it to do that.
And I think .. sometimes updating new ESI to older software version device is a little bit risky..
I'm considering a little bit about it.
Anyways, thank you so much you guys.
26 Feb 2026 21:50
Need to install newest Linux Debian Bookworm with the newest Linuxcnc preempt-rt
Category: Installing LinuxCNC
Normal gcode
G17 G90 G64 P0.001 M3
G21
G0 Z0.1000
F5000.0000
F5000.0000
G0 X115.8525 Y150.0000
F5000.0000
G1 Z-10.0000
 X111.6756
 X109.9170 Z-9.5877
 X109.6238 Z-9.2348
 X109.3307 Z-9.1373
 X108.5979 Z-9.3725
 X105.9599 Z-9.6471
 X105.6668 Z-9.9799
 X105.3737 Z-10.0000
 X80.9722
Parametric gcode
#<xscale> = 1.0
#<yscale> = 1.0
#<zscale> = 1.0
#<fscale> = 10000.0
#<toolno> = 1
#<rpm>    = 1600
N30 G21
N40G90
G64P.1
N50T#<toolno>M6
N60M8
N70S#<rpm>M3
N90G0Z[#<zscale>*10.]
N80G0X[#<xscale>*53.]Y[#<yscale>*-56.128]
N100G1Z[#<zscale>*-25.372]F[#<fscale>*100]
N110G1Z[#<zscale>*-27.372]F[#<fscale>*225]
N120Y[#<yscale>*-56.12]Z[#<zscale>*-27.725]
N130Y[#<yscale>*-56.105]Z[#<zscale>*-27.894]
N140Y[#<yscale>*-56.06]Z[#<zscale>*-28.152]
N150Y[#<yscale>*-56.051]Z[#<zscale>*-28.184]
N160Y[#<yscale>*-55.992]Z[#<zscale>*-28.405]
N170Y[#<yscale>*-55.902]Z[#<zscale>*-28.651]
N180Y[#<yscale>*-55.792]Z[#<zscale>*-28.888]
N190Y[#<yscale>*-55.661]Z[#<zscale>*-29.115]
N200Y[#<yscale>*-55.511]Z[#<zscale>*-29.329]
N210Y[#<yscale>*-55.343]Z[#<zscale>*-29.53]
  • my1987toyota
  • my1987toyota's Avatar
26 Feb 2026 21:31
Just When You Couldn't Hate Government More was created by my1987toyota
  So I just came across this a few minutes ago. I am so sick of this new police state everyone is being forced into.
and this is just the beginning.
  • Hannes
  • Hannes
26 Feb 2026 21:07
Hmm, mine shows always 0. In Mach3, Mach4 and LinuxCNC.
I'm pretty sure I just have a variant with a different buggy firmware than yours.
However, if you have time to spare, you can comment out the line in my last post, recompile linuxcnc and send me the result. Which version of LinuxCNC are you using?
  • Hakan
  • Hakan
26 Feb 2026 20:30 - 26 Feb 2026 20:31
Replied by Hakan on topic XHC WHB04B development?
Short update on that, Hannes.
While in auto mode and running a program it doesn't show F: nor S:
It does react on Feed+/- and Speed+/- but only on displayed values in the HMI, not the pendant display.
In Man mode it shows F: and S: in the way one expect.
  • Hannes
  • Hannes
26 Feb 2026 20:23
@Hakan:
Strange. Mine doesn't show anything. But it's an LHB04B-6 TX V3 (Wired version)
As much as I read, it should work the same, but might be not.
Starting with -Ha and commenting out github.com/LinuxCNC/linuxcnc/blob/master...whb04b-6/usb.cc#L209 it shows:
out 0x06fefdfe801800bc 060e0800161e0200 06008069006e0000
out size 24B hdr 0xfdfe dom 0xfe status 0x80 coord1 +0024.3772 coord2 +0008.7702 coord3 -0002.0000 feed 0105 spindle feed rate 00110
So it seams the values are sent. Might be my device has a different firmware. With Mach3, I tried already and I didn't see any value. I will try again with Mach4.
  • 3404gerber
  • 3404gerber
26 Feb 2026 20:17
Replied by 3404gerber on topic CiA 402 Folder Missing
Category: EtherCAT
According to github, that's a part of the feb 15 2025 commit:
-  hal_bit_t *request_cia402_homing;   // output requests homing (connect to cia402.n.home)
-  hal_bit_t *is_cia402_homing;        // input verifies custom homing (connect to cia402.n.stat_homing)
-  hal_bit_t *cia402_homing_finished;  // input from servo drive after homing (connect to cia402.stat_homed)
+ hal_bit_t *request_custom_homing;   // output requests homing (connect to cia402.n.home)
+ hal_bit_t *is_custom_homing;        // input verifies custom homing (connect to cia402.n.stat_homing)
+ hal_bit_t *custom_homing_finished;  // input from servo drive after homing (connect to cia402.n.stat_homed)
So if your example is older than this and that you compiled the comp from source, yes you have to use the current name. And if HAL tells you the pin doesn't exist, then it very likely doesn't exist.
  • NWE
  • NWE's Avatar
26 Feb 2026 20:10
Replied by NWE on topic Robot Arm and Controller
Category: CNC Machines
The specs they list for that mini control box makes me think it is a servomotor amplifier. I see ratings of 48VDC 42A max and 48VDC 104A max on several models of the control box shown at your second link.
Interesting possibilities.
  • DerKlotz
  • DerKlotz
26 Feb 2026 20:09
So is it normal? As i remember from my old PC there were mm shown... and G21 is mm, right?
  • T_D
  • T_D
26 Feb 2026 20:08
Probleme mit NativeCam was created by T_D
Category: NativeCAM
 Hallo zusammen, ich habe NativeCam auf meinem System installiert, jedoch läuft es bei mir bisher nicht wie erwartet. Konkret: Im Verfahrbereich / Geometry Tab sehe ich beim Ändern der Geometrie keine Änderungen. Wenn ich ein neues Werkstück hinzufüge, wird nicht einmal die Blockform angezeigt. Ich kann zwar Code erstellen, aber sobald ich diesen starten will, erscheint immer der Fehler: Word O gesuchtbzw. der G-Code scheint generell einen Fehler zu verursachen. Ich habe bereits geprüft, dass die Installation abgeschlossen ist, konnte den Fehler jedoch nicht finden. Hat vielleicht jemand von euch ähnliche Probleme gehabt oder kennt eine Lösung für dieses Verhalten? Jede Hilfe oder jeder Hinweis wäre super! Vielen Dank schonmal!
Hi everyone, I have installed NativeCam on my system, but it is not working as expected. Specifically: In the motion/geometry area, I don’t see any changes when I modify the geometry. When I add a new workpiece, the block form is not displayed at all. I can generate the code, but when I try to start it, I always get the error: Word O expected or the G-code seems to cause an error in general. I’ve verified that the installation completed successfully, but I haven’t been able to identify the problem. Has anyone experienced similar issues or knows a solution for this behavior? Any help or advice would be greatly appreciated!
  • PCW
  • PCW's Avatar
26 Feb 2026 19:48
Replied by PCW on topic Trying to set up position control mode
Category: HAL
The wiring does not look right to me, Don't those drives have differential inputs?
If they are differential, the 7I95 Step/Dir connections are wrong.
Displaying 6436 - 6450 out of 12556 results.
Time to create page: 0.341 seconds
