  • PCW
  • PCW's Avatar
10 Sep 2025 14:04
HAL help needed for MPG wheel jogging and machine enabling logic
Category: HAL
A voltmeter will do, you just need to jog the MPG
so you can measure the high and low states.
  • LinuxCrashOut
  • LinuxCrashOut's Avatar
10 Sep 2025 13:59
Category: HAL
I guess I am going to need an oscilloscope?
  • PCW
  • PCW's Avatar
10 Sep 2025 13:55
Category: HAL
I would check the swing of the A,B MPG signals, relative to ground.
The input threshold is about 2.5V with ~20% hysteresis so needs a good
say 4V swing to work reliably.
  • unknown
  • unknown
10 Sep 2025 13:49
Replied by unknown on topic RPi 4B - Network File Share - nfs
Thanks mate, must have been posting at the same time.
Anyways I've added this thread to the RPi Index thread under Linuxcnc General Questions.
  • cmorley
  • cmorley
10 Sep 2025 13:04
Replied by cmorley on topic gladeVCP not calling python handlers
Category: GladeVCP
The 'def get_handlers(halcomp,builder,useropts):' function has the wrong indent.
It should have no indent just like the class definition.
  • Unlogic
  • Unlogic
10 Sep 2025 12:26
Probing routines changing mode from G90 to G91
Category: QtPyVCP
I've noticed that some probing routines in Probe Basic change the distance mode from G90 (absolute) to relative (G91). Took me while to figure this out
Some routines do it only when there is an error during problem while a few others always leave the machine in G91 even after successful probing.
Is this by design or is it something that should be looked into?
  • LinuxCrashOut
  • scsmith1451
  • scsmith1451's Avatar
10 Sep 2025 11:03
gladeVCP not calling python handlers was created by scsmith1451
Category: GladeVCP
I have been struggling to understand why my gvcp handlers are not being called. I'm running LCNC 2.9.4. Maybe I don't have syntax correct or missing a configuration item. I've attached my .ui and .py files for reference. Would someone please provide guidance?
Kind Regards,
  • ziggi
  • ziggi's Avatar
10 Sep 2025 10:22
Troubles to get started with SD240 Retrofit
Category: Turning
I think I found most settings in linuxcnc.org/docs/html/examples/spindle.html
Lets see how far I get.
Only thing is that my encoder is a 2000 pulse encoder and in the example its a 100pulse per rev. encoder. We wills see...
  • Retrofit
  • Retrofit
10 Sep 2025 10:03
Carousel don t stop when estop is pushed
Category: QtPyVCP
  Hello to everybody
I retrofited two mills , one is complet functional , it work fine , Cincinna Milacro , and other one it is on demand , Leadwell VMC40.
The first is with 7i92+7177+7i84 Mesa Cards , and the second with cards from Yurtaev.com (mithsubishi) , pci card.
On the second mill , when I try to configurate the carousel for homing ,carousel  starts moving , but when I push the estop  to stop the rotate ,  don t stop !, even from desktop estop or power btn . So, I try this for the first one mill to check it ,and ,  unfortunately is the same issue.
The same is when M6 Txx  is requared from MDI , don t stop when estop is pushed , on both of mills.
The carousel have geneva mechanism , both of them with home pin and index pin .The configuration is from examples that are in Probe basic files(M13)
Any advice for eliminate the issue ?
Thanx in advance
  • hitchhiker
  • hitchhiker
10 Sep 2025 09:55
Replied by hitchhiker on topic Proximity sensor hardware debounce?
Category: Basic Configuration
On the bench it works.
Important is to know that the signal is inverted.
Option 1 use a second schmittriger to re invert. As example.. from 1Y to 2A and from 2Y to motion card.
Option 2 change signal in hal from in to in_not.
  • Unlogic
  • Unlogic
10 Sep 2025 07:54
Replied by Unlogic on topic Optimum Optimill MH50V CNC conversion
Category: Milling Machines
This is not really LinuxCNC related but something I should have done years ago, 3D-printed T-slot covers. It makes it much easier to vacuum up all the chips of the table.
It took three iterations to get the profile right, here are the test pieces I went through.
Here is the complete set that I installed.
They are printed out of flexible TPU filament and took about 4,5 hours to print on a Bambulab P1S printer.
  • ziggi
  • ziggi's Avatar
10 Sep 2025 07:32 - 10 Sep 2025 07:36
Category: Turning
The 7I33 can just ..., not pin-by-pin as most newer Mesa cards can do.
Is there a better alternative to the 7i33- just in case?
How can I get the spindle indexed?  Setup at the spindle is different- the motor encoder (G5) is just wired to the amplifier and not accessible for me, but a second encoder for threading (G2) is driven by the spindle via a toothed belt (1:1)
Signals for G2 are similar to the axes encoder signals, Ua1/Ua1*, Ua2/Ua2* and the index Ua0 single (non differential)
Mechanical Setup:
Wiring of G2:
I have the spindle running with G2 as a feedback- this works fine but I will need the index for threading.
How can I manage this?   I tried to make the index visible in HAL Scope, but can not set the "index enable" (get an error message)
The encoder G2 is connected to the 7i33 as ENC02, as said works fine for spindle feedback so far.
Sigi
  • meister
  • meister
10 Sep 2025 07:26 - 10 Sep 2025 07:31
# The Step signal for my machine is inverted. I tried to remove the inversion from the step signal, but than the Stepper don´t move at all. Does that make sense??
please check your Opto-Outputs, perhaps they are too slow for the short pulses. ?!?!
EDIT: and please add you config
Displaying 10051 - 10065 out of 17033 results.
Time to create page: 2.766 seconds
