  • ihavenofish
  • ihavenofish
16 Feb 2026 00:26
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
www.minimonster.ca
Tarts for allll!!! :P
It's been an entertaining and frustrating journey to get to finally be able to sell these machines. Thanks to everyone that helped me with all my linuxCNC needs.
  • Hakan
  • Hakan
15 Feb 2026 23:39 - 16 Feb 2026 10:10
Replied by Hakan on topic XHC WHB04B development?
Thought a bit about this with disconnects/reconnects.
It is actually normal behavior and the component is designed to work with that.
In run(), that is the main loop, github.com/LinuxCNC/linuxcnc/blob/ffc393.../xhc-whb04b6.cc#L414
There is a loop that opens the device, processes and teardown usb, repeatedly.
The stop in setupAsyncTransfer() should not be fatal. The assert() statement makes it fatal.
I now remember my original issue I opened two? years ago, it was to remove assert() statements,
because I at that time found that the code does the right thing, in principle. Just that the asserts()
should be removed.
The call to setupAsyncTransfer tries to see if the usb device is connected with the mIsRunning flag,
but if I understand right (not necessarily) things change sometimes before libusb_submit_transfer().
github.com/LinuxCNC/linuxcnc/blob/ffc393...whb04b-6/usb.cc#L539
github.com/LinuxCNC/linuxcnc/blob/ffc393...whb04b-6/usb.cc#L456
I think now that the right thing to do is to have a failed libusb_submit_transfer() not crash the component through an assert() call
Instead finds it way in the call stack back to ::run() where the usb comm is torn down and the device is reconnected
and everything can continue.
  • PCW
  • PCW's Avatar
15 Feb 2026 21:40 - 15 Feb 2026 21:48
Replied by PCW on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Its hard to tell without a halscope plot that is scaled and timed so you can actually see the motion towards home
You might disable homing to index at least temporarily at that would simplify debugging
Are you sure there are no hardware connections that disable the drives when the home switch is reached?
Edit:
For HOME_FINAL_VELOCITY you might use  a low positive number since the PID is still not tuned
Also why are the X and Y limits covering a negative range? This is standard for Z but a bit odd for X and Y
  • Hakan
  • Hakan
15 Feb 2026 21:34
I'm interested to try it out.
Can there be different versions of the usb dongle firmware?
Like newer devices don't have the reconnect issue?
  • decor82
  • decor82
15 Feb 2026 21:25
Probe Basic Tool Setter touch off pos Y not set
Category: QtPyVCP
Thanks for your support! I updated everything again today and now probe basic 0.6.5 ist installed and in the sim the toolsetter position is now there for X and Y. Will test with my router and real config next week.
  • 5_Zylinder
  • 5_Zylinder
15 Feb 2026 20:57
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Why does the Z-axis then work exactly as it should?
The limit switch slowly moves onto the cam. It receives the signal.
The limit switch slowly moves away from the cam and reports that the axis is referenced.
Which value do you recommend for HOME_FINAL_VELOCITY?
  • PCW
  • PCW's Avatar
15 Feb 2026 20:42
Hurco BMC 30 AP
The commanded and fFB position are the correct ones to monitor
You might try rehoming after the first failed home so the actual motion towards home is visible
(uses a smaller scale)
I also note that HOME_FINAL_VELOCITY is 0 which as far as I can tell is not a legal value
  • endian
  • endian's Avatar
15 Feb 2026 20:35
IndraDrive + LinuxCNC – PDO configuration problems
Category: EtherCAT
Which kind of IndraDrive do you use?
some of them are SoE ... And it has have to startup IDNs
If you need EoE for something else at ethercat you can edit eeprom at drive... but I can recommend you to reisntall ethercat master with eoe disabling... it way easier path...
  • Finngineering
  • Finngineering
15 Feb 2026 20:34
Replied by Finngineering on topic XHC WHB04B development?
I tested now and get same behavior as you. This was some small news for me. I thought it only started reconnecting if it had already been in use already by LinuxCNC.
The test was like:
1. Pendant off, plug dongle into computer. No disconnects for 5 minutes.
2. Turn pendant on. Disconnects start with around 20 s cycle.
3. Turn pendant off. It looks like dongle stays disconnected. Maybe just bad/good luck with the timing.
I already made some first steps for a new driver. The initial target of that was to have reliable polling. I already abandoned it and started thinking more about the firmware. But maybe I should give it another shot. I'll try to have a look tomorrow if I can clean it up just slightly and post it here. It's simple enough to play around with and it should be able to provide stable polling.
  • 5_Zylinder
  • 5_Zylinder
15 Feb 2026 20:29
Hurco BMC 30 AP
The HAL and INI files are on page 6.
I can upload the HAL and INI files again tomorrow evening, but there are no changes in that area. Have I selected the correct channels for logging?
  • Lcvette
  • Lcvette's Avatar
15 Feb 2026 20:18
Replied by Lcvette on topic Some problems with probe basic lathe
Category: QtPyVCP
I’ve tried changing the field names in Turning using Qt Designer so they match the macros, but without success. I’m not exactly sure if what I tried makes any sense, since I don’t have experience with this.I’ve looked at the files in the link, but are they for Probe Basic Mill? This is a bit beyond me because I don’t really have the necessary knowledge…I also saw a post on the Facebook page about an update to the lathe conversational section. Does anyone know when that update will be released?
it will be a while and that is not a "probe basic" item it is actually a universal machine conversational that will also be able to be added in as an external plugin to probe basic. its a ways out as i have limited time to work on it lately.
  • Lcvette
  • Lcvette's Avatar
15 Feb 2026 20:16
Category: QtPyVCP
dont change the ui names, modify the macros otherwise on an update you will be overwritten while macros in your config folder for machine are not
  • Hakan
  • Hakan
15 Feb 2026 20:04
If you just have the dongle and pendant attached and switched on do you get resets every 20 sec?
I mean, without linuxcnc.
I took the dongle and pendant to a bit newer N150 PC. Plugged it in. Ok, was discovered.
Switched on the pendant and it started with the 20 sec disconnects/reconnects.
Switched off the pendant with the button and it stopped. There is a clear relation.
It can be related to polling, I guess.
Searched for a simple program to regularly poll a usb device.
Best I found was "usbreset" but it didn't change anything.
Interesting that you MRx says it is stable. Advice was to test with USB 2.0 and I have looked
and it isn't easy to find a PCI-E USB 2.0 board I can get in a few days. My motherboard
Gigabyte Z170N-WIFI does have an internal header for USB 2.0/1.1 and I should get a cable
and test I guess.
  • PCW
  • PCW's Avatar
15 Feb 2026 20:02
Hurco BMC 30 AP
Unfortunately neither plot shows any motion so it hard to tell what's going on.
Can you post your current hal/ini files?
  • 5_Zylinder
  • 5_Zylinder
15 Feb 2026 19:44 - 15 Feb 2026 19:47
Hurco BMC 30 AP
Hello everyone,
Today I recorded data from the Z-axis, which is functioning correctly, and then I tested the X-axis.
The X-axis limit switch moves onto the cam and then simply stops instead of moving freely.
After a few seconds, the following error message appears: joint 0 following error
Displaying 6931 - 6945 out of 12579 results.
Time to create page: 0.427 seconds
