  • PCW
  • PCW's Avatar
29 Dec 2025 20:17
Linuxcnc 2.9.7 - Mesa 5i25 with HKD 5 AXIS MACH3 STEPPER I/FACE and 5i25_5ABOBx2
Category: Driver Boards
Did you verify that  the BOB has 5V power?
It needs both 5 and 12V power for operation,
5V for the step/dir outputs and 12V for the analog out and digital inputs
  • Cooped-Up
  • Cooped-Up
29 Dec 2025 20:14
Escalation of a Maho MH400E Retrofit (LinuxCNC + EtherCAT)
Category: Milling Machines
this is awesome. I am currently nearing the finish line on a MH800e retrofit. i used mesa cards and followed in the footsteps of rotarysmp and his documentation. this was a huge boost in feasibility as he had already done it. As the machine currently sits I could run a program but shift gears manually as I am still integrating auto shifting into the mix.
what issues did you have with the indramat?
  • automata
  • automata
29 Dec 2025 19:27
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Hi Hakan,
I have been able to wedge the double domain stuff into lcec_main.c and got a single yaskawa drive working with lcec_generic
For now I have made the double domain an option for the master. But I still need to check how to make it work only for yaskawa slave without affecting the other non-yaskawa slaves.
I'll try to wiggle that option into only the needed syncmanager or the required pdos.
Unlike fdarling, I did not need to disable fsoe part. So that part is good.
Will post more updates towards the end of the week.
-automata
  • Ozcnc
  • Ozcnc
  • Robin123
  • Robin123
29 Dec 2025 18:46
7i97t Mesaflash Problem was created by Robin123
Hallo zusammen,
vorab ich bin absoluter anfänger mit Linux.
Habe eine alte Fräsmaschine auf eine Mesa 7i97t umgebaut und durch dieses Forum etc. Alles soweit zum laufen gebracht.
Das ursprüngliche Problem war das ich die Analog Outputs für die Endstufen nicht steuern konnte.
Meine Vermutung --> falsche Firmware auf der Mesa.
Habe versucht die richtige zu laden, funktionierte nicht. Es kam immer eine meldung das es nicht bekannt war oder so ähnlich.
Meine Vermutung  --> zu alte mesaflash version.
Habe dann versucht die neue Version zu laden, da bei jemand anderen hier im Forum es mit 3.5.10 funktioniert hat.
Dann war git nicht mehr da und so weiter .... habe nach vielen vielen Stunden git und alles andere wieder soweit ich beurteilen kann drauf.
Habe nun das aktuelle Mesaflash paket.
mit dem befehl -make in dem Ordner kommt aber die Meldung: pkg-config can't find libpci
Wenn ich nun Versuche dies zu installieren, kommt die Meldung das cvs, perl-dbdabi-94, perlapi-5.32.0 und libc6 >=2.38 fehlen. (libc6 2.36-9 ist installiert) ....
Ich komme dort irgendwie nicht weiter.
Es kann sehr gut sein das ich einiges falsch gemacht habe, kann das leider absolut nicht einschätzen.
Ich bin für jegliche Hilfe sehr Dankbar!
Habe Linuxcnc 2.8, debian 12
Danke!
  • MaHa
  • MaHa
29 Dec 2025 18:24
Replied by MaHa on topic Disable pushbutton
Disable pushbutton
Category: Flex GUI
That was easy to do, and it works exactly as desired. It is important for me to lock out this kind of potential risks.
Thank you for providing this information.
  • workshop54
  • workshop54
29 Dec 2025 18:03
Hi all,
I've been working on a design for the control cabinet of my Maho MH400E.
I initially planned a relatively simple retrofit using Mesa cards, but after running into issues with the servo motors and spending quite some time trying to understand what was going wrong, the scope of the project gradually grew.
Along the way I ran into a few challenges:
  1. I'm not an electrical engineer, so there was (and still is) a lot to learn.
  2. Cost: this kind of hardware isn't cheap. Given the scope of the project, I deliberately chose components from vendors with strong documentation and long-term availability, to reduce risk during commissioning and future maintenance.
  3. Time — or perhaps more accurately: patience.
After some frustrating attempts with QElectroTech, I ended up using SolidWorks Electrical. It certainly wasn't trivial either, but I do think it pays off in terms of built-in consistency, cross-references between components and wiring, and the ability to generate reports directly from the design.
This isn't meant as an endorsement, just my personal experience.
At this point the SWE license has expired and I want to move on to the actual build, once the remaining mechanical designs (servo motor mounts in particular) are finished.
Given my limited experience, I'm reasonably happy with the result so far, while fully expecting that there are still issues and blind spots.
What I ended up with:
  1. An EtherCAT-based setup using Beckhoff I/O modules
  2. Delta servo drives and a VFD with EtherCAT support
  3. Replacing the original Heidenhain 1 Vpp → TTL encoder cards with Beckhoff 1 Vpp encoder modules
  4. Schneider Electric and Phoenix Contact components for relays, power supplies, circuit breakers, etc.
  5. Reuse of the original 400 V → 110 V transformer, the cabinet itself (with heat exchanger), the hydraulics pump and the lubrication pump
Still TODO (design-wise):
  1. Control cabinet layout
  2. Mechanical design for the servo motor mounts
At this stage I'm mainly looking for a sanity check on the overall architecture and safety-related choices. If anyone with experience in industrial control cabinets or LinuxCNC + EtherCAT setups would be willing to point out potential blind spots or "this will bite you later" issues, I'd really appreciate that.
I'm not looking to optimize for cost or replace major components at this point, but I am very interested in feedback on correctness, robustness, and failure modes — especially regarding EtherCAT behavior under LinuxCNC.
Due to forum size limits the attached PDF is a flattened version without internal cross-references. I do have a fully cross-referenced version available and can share it privately if someone wants to take a deeper look.
  • Hakan
  • Hakan
29 Dec 2025 17:28 - 29 Dec 2025 17:39
Category: EtherCAT
The problem is most likely related to the issue with  LWR and LRD/LRW modes that was discussed earlier.
You must at least get that fixed before you can rely on that error message.
automata has a solution. You cannot run lcec with those drives. automata attached
the code for another component to use with the Yaskawa drive.
attached as C file with a Makefile. Download and compile the code.
Use it as a component in hal.
I know it can be a handful to do this, I would foresee some experimentation to get this right.
Edit: I looked in the code and that isn't a ready-to-use component.
There is a lot of work needed to get this to work.
Frankly tar_san, I understood you have the drives on lone for evaluation, right?
Do yourself a favor and return them and get some other servo drives.
I can not spend that much time in getting this going. Hopefully someone else can.
  • Crusader2050
  • Crusader2050
29 Dec 2025 16:40
Replied by Crusader2050 on topic Retrofitting a 1986 Maho MH400E
from what I've been able to figure out from the drawings and manual provided and in the video, the "voltage fault lamp" on the Indramat seems to indicate an internal problem with the -15v/0v/+15v supply..
check the voltages on the relevant pins on the L6 connector.. ( might be one to scope )
the X axis doesn't seem to be causing an issue? but the Z and sometimes the Y axis trip out?
from the drawings that might be one or more brakes not releasing? as that appears to be linked through 19K2?
without the full schematic I'm guessing at the function of some of the contacts shown on what we do have.
  • PCW
  • PCW's Avatar
29 Dec 2025 16:20
Do you have a link to the manual for the HKD breakout?
Also make sure you do not have cable power enabled on the 5I25.
  • andrax
  • andrax's Avatar
29 Dec 2025 15:42 - 30 Dec 2025 17:04
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Please excuse me for asking more questions.
The following parameters for homing are specified in Collin Bardini's .ini file.
HOME_SEARCH_VEL            = 15.625
HOME_LATCH_VEL            = 15.625
HOME_IGNORE_LIMITS        = YES
CIA402_HOMING_ENABLED = 1
CIA402_HOMING_METHOD=-2
CIA402_HOMING_SEARCH_VELOCITY=20000
CIA402_HOMING_LATCH_VELOCITY=7000
CIA402_HOMING_ACCELERATION=131072
Which of the two parameters determines the homing speed and acceleration?
If the parameters are valid for CIA402, what units are they?
EDIT:
I figured it out. It's the lower values.
However, I still don't know what the units are.
Now I have an additional problem, though.
After completing the homing movement, the axes jump 1-2 mm and go into fault mode. The error can be acknowledged and the axis is referenced.
In the ini file, I have set HOME_OFFSET = 0.0 for the axes.
Where is my mistake?
Thank you in advance.
  • PCW
  • PCW's Avatar
29 Dec 2025 15:41
LinuxCNC + Mesa 7i43 – Axis A stepper (stepgen), error
Category: HAL
7I43 SVST4_4 pinout  (created with mesaflash) is:
File Name: SVST4_4.TXT
File Size:5 KB
  • Crusader2050
  • Crusader2050
29 Dec 2025 15:32
I'm not a Linuxcnc guy, however I do make and fault find control panels for lots of different machines..
is there a possibility of you posting the complete wiring schematic for the control panel? It may be something entirely seemingly unrelated is causing the problem.
Displaying 9151 - 9165 out of 12675 results.
Time to create page: 0.670 seconds
