  • snowgoer540
  • snowgoer540's Avatar
20 Sep 2026 15:34
Replied by snowgoer540 on topic Bug on new Install
Bug on new Install
Category: Plasmac
Yea, I think that our reliance on random folk who come and go to provide builds people rely on is a bit short sighted, perhaps one of the worst aspects of this project. I'd say it's one of the downfalls of "open source", but plenty of other open source projects seem to have it figured out. Who knows, but it's why I just advocate for learning how to build them yourself.
At any rate, I'm glad to hear all is well again! Sorry for any inconvenience I caused. Happy cutting!
  • tuxcnc
  • tuxcnc
20 Sep 2026 14:28
New User Lichuan CL3 57E and Stepper Online A6 - Problems
Category: EtherCAT
I had a similar problem (no errors displayed, only the motors did not want to turn).
I solved it by writing xml for one drive and when it started working, I connected the second one and added it to xml, and that way to the end.
I noticed that Ethercat in Linuxcnc is also sensitive to the order of entries, i.e. it may not work even if everything is fine, but incorrectly arranged...
  • BreadMonkey
  • BreadMonkey
20 Sep 2026 09:38
Category: EtherCAT
Hi mwc,
Thank you for your help... The motors are energizing now, not moving but I am now where I wanted to be at 3 days ago. Thank you!
My ethercat_conf.xml was generated using the lece_configgen command. It looked correct... but nothing in the motor controller area was correct. I would have been better off using the instructions from the ethercat github page and just searching the forum here.
Funny how both the Lichuan driver and the Stepperonline A6 drivers use the same code. They probably use the same (or from the same source) firmware.
  • rodw
  • rodw's Avatar
20 Sep 2026 09:02
Replied by tommylight on topic Looking for a super small Linux-Version?
Category: Installing LinuxCNC
I really don't understand why you write such things.Out of boredom and curiosity,
I recently tried to install CoolCNC, so I know what it real looks like.
Apart from the fact that EMC2 from 2005 bears little resemblance to LinuxCNC from 2026, it is practically impossible to install it on a modern computer, because the creators of kernel 2.4 were not clairvoyant and did not even foresee such inventions as SATA or a USB keyboard/mouse.
Really ?????
  • tuxcnc
  • tuxcnc
20 Sep 2026 07:20
Replied by tuxcnc on topic 2HSS86 Hybrid Servo Driver wiring
These are the pins of the optocoupler output transistors and they can be connected quite freely, as long as something limits the current to a safe value.
You can connect the "-" outputs to ground and the "+" outputs to the inputs that respond to a short circuit to ground, or connect the "+" outputs to the plus of the power supply (no more than 24V) and the "-" outputs to the inputs that respond to positive voltage.
Additionally, these outputs can be connected both in series and in parallel.
For example, the outputs of several ALM controllers in parallel (activation of any one will change the state) and PEND in series (activation of all of them will change the state).
  • tuxcnc
  • tuxcnc
20 Sep 2026 07:00 - 20 Sep 2026 07:06
Replied by tuxcnc on topic Looking for a super small Linux-Version?
  • aabtech
  • aabtech's Avatar
20 Sep 2026 05:12
2HSS86 Hybrid Servo Driver wiring was created by aabtech
  on 7i96 where should I wire the in position signal output and alarm signal output from the 2HSS86 Hybrid Servo Driver
  • caretech
  • caretech's Avatar
20 Sep 2026 01:09 - 20 Sep 2026 01:10
Replied by caretech on topic Bug on new Install
Bug on new Install
Category: Plasmac
Yes, thank you! I should have come back here to report this as solved.
Even after waiting for a few days, upgrading LinuxCNC via the package manager still kept us on QtPlasmaC version ending in 84. Not sure what's up with the buildbot. So I set up a Debian VM here and built a deb from source to install on cutnweld's table. The QtPlasmaC version now ends with 88 and the pause issue is resolved. Thanks again for an awesome plasma control interface.
  • snowgoer540
20 Sep 2026 01:00
Bug on new Install
Category: Plasmac
Following up, how did this go? Is the issue solved?
19 Sep 2026 23:38
Is there a super-minimal LinuxCNC installation available?
-CoolCNC 50MB ISO
-Debian Dog 350MB ISO
-Ubuntu 10.04 700MB ISO
All are still usable and functional, all can still be downloaded, and all can run machines just fine, except EtherNET Mesa cards.
You can download and install ANY distro that is derivative of Debian and install LinuxCNC on it, from the latest Debian Pup, to several other "lite" distros that i would not consider lite at all.
Almost all of them will work in Live mode, so download, boot, test, and if you like it install it and LinuxCNC with:
sudo apt update
sudo apt install linuxcnc-uspace
  • mwc
  • mwc
19 Sep 2026 21:13 - 19 Sep 2026 21:13
Category: EtherCAT
Have a look at my ethercat xml for those drives, as I have nothing in the SyncManager 0 and 1 idx.
I did have an xml reading the drive digital inputs, which I'm sure was in the 2 and 3 idx, but I'm not sure where I saved it, and I've still not got as far as adding them to my current test setup.
You probably want to start simpler with just the enabling/motion
  • rodw
  • rodw's Avatar
19 Sep 2026 21:02
Replied by rodw on topic Looking for a super small Linux-Version?
Strange, LibreOffice is excluded from the Debian Live-build ISO we create
github.com/LinuxCNC/linuxcnc-live-build/...e-lists/desktop.list
I don't know of any games installed.
  • Aciera
  • Aciera's Avatar
19 Sep 2026 19:43
Replied by Aciera on topic looks like a bug in linuxcnc?
Could you point out where these files are in linuxcnc or how you have come across them?
  • tuxcnc
  • tuxcnc
19 Sep 2026 19:20
You can do as follows:
1. Download the Debian 13 installer.
2. During installation, deselect all window managers so that the system installs in text mode.
3. Do apt install xfce4-desktop linux-image-rt-amd64 linuxcnc (I'm writing from memory, maybe it needs to be done a little differently).
The system installed in this way will fit on an 8 GB disk.
It won't be comfortable to use, but LinuxCNC will work properly.
Displaying 781 - 795 out of 11520 results.
Time to create page: 0.397 seconds
