  • GDTH
  • GDTH's Avatar
01 Sep 2025 06:27
Solved: Help with Busellato JET 2 spindle retrofit – VFD overload
Category: Driver Boards
Yesterday I tried running the VFD with a potentiometer, but had no luck. I experimented by slowly adjusting the frequency and changing some basic parameters to see if I could get any results. The only thing that seemed to have some effect was changing the V/f pattern.
  • GDTH
  • GDTH's Avatar
01 Sep 2025 06:24
Solved: Bitfile needed for 6i25 + 7i77 + Chinese BoB
Thanks! i got it running. i was able control the pins. Weirldy enough i was not able to get the stepgen running. i was not able to see anything on the oscilloscope. i did not plug the 12/24v as i thought it is not needed. I was able to pull both the dir and pulse pin high by inverting it.
Any tips are appreciated, gonna continue working on it tommorow
  • PCW
  • PCW's Avatar
01 Sep 2025 04:39
Replied by PCW on topic Problems with starting linuxcnc
The /DONE LED (CR7) lighting means a power cycle.
This suggests an issue with 5V power.
  • arijitdutta
  • arijitdutta
01 Sep 2025 03:54 - 01 Sep 2025 03:56
Problems with starting linuxcnc was created by arijitdutta
So i have been running 7i96s with my lathe for around a year now. It is running without any issues till a couple of days ago. I never do any kind of changes to hal or anything. I have been getting this error so much that it is almost unusable now. Upon starting the interface, 80% of the time, it ends up with an error. I have attached the debug file report for reference. 20% of the time it runs but within 5-10 minutes it shows "error finishing read iter = 957938" even during operations suddenly. I pinged my card and ran it for sometime, and saw some packet losses for reasons I dont know. Attached a picture for that too.When i startup, the PWR led stays on, others off. The cr6 and  cr7 blinks in turns sometimes during the error and when the packet loss happens and it doesnt turn off after that. Debug as follows:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.3
Machine configuration directory is '/home/arijitdutta/linuxcnc/configs/lathe'
Machine configuration file is 'lathe.ini'
INIFILE=/home/arijitdutta/linuxcnc/configs/lathe/lathe.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XZ
KINEMATICS=trivkins coordinates=XZ
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Found file(REL): ./lathe.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:88:df
hm2_eth: discovered 7I96S
hm2/hm2_7i96s.0: Low Level init 0.15
hm2/hm2_7i96s.0: Smart Serial Firmware Version 43
board fails HM2 registration
hm2_eth: in hm2_eth_reset
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./lathe.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./lathe.hal:9: /usr/bin/rtapi_app exited without becoming ready
./lathe.hal:9: insmod for hm2_eth failed, returned -1
7688
Stopping realtime threads
Unloading hal components
  • PCW
  • PCW's Avatar
01 Sep 2025 03:40
Neuling mit MESA 7i97T sucht Leidensgenossen zum Erfahrungsaustausch
First, you should not actually need mesaflash as the pre-installed firmware on the 7I97T
should work as-is for normal analog drive setups.
You do need a recent LinuxCNC to recognize the 7I97T
In addition, you will likely need to install MesaCT to setup the initial configuration files
as pncconf does not yet support the 7I97/7I97T
There is also a basic configuration file example for the 7I97/7I97T here:
File Name: basic7i97_...8-31.zip
File Size:4 KB
  • johns00056
  • johns00056
01 Sep 2025 00:14
Replied by johns00056 on topic installing an older version
Category: Installing LinuxCNC
Thanks for the kind offer. I made good progress , today, on upgrading it by hand.
I think that it is pretty close to running.
It is a hand written configuration so I am not surprised that the script did not work.
  • Waldemar
  • Waldemar's Avatar
31 Aug 2025 23:41
Replied by Waldemar on topic Simple/Manual Centre Finder
Category: AXIS
Nice work. Yeah, I'm on Axis - 2.8.4 although I'd be happy to hear about your method to set this up.
Have spent a few hours going around in circles trying to get Chat GPT to point me in the right direction. Managed to get a custom tab set up but that's about it - buttons proved problematic for one reason or another. I'll probably wait until I upgrade to 2.9 to try again but that might be a while. Spreadsheet for now..!
*Not my formulas - I found 'em squirrelled away on a Microsoft forum page.
  • Paul01
  • Paul01's Avatar
31 Aug 2025 23:31 - 31 Aug 2025 23:32
Replied by Paul01 on topic Multi Axis Slow Feedrate
Thanks Andy. The single-line lookahead is the conclusion I've come to also.
Any advice on where to go from here?
Is there an alternative trajectory planner that could be better suited for multi axis? Is PathPilot an option, and can it be modified for more that 4 axes? What would it take to merge the Tormach TP into LinuxCNC? Or is there something other than LinuxCNC that would be better for simultaneous multi axis machining?
  • JohnnyCNC
  • JohnnyCNC's Avatar
31 Aug 2025 22:15
Questions about "Auto Zero" in QT_Dragon_HD probe tab.
How can I make the "Auto Zero" button default to ON?  ON a few occasions where I have not used my machine for a couple of months, I forget to set Auto Zero to ON, and then go down a rabbit hole trying to figure out why my machine is not cutting at the correct Z height.
What is the use-case when you would want Auto Zero to be OFF?
  • MarkoPolo
  • MarkoPolo
31 Aug 2025 22:07
Replied by MarkoPolo on topic Simple/Manual Centre Finder
Category: AXIS
I used your formulas for calculating the center of a circle and created a widget for qtdragon that does it.
(There's also a Python function that calculates the center from three coordinates.)
You're using axis, so it probably won't be useful to you.
  • vicstransam
  • vicstransam
31 Aug 2025 22:01
Replied by vicstransam on topic Simple G-Code Generator
Category: CAD CAM
I may also try to run the script in terminal and see what I can find out.
  • vicstransam
  • vicstransam
31 Aug 2025 21:43
Category: CAD CAM
It is an assumption. I click on "Write to Axis" and I notice that Axis says "filtering" at the bottom right but nothing is received. I then exit the py script gui after a few minutes of waiting for it to post code and that's when axis gives the message about the % sign or M2. It could be it never got anything.
I may change the "sys.stdout.write" to create a file instead and see if it post.
There may be something else in the py script that hangs it up. These scripts all ran fine on the python version that comes with Wheezy on my other machine but they don't like Python 3 and using 2to3 doesn't fix everything.
  • xunil
  • xunil
31 Aug 2025 21:34
Replied by xunil on topic halui.mdi-command-NN pins not showing up
Category: HAL
Not sure this will shed any more light, but I've attached the output from starting LinuxCNC on my actual machine.  I get that 'halui exited without becoming ready' message too.  One other thing I noticed is that the initial messages about kinematics has "coordinates:AZ" but later on the jog order is "ZA".  Is there some requirement that the first axis be linear?  I don't think it would hurt anything for my machine to reorder things so joint 0 was linear and joint 1 was angular.  Just kind of fumbling in the dark here for ideas.
File Name: linuxcnc-o...8-31.txt
File Size:5 KB
  • ziggi
  • ziggi's Avatar
31 Aug 2025 20:42 - 31 Aug 2025 20:45
Troubles to get started with SD240 Retrofit
Category: Turning
No, no real help - but we found the error:
Wrong is the term VELOCITY - needs to be VEL thats all, then it works
so
Wrong:
HOME_SEARCH_VELOCITY = 10
HOME_LATCH_VELOCITY = 0.5
HOME_FINAL_VELOCITY = 1.0
Correct:
HOME_SEARCH_VEL = 10
HOME_LATCH_VEL = 0.5
HOME_FINAL_VEL = 1.0
Thats all, then it works
Sigi
  • JT
  • JT's Avatar
31 Aug 2025 19:39
Category: HAL
That line does not show up if the axes are all linear.
JT
Displaying 10471 - 10485 out of 17074 results.
Time to create page: 0.335 seconds
