  • m0602232
  • m0602232
23 Feb 2026 11:02
Replied by m0602232 on topic Custom homing - distance coded glass scales
Yes of course but distance coded indexes are not as far as I know? (The distance between index marks varies and the distance is used to calculate absolute position)
  • Dudelbert
  • Dudelbert
23 Feb 2026 10:51
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
First of all, thank you for your help. I hope I’m not being annoying.
I tried again. If I connect the 7i83 to Smart Serial channel 0 and change the HAL file to match, the system does not work. Only channel 4 seems to work. That is the channel that worked with the firmware I used temporarily. I double-checked that the firmware which supports all five Smart Serial channels (that the 7i85 should use) is actually flashed.
I also tested the 7i73 on my mill, and it works fine, so at least that card is not faulty. However, it is not detected on any of the Smart Serial channels of the 7i85.
With the two 7i84U cards I have, I have the problem that only LEDs CR2 and CR7 are on, according to the manual. However, at least CR5 should also be on during startup. I don’t know how to troubleshoot this.
I’ve attached my HAL file as well—maybe I am doing something wrong there.
  • jarcysgru
  • jarcysgru
23 Feb 2026 09:17 - 08 Mar 2026 13:18
Replied by jarcysgru on topic Chinese Mesa 7I92 from aliexpress NEW
Category: Driver Boards
Witam czy podłączając kartę mesa 7i92 do płyty SSK-MB2 muszę odpowiednio prpodpiąc piny ?
[attachment=
74825]mesa_7i92_pins.jpg[/attachment]
Dla karty Mesa 7i92 współpracującej z płytą główną SSK-MB2 (którą można traktować jako płytę typu "generic breakout board" / zamiennik złącza LPT) najbardziej odpowiednim plikiem oprogramowania układowego (firmware) jest zazwyczaj:
7i92_G540x2D.bit
Moje pytanie czy to jest włąściwy plik i skąd go pobrać ?
  • Hakan
  • Hakan
23 Feb 2026 08:25
Homing on glass scale index is supported directly by Linuxcnc and Mesa's products.
linuxcnc.org/docs/html/config/ini-homing.html#_home_use_index but the whole page is worthwhile reading.
  • Hakan
  • Hakan
23 Feb 2026 08:22
Replied by Hakan on topic XHC WHB04B development?
Please specify what you mean by idle. Is this with LinuxCNC running or one of the other programs polling the pendant?
I saw the effect with no polling program. Didn't see it with one of the pollers active.
Idea was that sitting idle for some time made turning the wheel trigger something that disconnects it.
Didn't find that was the case though.
Hi Hannes, my unit displays the F: and S:, pressing Feed+ makes it display F:105 F:110 and so on. S: also show some values that change with press of S+ and S-. Seems to work.
Switched to libusb_fill_interrupt_transfer. I have a milling session today so I can at least tell if it still crashes.
I guess one can take out the original and solder in a new STM32G030C8T6? They are almost free.
What role does the dongle have? Is it passive or does it too have firmware?
  • ihavenofish
  • ihavenofish
23 Feb 2026 07:51
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
one more time again... :)
  • PCW
  • PCW's Avatar
22 Feb 2026 22:03
Category: Turning
The pin definitions are in the firmware.
In addition, the driver command line can enable/disable secondary functions.
(the primary function of all pins is GPIO)
That is, "sserial_port_0=2xxxxxxx" would only enable sserial channel 0 in mode 2
  • PCW
  • PCW's Avatar
22 Feb 2026 21:55 - 22 Feb 2026 21:55
Replied by PCW on topic 7i92T and mx3660 request for help
Category: PnCConf Wizard
If you get a red LED on the 7I92 when LinuxCNC is running, that indicates latency issues with the host PC
This does not require  a reset but the issue must be solved before you can have reliable operation
I would no bother with pncconfs tests, but simply run  your newly created configuration with LinuxCNC
To check network latency, run:
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
This will run for 1 minute then print timing statistics.
  • Studi
  • Studi's Avatar
22 Feb 2026 20:57
Mesa 7i96S step ausgangsignal =5V , Schrittmotortriber eingang 12V was nun?
Category: Deutsch
@ Tommylight Danke für das Anpassen!
Ich werde berichten wie es weiter geht, und hoffentlich welche Lösung wir gebaut haben.
Dies wird aber eine Weile dauern. Bitte um etwas Geduld.
  • m0602232
  • m0602232
22 Feb 2026 20:41
Hello
(Third try posting this, there's something wrong with the forum server)
I'm retrofitting a Cincinnati Arrow which does not have any kind of homing or limit switches on x and y -axis. Glass scales have distance coded index marks though and I would like to use them for homing. I found one successful attempt doing so:
forum.linuxcnc.org/12-milling/42195-retr...ing-success?start=50
Editing hm2 similarly shouldn't be too difficult but homing.c looks completely different nowadays. Should this kind of thing be done with homecomp? Any advice on that would be welcome, my coding skills are slightly limited and there is not too many examples of homecomp yet.
Ossi
22 Feb 2026 19:52
Category: Deutsch
Der Titel stimmt fast ganz nur das s ist mir entwischt.
Fixed, thank you.
22 Feb 2026 19:17
Request for Community Feedback on g-code++ (sterp) Integration with LinuxCNC
Category: Show Your Stuff
Thank you Franco,
Do you think it would be better to have this on a separate topic?
Either way, i have pinned this so it is easier to find, google has become utterly useless for searching anything if not very good at "google hacking".
22 Feb 2026 19:16
Replied by tommylight on topic Mesa 7i73 auf analog in + encoder mode stellen
Category: HAL
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=00200000 sserial_port_1=22222222"
Notice the 22222222 <<< 8x2, that will set all sserial ports to mode 2, this is what i do when i do not want to bother finding the right address.
Also notice sserial_port_1, if you have more than a single sserial port (each can have several boards attached)
The above example is from my Mazak with 7i92/7i77/7i74 and 2 of 7i84.
  • Finngineering
  • Finngineering
22 Feb 2026 19:14
Replied by Finngineering on topic XHC WHB04B development?
Welcome Hannes and thank you from my side for your contributions. I am fairly new here myself, and have made no "real" contributions to LinuxCNC so far.
If you read through this thread, you saw we discussed a "loops" variable. The changes you made to hal.cc should be another way of fixing that specific issue. As for the other changes, I haven't really used any of those features. And to be honest, I'm a bit confused about the modes (auto, MDI, manual, teleop, joint).
In other news, I have been slowly chipping away at making a new firmware for the dongle. As of right now, I have something that is mostly working. I will release the source code once I have it in a little bit better shape. But I don't think it will be of use to most people, as flashing a new firmware is likely a one way street, and may make the pendant unusable.
If you or somebody else wants to update the xhc-whb04b-6 component (more), there is some low hanging fruit:
The libusb_fill_bulk_transfer in:
github.com/LinuxCNC/linuxcnc/blob/master...whb04b-6/usb.cc#L457
should really be a libusb_fill_interrupt_transfer. Endpoint 1 is an interrupt endpoint after all. The dongle/pendant doesn't know the difference between bulk and interrupt, but for scheduling of traffic on the USB bus, there are some differences. It's not inconceivable that some of the disconnects could be from USB congestion and wrong transfer type, but I do think it's unlikely.
Another thing is the checksum calculation. The full formula is:
checksum = (~random + button1)^(~random | seed)
In the XHC implementation, the seed is the day of month [1...31] and "random" is from a timer in the microcontroller.
Displaying 6661 - 6675 out of 12559 results.
Time to create page: 0.607 seconds
