  • spumco
  • spumco
10 Sep 2026 02:26
(Solved) Probe Basic - HAL pins not being created
Category: QtPyVCP
there is no 3 states only on off because you only have on and off hal output and this can only use a single hal reader
That's a StatusLabel connected to the status channel, not a hal bit pin.  And the logic is in the user_button.py file.
just an fyi why are you destroying the format and look of the ui.. your better than that!
I thought I was keeping the look quite true to your original.  Same background colors, container shapes, borders, padding, etc for everything but the DRO.  I wanted a bigger display for the main DRO and had the real estate.  I even used the exact same halbar color scheme for the axis load indicators as you did on the spindle load bar.
As for format, I've mentioned a number of times (in other threads) I don't want/like any controls in the user interface that can cause physical machine movement.  If I could get rid of the cycle start/stop buttons, jog panel, go-to-home/zero buttons I would... but those are in the base probe_basic.ui files I cant touch without going way off the reservation.
I understand having on-screen control buttons for the ATC and probing - those are just too convenient and would take up a massive number of physical inputs to replicate.
My physical control panel has all the 'standard' controls I need for routine machine operations: start/stop/feed-hold, jog, FRO/SRO/JRO/RRO, spindle control, flood/mist/blast/wash, plus man/mdi/auto mode and a home-all button plus a few undesignated spares.  I like tactile controls and think touchscreens are dangerous... same opinion about modern cars, in fact.
So my compromise is to accept what's in the base ui, but change everything I can to indicators vs. buttons/controls. And get rid of the 'danger' buttons (DRO auto-zero HAD to go).  Your somewhat-recent modification to permit keyboard jog disable was a huge win in my book!
I just pushed the changes to qtpyvcp for the halbutton flash option property in qtdesigner
You rock.  I'll have a go at it tomorrow evening and report back.
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 02:03
Category: QtPyVCP
here is the flashing stylesheet code:
QPushButton {
    color: white;
    border-color: black;
    border-style: solid;
    border-radius: 5px;
    border-width: 1px;
    background: rgb(0, 255, 133);
    font-family: "Probe Basic Bebas Mono";
    font-size: 15pt;
QPushButton:checked[flashState="true"] {
    background: red;
    color: white;
QPushButton:checked[flashState="false"] {
    background: yellow;
    color: black;
QPushButton:disabled {
    color: white;
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 01:57
Category: QtPyVCP
I just pushed the changes to qtpyvcp for the halbutton flash option property in qtdesigner. it will take it about 20 minutes to build and be available via apt, once you see it pop up in sudo apt update you will have the functionality you can adjust the stylesheet to give you whatever colors you want for the checked state flash primary and secondary colors!
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 01:51
Category: QtPyVCP
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 01:50
Category: QtPyVCP
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 01:48
Category: QtPyVCP
and i am adding a flashing property to button widgets because thats a good idea..
  • spumco
  • spumco
10 Sep 2026 01:45
Category: QtPyVCP
That's really slick!
Any thoughts on the three-state label I mentioned?
PAUSED state is blinking.
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 01:29 - 10 Sep 2026 01:33
Category: QtPyVCP
ok yeah this is what you want to do it is much cleaner with no code changes to hack it up, this is existing hal code and the button itself is none functional in the ui essentially becomes a label, you cannot click it or select it or do anything bu observe it physically.
you then just add your net in postgui.hal file and your off to the races!
here is the stylesheet used:
QPushButton {
    color: white;
    border-radius: 5px;
    border-width: 1px;
    background: green;
    font-size: 15pt;
QPushButton:checked {
    background: red;
and for reference here is the simple net to the hal test_button:
# *** Probe graphic simulation trigger push probe tip ***
net probe-in  =>  qtpyvcp.probe-in.out
net probe-in  <=  qtpyvcp.probe-led.on
net probe-in  =>  qtpyvcp.test_button.check
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 01:19
Category: QtPyVCP
doesn't have to be, you can give it no focus, im tinklering with it now just about have it and it is pretty easy with no code changes and making more of them would be way faster and not require code changes for each instance
  • spumco
  • spumco
10 Sep 2026 00:51
Category: QtPyVCP
Ok I see now, did you try just using a halbutton? If you just wanted color change I think that would work and be simple. Have to check, but I believe they are bidirectional.
No, it didn't occur to me to use a button as an indicator.  And I didn't want an on-screen button or control widget.
  • Lcvette
  • Lcvette's Avatar
10 Sep 2026 00:42 - 10 Sep 2026 00:43
Category: QtPyVCP
  • spumco
  • spumco
10 Sep 2026 00:34
Category: QtPyVCP
As I said earlier, the LED was just a first attempt.  When that didn't work out, I realized a label that acted like an LED could do double-duty and save screen space.
Just so we're on the same page, here are two screenshots of what I've got after Claude created new .py and .qss files
The red one is actually blinking, but you get the idea.
I'm not completely sure about the architecture, but it looks like that python file creates two hal pins per Qlabel instance.  And links the label to a .qss setting via the standard Qt Qlabel's dynamic settings.  Screenshot of the dynamic properties:
The rest of the indicators follow the same process.  Two hal pins are created per label, I link one of the pins in post-gui, set the dynamic properties to a color, and they all work.
I've attached the files in case you're interested in what's backstage.  And I think the status_tab.py was also modified - and is what I'm not supposed to touch (auto-updated when probe_basic.ui is open).
The above is what I was trying to do with HalLabel widget rules, but couldn't.
  • rodw
  • rodw's Avatar
10 Sep 2026 00:03
Replied by rodw on topic Looking for opinions on controller box
Category: Plasma & Laser
I agree with Tommy. Pointless adding additional failure points!
I would try and arrange the drives horizontallly as there is a risk the top drives overheat with the heat from the ones below. I have had this happen but at a lot more than 24 volts (which I think is too low, velocity and acceleration are king with plasma and you are limiting yours by the low voltage)
  • Lcvette
  • Lcvette's Avatar
09 Sep 2026 23:43
Category: QtPyVCP
for reference here are the already linuxcnc exposed status items:
linuxcnc.org/docs/html/config/python-interface.html
  • Lcvette
  • Lcvette's Avatar
09 Sep 2026 23:41
Category: QtPyVCP
you want the label now and not the led? the led you simply set the pin base name and then point to it in hal in the post gui hal file and when the net is active it will light up the led.
halLabels are for numerical values, not strings. there is not a really clean method to access the hal io layer digitally with strings. this is just a linuxcnc shortcoming, they expose certain things through python and they are determined through the linuxcnc repo and not qtpyvcp/probe basic. so if you need a status or setting that is in that python channel its easy if its a customized halpin not so much unless its something very basic like toggling a switch for an led or outputting an actual numerical value since that coding is present in the linuxcnc codebase.
you can get around this a few ways, the first being to make a hallabel that would display a value and make your other changable label display certain text based on that hallabel's current value: for example,
1 = air pressure LOW
2 = air pressure OK
its a bit hacky so you will need to determine if the hackiness is ok to achieve your goal, or maybe just use the led.
I can look at giving the user a default state color style for the halledindicator which could give you the ability to make it green default and red active.
Displaying 991 - 1005 out of 11521 results.
Time to create page: 2.220 seconds
