  • becrazy
  • becrazy
25 Aug 2025 11:09 - 25 Aug 2025 11:14
RPi5 with LinuxCNC Image and Waveshare PCIe TO Gigabit ETH Board
Category: Installing LinuxCNC
Using dmesg gives information if I unplug and plug the network cable on eth0 and eth1:
cnc@linuxcnc1:~$ sudo dmesg | grep eth
[51259.808328] r8169 0000:01:00.0 eth1: Link is Down
[51334.956935] macb 1f00100000.ethernet eth0: Link is Down
[51336.323225] r8169 0000:01:00.0 eth1: Link is Up - 100Mbps/Full - flow control rx/tx
[51431.494868] r8169 0000:01:00.0 eth1: Link is Down
[51433.262584] macb 1f00100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control tx
If I connect the port to a network switch it is getting an IP from the router, but it is not possible to ping to that ip. I will try to read some more about how to get that working.
  • emclinuxer
  • emclinuxer
25 Aug 2025 10:15
Replied by emclinuxer on topic Probe Basic Screen missing axes
Category: QtPyVCP
Hello , i've got the same Problem but the manual doesn't help me.
Have you solved this problem?
  • Gautham
  • Gautham
25 Aug 2025 10:15
Replied by Gautham on topic Connecting my 7i96s to the VFD
Category: Driver Boards
So I got my spindle and VFD wired up as you mentioned but as I am new to LinuxCNC I don't know how to set up my LinuxCNC to run my spindle. I am using 7i96s_5abobd.bin firmware if that has any impact on this. Thank you for being so helpful.
  • unknown
  • unknown
25 Aug 2025 10:10
I'm assuming this is the output when running the Linuxcnc image.
0000:01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
        Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
        Flags: fast devsel, IRQ 38
        Memory at 1b80004000 (64-bit, non-prefetchable)
=4K%        Memory at 1b80000000 (64-bit, non-prefetchable)
=16K%        Capabilities: <access denied>
        Kernel driver in use: r8169
        Kernel modules: r8169
Ethernet device has been detected and the driver loaded.
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether aa:57:f1:85:a9:88 brd ff:ff:ff:ff:ff:ff
    altname enp1s0
Your NIC is there, just waiting to be configured, most likely it will be enp1s0. It's very rare interfaces identify as eth0 eth1 etc anymore without any kernel options being given. Has been this way for a few years now.
forum.linuxcnc.org/38-general-linuxcnc-q...l-images-only#325007 is a thread that indexes topics in the main RPi5/4 thread. Plenty there on configuring interfaces installing Gnome Network manager and the sort.
Unsure as to why dmesg isn't giving any output.
  • Gautham
  • Gautham
25 Aug 2025 10:03 - 25 Aug 2025 10:11
Replied by Gautham on topic 5 axis milling machine with 7i96s
Hi again,So I finally got this BoB,  and I have wired up everything according to this video tutorial I found, but I don't know how to configure my B-axis to run through the BoB on LinuxCNC. I also managed to flash the 7i96s_5abobd.bin firmware to the mesa card but I'm not sure how to proceed on LinuxCNC
Thank you so much for your help.
  • andronick83
  • andronick83's Avatar
25 Aug 2025 09:35 - 25 Aug 2025 09:36
Replied by andronick83 on topic joywheel.comp - Joystick wheel processor
Category: Lathe Library
Added pins:
enable IN BIT - Enable joywheel
multiplier IN FLOAT - Output signal multiplier. For reverse: -1.0
  • karlhe
  • karlhe
25 Aug 2025 09:30
Replied by karlhe on topic in linuxcnc freecad 1.0 einbinden
Category: Configuration Tools
hallo Michael,
vielen Dank für Deine Hilfe. ich habe flatpak über das terminal installiert.
Wie binde ich jetzt freecad 1.0 ein?
karlhe
  • ts
  • ts
25 Aug 2025 08:37 - 25 Aug 2025 11:59
Replied by ts on topic Use of ODOT Ethercat coupler I/O?
Category: EtherCAT
Hi, Hakkan!
at this morning command PDOS -p0 give me only empty answer. After your command - lcec_configgen gives only <masters> string at all. But after manipulation - everything changed/I found information and solve this issue.So - our modules have to be flashed by configuration. Configuration generates with utility. This utility gives a bin file, which one have to be flashed into ODOT with command sii_write -p0 esi.bin .
sudo apt-get install libxml2-devgit
clone https://github.com/synapticon/siitool siitool
cd siitool
make
sudo make install
siitool -o esi.bin 'name of xml file ODOT'
ethercat sii_write -p 0 esi.bin
if needed i may send  file esi.bin (in attachment) and working xml for odot 8033 - only coupler and 222f module in config - in network ethercat only one slave - ODOT. Also - file XML from site ODOT dont work from the box when i try to compile bin file. It works in my case with XML ODOT version XML-ODOT-CN8033-V1.45-20241209.After procedure already lcec_configgen works fine. One point now - is how to automatic download sii_write to every starting of LinuxCNC because every power on, need to do sii_write procedure again...
  • Hakan
  • Hakan
25 Aug 2025 07:29
Debian tries to connect to the internet on EtherCAT network device?
Category: EtherCAT
Debian themselves say to use ifconfig in their wiki wiki.debian.org/NetworkConfiguration#Bri...ithout_an_IP_address. It's available just install it with "apt install net-tools".
There is no kernel variable to set/unset eee for the igc driver afaik. The only way is to use "ethtool --show-eee enps2s0" and "ethtool --set-eee enp2s0 eee off" or on. It was some five months since I played around with this so I might have forgotten things
forum.linuxcnc.org/18-computer/55782-adding-a-m-2-ethernet-port
  • becrazy
  • becrazy
25 Aug 2025 07:26 - 25 Aug 2025 07:34
Hello,thank you for your answer. Here are the outputs
cnc@linuxcnc1:~$ lspci -v
0000:00:00.0 PCI bridge: Broadcom Inc. and subsidiaries BCM2712 PCIe Bridge (rev 21) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 38
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        Memory behind bridge: 80000000-800fffff =1M% [32-bit]
        Prefetchable memory behind bridge: [disabled] [64-bit]
        Kernel driver in use: pcieport
0001:00:00.0 PCI bridge: Broadcom Inc. and subsidiaries BCM2712 PCIe Bridge (rev 21) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 39
        Memory behind bridge: 00000000-005fffff =6M% [32-bit]
0001:01:00.0 Ethernet controller: Raspberry Pi Ltd RP1 PCIe 2.0 South Bridge
        Memory at 1f00410000 (32-bit, non-prefetchable)
=16K%        Memory at 1f00000000 (32-bit, non-prefetchable) [virtual]
=4M%        Memory at 1f00400000 (32-bit, non-prefetchable)
=64K%        Capabilities: <access denied>
        Kernel driver in use: rp1
cnc@linuxcnc1:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 2c:cf:67:3a:15:bb brd ff:ff:ff:ff:ff:ff
    altname end0
    inet 192.168.0.153/24 brd 192.168.0.255 scope global dynamic eth0
       valid_lft 825164sec preferred_lft 825164sec
    inet6 fdce:a2be:2d61:0:2ecf:67ff:fe3a:15bb/64 scope global dynamic mngtmpaddr
       valid_lft 7188sec preferred_lft 3588sec
    inet6 2003:e4:9741:1e00:2ecf:67ff:fe3a:15bb/64 scope global dynamic mngtmpaddr
       valid_lft 7188sec preferred_lft 1313sec
    inet6 fe80::2ecf:67ff:fe3a:15bb/64 scope link
    altname enp1s0
4: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 2c:cf:67:3a:15:bc brd ff:ff:ff:ff:ff:ff
For
there is no output on console.
  • Hakan
  • Hakan
25 Aug 2025 06:16
Replied by Hakan on topic Use of ODOT Ethercat coupler I/O?
Category: EtherCAT
Output of lcec_configgen?
  • ts
  • ts
25 Aug 2025 05:36 - 25 Aug 2025 06:05
Category: EtherCAT
dmesg says:
[ 42.224233] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ 42.224475] EtherCAT ERROR 0-0: AL status message 0x001D: "Invalid output configuration".
[ 42.226186] EtherCAT 0-0: Acknowledged state PREOP.
additional information listing of sdos command - i have only coupler and ct222f module (16 do):
r@LCNC2:~$ ethercat sdos
SDO 0x1000, "Device type"
  0x1000:00, r-r-r-, uint32, 32 bit, "Device type"
SDO 0x1001, "Error register"
  0x1001:00, r-r-r-, uint8, 8 bit, "Error register"
SDO 0x1008, "Device name"
  0x1008:00, r-r-r-, string, 256 bit, "Device name"
SDO 0x1009, "Hardware version"
  0x1009:00, r-r-r-, string, 24 bit, "Hardware version"
SDO 0x100a, "Software version"
  0x100a:00, r-r-r-, string, 24 bit, "Software version"
SDO 0x1018, "Identity"
  0x1018:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1018:01, r-r-r-, uint32, 32 bit, "Vendor ID"
  0x1018:02, r-r-r-, uint32, 32 bit, "Product code"
  0x1018:03, r-r-r-, uint32, 32 bit, "Revision"
  0x1018:04, r-r-r-, uint32, 32 bit, "Serial number"
SDO 0x10f1, "Error Settings"
  0x10f1:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x10f1:01, rwrwrw, uint32, 32 bit, "Local Error Reaction"
  0x10f1:02, rwrwrw, uint16, 16 bit, "Sync Error Counter Limit"
SDO 0x10f8, "Timestamp Object"
  0x10f8:00, rwrwrw, uint64, 64 bit, "Timestamp Object"
SDO 0x1600, "CT-222F"
  0x1600:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1600:01, r-r-r-, uint32, 32 bit, "SubIndex 001"
SDO 0x1c00, "Sync manager type"
  0x1c00:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c00:01, r-r-r-, uint8, 8 bit, "SubIndex 001"
  0x1c00:02, r-r-r-, uint8, 8 bit, "SubIndex 002"
  0x1c00:03, r-r-r-, uint8, 8 bit, "SubIndex 003"
  0x1c00:04, r-r-r-, uint8, 8 bit, "SubIndex 004"
SDO 0x1c12, "SyncManager 2 assignment"
  0x1c12:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c12:01, r-r-r-, uint16, 16 bit, "SubIndex 001"
SDO 0x1c13, "SyncManager 3 assignment"
  0x1c13:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c13:01, r-r-r-, uint16, 16 bit, "SubIndex 001"
SDO 0x1c32, "SM output parameter"
  0x1c32:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c32:01, rwr-r-, uint16, 16 bit, "Synchronization Type"
  0x1c32:02, r-r-r-, uint32, 32 bit, "Cycle Time"
  0x1c32:03, ------, type 0000, 32 bit, "SubIndex 003"
  0x1c32:04, r-r-r-, uint16, 16 bit, "Synchronization Types supported"
  0x1c32:05, r-r-r-, uint32, 32 bit, "Minimum Cycle Time"
  0x1c32:06, r-r-r-, uint32, 32 bit, "Calc and Copy Time"
  0x1c32:07, ------, type 0000, 32 bit, "SubIndex 007"
  0x1c32:08, rwrwrw, uint16, 16 bit, "Get Cycle Time"
  0x1c32:09, r-r-r-, uint32, 32 bit, "Delay Time"
  0x1c32:0a, rwrwrw, uint32, 32 bit, "Sync0 Cycle Time"
  0x1c32:0b, r-r-r-, uint16, 16 bit, "SM-Event Missed"
  0x1c32:0c, r-r-r-, uint16, 16 bit, "Cycle Time Too Small"
  0x1c32:0d, ------, type 0000, 16 bit, "Shift Time Too Short"
  0x1c32:0e, ------, type 0000, 16 bit, "SubIndex 014"
  0x1c32:0f, ------, type 0000, 32 bit, "SubIndex 015"
  0x1c32:10, ------, type 0000, 32 bit, "SubIndex 016"
  0x1c32:11, ------, type 0000, 32 bit, "SubIndex 017"
  0x1c32:12, ------, type 0000, 32 bit, "SubIndex 018"
  0x1c32:13, ------, type 0000, 0 bit, "SubIndex 019"
  0x1c32:14, ------, type 0000, 0 bit, "SubIndex 020"
  0x1c32:15, ------, type 0000, 0 bit, "SubIndex 021"
  0x1c32:16, ------, type 0000, 0 bit, "SubIndex 022"
  0x1c32:17, ------, type 0000, 0 bit, "SubIndex 023"
  0x1c32:18, ------, type 0000, 0 bit, "SubIndex 024"
  0x1c32:19, ------, type 0000, 0 bit, "SubIndex 025"
  0x1c32:1a, ------, type 0000, 0 bit, "SubIndex 026"
  0x1c32:1b, ------, type 0000, 0 bit, "SubIndex 027"
  0x1c32:1c, ------, type 0000, 0 bit, "SubIndex 028"
  0x1c32:1d, ------, type 0000, 0 bit, "SubIndex 029"
  0x1c32:1e, ------, type 0000, 0 bit, "SubIndex 030"
  0x1c32:1f, ------, type 0000, 0 bit, "SubIndex 031"
  0x1c32:20, r-r-r-, bool, 1 bit, "Sync Error"
SDO 0x1c33, "SM input parameter"
  0x1c33:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c33:01, rwr-r-, uint16, 16 bit, "Synchronization Type"
  0x1c33:02, r-r-r-, uint32, 32 bit, "Cycle Time"
  0x1c33:03, ------, type 0000, 32 bit, "SubIndex 003"
  0x1c33:04, r-r-r-, uint16, 16 bit, "Synchronization Types supported"
  0x1c33:05, r-r-r-, uint32, 32 bit, "Minimum Cycle Time"
  0x1c33:06, r-r-r-, uint32, 32 bit, "Calc and Copy Time"
  0x1c33:07, ------, type 0000, 32 bit, "SubIndex 007"
  0x1c33:08, rwrwrw, uint16, 16 bit, "Get Cycle Time"
  0x1c33:09, r-r-r-, uint32, 32 bit, "Delay Time"
  0x1c33:0a, rwrwrw, uint32, 32 bit, "Sync0 Cycle Time"
  0x1c33:0b, r-r-r-, uint16, 16 bit, "SM-Event Missed"
  0x1c33:0c, r-r-r-, uint16, 16 bit, "Cycle Time Too Small"
  0x1c33:0d, ------, type 0000, 16 bit, "Shift Time Too Short"
  0x1c33:0e, ------, type 0000, 16 bit, "SubIndex 014"
  0x1c33:0f, ------, type 0000, 32 bit, "SubIndex 015"
  0x1c33:10, ------, type 0000, 32 bit, "SubIndex 016"
  0x1c33:11, ------, type 0000, 32 bit, "SubIndex 017"
  0x1c33:12, ------, type 0000, 32 bit, "SubIndex 018"
  0x1c33:13, ------, type 0000, 0 bit, "SubIndex 019"
  0x1c33:14, ------, type 0000, 0 bit, "SubIndex 020"
  0x1c33:15, ------, type 0000, 0 bit, "SubIndex 021"
  0x1c33:16, ------, type 0000, 0 bit, "SubIndex 022"
  0x1c33:17, ------, type 0000, 0 bit, "SubIndex 023"
  0x1c33:18, ------, type 0000, 0 bit, "SubIndex 024"
  0x1c33:19, ------, type 0000, 0 bit, "SubIndex 025"
  0x1c33:1a, ------, type 0000, 0 bit, "SubIndex 026"
  0x1c33:1b, ------, type 0000, 0 bit, "SubIndex 027"
  0x1c33:1c, ------, type 0000, 0 bit, "SubIndex 028"
  0x1c33:1d, ------, type 0000, 0 bit, "SubIndex 029"
  0x1c33:1e, ------, type 0000, 0 bit, "SubIndex 030"
  0x1c33:1f, ------, type 0000, 0 bit, "SubIndex 031"
  0x1c33:20, r-r-r-, bool, 1 bit, "Sync Error"
SDO 0x2000, "ConfigurationParameter"
  0x2000:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x2000:01, rwr-r-, type 0030, 1 bit, "SourceOfConfiguration"
  0x2000:02, rwr-r-, type 0030, 1 bit, "InputFaultAction"
  0x2000:03, rwr-r-, type 0030, 1 bit, "OutputFaultAction"
  0x2000:04, rwr-r-, type 0030, 1 bit, "DiagnosticFunctionEnable"
SDO 0x7000, ""
  0x7000:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x7000:01, rwrwrw, uint32, 32 bit, "SubIndex 001"
SDO 0xf000, "Module device profile"
  0xf000:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0xf000:01, r-r-r-, uint16, 16 bit, "Index distance"
  0xf000:02, r-r-r-, uint16, 16 bit, "maximum number of modules"
SDO 0xf010, "Module Profile List"
  0xf010:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0xf010:01, r-r-r-, uint32, 32 bit, "SubIndex 001"
  0xf010:02, r-r-r-, uint32, 32 bit, "SubIndex 002"
  0xf010:03, r-r-r-, uint32, 32 bit, "SubIndex 003"
  0xf010:04, r-r-r-, uint32, 32 bit, "SubIndex 004"
  0xf010:05, r-r-r-, uint32, 32 bit, "SubIndex 005"
  0xf010:06, r-r-r-, uint32, 32 bit, "SubIndex 006"
  0xf010:07, r-r-r-, uint32, 32 bit, "SubIndex 007"
  0xf010:08, r-r-r-, uint32, 32 bit, "SubIndex 008"
  0xf010:09, r-r-r-, uint32, 32 bit, "SubIndex 009"
  0xf010:0a, r-r-r-, uint32, 32 bit, "SubIndex 010"
  0xf010:0b, r-r-r-, uint32, 32 bit, "SubIndex 011"
  0xf010:0c, r-r-r-, uint32, 32 bit, "SubIndex 012"
  0xf010:0d, r-r-r-, uint32, 32 bit, "SubIndex 013"
  0xf010:0e, r-r-r-, uint32, 32 bit, "SubIndex 014"
  0xf010:0f, r-r-r-, uint32, 32 bit, "SubIndex 015"
  0xf010:10, r-r-r-, uint32, 32 bit, "SubIndex 016"
  0xf010:11, r-r-r-, uint32, 32 bit, "SubIndex 017"
  0xf010:12, r-r-r-, uint32, 32 bit, "SubIndex 018"
  0xf010:13, r-r-r-, uint32, 32 bit, "SubIndex 019"
  0xf010:14, r-r-r-, uint32, 32 bit, "SubIndex 020"
  0xf010:15, r-r-r-, uint32, 32 bit, "SubIndex 021"
  0xf010:16, r-r-r-, uint32, 32 bit, "SubIndex 022"
  0xf010:17, r-r-r-, uint32, 32 bit, "SubIndex 023"
  0xf010:18, r-r-r-, uint32, 32 bit, "SubIndex 024"
  0xf010:19, r-r-r-, uint32, 32 bit, "SubIndex 025"
  0xf010:1a, r-r-r-, uint32, 32 bit, "SubIndex 026"
  0xf010:1b, r-r-r-, uint32, 32 bit, "SubIndex 027"
  0xf010:1c, r-r-r-, uint32, 32 bit, "SubIndex 028"
  0xf010:1d, r-r-r-, uint32, 32 bit, "SubIndex 029"
  0xf010:1e, r-r-r-, uint32, 32 bit, "SubIndex 030"
  0xf010:1f, r-r-r-, uint32, 32 bit, "SubIndex 031"
  0xf010:20, r-r-r-, uint32, 32 bit, "SubIndex 032"
  0xf010:21, r-r-r-, uint32, 32 bit, "SubIndex 033"
  0xf010:22, r-r-r-, uint32, 32 bit, "SubIndex 034"
  0xf010:23, r-r-r-, uint32, 32 bit, "SubIndex 035"
  0xf010:24, r-r-r-, uint32, 32 bit, "SubIndex 036"
  0xf010:25, r-r-r-, uint32, 32 bit, "SubIndex 037"
  0xf010:26, r-r-r-, uint32, 32 bit, "SubIndex 038"
  0xf010:27, r-r-r-, uint32, 32 bit, "SubIndex 039"
  0xf010:28, r-r-r-, uint32, 32 bit, "SubIndex 040"
  0xf010:29, r-r-r-, uint32, 32 bit, "SubIndex 041"
  0xf010:2a, r-r-r-, uint32, 32 bit, "SubIndex 042"
  0xf010:2b, r-r-r-, uint32, 32 bit, "SubIndex 043"
  0xf010:2c, r-r-r-, uint32, 32 bit, "SubIndex 044"
  0xf010:2d, r-r-r-, uint32, 32 bit, "SubIndex 045"
  0xf010:2e, r-r-r-, uint32, 32 bit, "SubIndex 046"
  0xf010:2f, r-r-r-, uint32, 32 bit, "SubIndex 047"
  0xf010:30, r-r-r-, uint32, 32 bit, "SubIndex 048"
  0xf010:31, r-r-r-, uint32, 32 bit, "SubIndex 049"
  0xf010:32, r-r-r-, uint32, 32 bit, "SubIndex 050"
  0xf010:33, r-r-r-, uint32, 32 bit, "SubIndex 051"
  0xf010:34, r-r-r-, uint32, 32 bit, "SubIndex 052"
  0xf010:35, r-r-r-, uint32, 32 bit, "SubIndex 053"
  0xf010:36, r-r-r-, uint32, 32 bit, "SubIndex 054"
  0xf010:37, r-r-r-, uint32, 32 bit, "SubIndex 055"
  0xf010:38, r-r-r-, uint32, 32 bit, "SubIndex 056"
  0xf010:39, r-r-r-, uint32, 32 bit, "SubIndex 057"
  0xf010:3a, r-r-r-, uint32, 32 bit, "SubIndex 058"
  0xf010:3b, r-r-r-, uint32, 32 bit, "SubIndex 059"
  0xf010:3c, r-r-r-, uint32, 32 bit, "SubIndex 060"
  0xf010:3d, r-r-r-, uint32, 32 bit, "SubIndex 061"
  0xf010:3e, r-r-r-, uint32, 32 bit, "SubIndex 062"
  0xf010:3f, r-r-r-, uint32, 32 bit, "SubIndex 063"
  0xf010:40, r-r-r-, uint32, 32 bit, "SubIndex 064"
  0xf010:41, r-r-r-, uint32, 32 bit, "SubIndex 065"
SDO 0xf050, "Detected Module Ident List"
  0xf050:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0xf050:01, r-r-r-, uint32, 32 bit, "SubIndex 001"
  0xf050:02, r-r-r-, uint32, 32 bit, "SubIndex 002"
  0xf050:03, r-r-r-, uint32, 32 bit, "SubIndex 003"
  0xf050:04, r-r-r-, uint32, 32 bit, "SubIndex 004"
  0xf050:05, r-r-r-, uint32, 32 bit, "SubIndex 005"
  0xf050:06, r-r-r-, uint32, 32 bit, "SubIndex 006"
  0xf050:07, r-r-r-, uint32, 32 bit, "SubIndex 007"
  0xf050:08, r-r-r-, uint32, 32 bit, "SubIndex 008"
  0xf050:09, r-r-r-, uint32, 32 bit, "SubIndex 009"
  0xf050:0a, r-r-r-, uint32, 32 bit, "SubIndex 010"
  0xf050:0b, r-r-r-, uint32, 32 bit, "SubIndex 011"
  0xf050:0c, r-r-r-, uint32, 32 bit, "SubIndex 012"
  0xf050:0d, r-r-r-, uint32, 32 bit, "SubIndex 013"
  0xf050:0e, r-r-r-, uint32, 32 bit, "SubIndex 014"
  0xf050:0f, r-r-r-, uint32, 32 bit, "SubIndex 015"
  0xf050:10, r-r-r-, uint32, 32 bit, "SubIndex 016"
  0xf050:11, r-r-r-, uint32, 32 bit, "SubIndex 017"
  0xf050:12, r-r-r-, uint32, 32 bit, "SubIndex 018"
  0xf050:13, r-r-r-, uint32, 32 bit, "SubIndex 019"
  0xf050:14, r-r-r-, uint32, 32 bit, "SubIndex 020"
  0xf050:15, r-r-r-, uint32, 32 bit, "SubIndex 021"
  0xf050:16, r-r-r-, uint32, 32 bit, "SubIndex 022"
  0xf050:17, r-r-r-, uint32, 32 bit, "SubIndex 023"
  0xf050:18, r-r-r-, uint32, 32 bit, "SubIndex 024"
  0xf050:19, r-r-r-, uint32, 32 bit, "SubIndex 025"
  0xf050:1a, r-r-r-, uint32, 32 bit, "SubIndex 026"
  0xf050:1b, r-r-r-, uint32, 32 bit, "SubIndex 027"
  0xf050:1c, r-r-r-, uint32, 32 bit, "SubIndex 028"
  0xf050:1d, r-r-r-, uint32, 32 bit, "SubIndex 029"
  0xf050:1e, r-r-r-, uint32, 32 bit, "SubIndex 030"
  0xf050:1f, r-r-r-, uint32, 32 bit, "SubIndex 031"
  0xf050:20, r-r-r-, uint32, 32 bit, "SubIndex 032"
  0xf050:21, r-r-r-, uint32, 32 bit, "SubIndex 033"
  0xf050:22, r-r-r-, uint32, 32 bit, "SubIndex 034"
  0xf050:23, r-r-r-, uint32, 32 bit, "SubIndex 035"
  0xf050:24, r-r-r-, uint32, 32 bit, "SubIndex 036"
  0xf050:25, r-r-r-, uint32, 32 bit, "SubIndex 037"
  0xf050:26, r-r-r-, uint32, 32 bit, "SubIndex 038"
  0xf050:27, r-r-r-, uint32, 32 bit, "SubIndex 039"
  0xf050:28, r-r-r-, uint32, 32 bit, "SubIndex 040"
  0xf050:29, r-r-r-, uint32, 32 bit, "SubIndex 041"
  0xf050:2a, r-r-r-, uint32, 32 bit, "SubIndex 042"
  0xf050:2b, r-r-r-, uint32, 32 bit, "SubIndex 043"
  0xf050:2c, r-r-r-, uint32, 32 bit, "SubIndex 044"
  0xf050:2d, r-r-r-, uint32, 32 bit, "SubIndex 045"
  0xf050:2e, r-r-r-, uint32, 32 bit, "SubIndex 046"
  0xf050:2f, r-r-r-, uint32, 32 bit, "SubIndex 047"
  0xf050:30, r-r-r-, uint32, 32 bit, "SubIndex 048"
  0xf050:31, r-r-r-, uint32, 32 bit, "SubIndex 049"
  0xf050:32, r-r-r-, uint32, 32 bit, "SubIndex 050"
  0xf050:33, r-r-r-, uint32, 32 bit, "SubIndex 051"
  0xf050:34, r-r-r-, uint32, 32 bit, "SubIndex 052"
  0xf050:35, r-r-r-, uint32, 32 bit, "SubIndex 053"
  0xf050:36, r-r-r-, uint32, 32 bit, "SubIndex 054"
  0xf050:37, r-r-r-, uint32, 32 bit, "SubIndex 055"
  0xf050:38, r-r-r-, uint32, 32 bit, "SubIndex 056"
  0xf050:39, r-r-r-, uint32, 32 bit, "SubIndex 057"
  0xf050:3a, r-r-r-, uint32, 32 bit, "SubIndex 058"
  0xf050:3b, r-r-r-, uint32, 32 bit, "SubIndex 059"
  0xf050:3c, r-r-r-, uint32, 32 bit, "SubIndex 060"
  0xf050:3d, r-r-r-, uint32, 32 bit, "SubIndex 061"
  0xf050:3e, r-r-r-, uint32, 32 bit, "SubIndex 062"
  0xf050:3f, r-r-r-, uint32, 32 bit, "SubIndex 063"
  0xf050:40, r-r-r-, uint32, 32 bit, "SubIndex 064"
  0xf050:41, r-r-r-, uint32, 32 bit, "SubIndex 065"
  • tcbmetalworks
  • tcbmetalworks
25 Aug 2025 04:48
Replied by tcbmetalworks on topic Automatic band saw marvel v10a
Category: CNC Machines
Here i have the saw. I pressure washed it like 20 times lots of wire brush on a angle grinder to all of the machined surfaces then painted it with thick oil based enamel paint. I also resurfaced all of the flat surfaces on the clamps/table on a large gorton milling machine with a shell mill. Soon I will start doing the assembly of the control box and wiring. I am going to keep a portion of the original electronic components and replacing most. Hopefully the system of controlling the hydraulic feed with a Encoder works well. If not I can scrap it for a ballscrew. slowly but surely it comes together.
  • jschulze
  • jschulze
25 Aug 2025 03:56
Looking for Stepgen Index Homing Firmware for Mesa 7i76eu & 7i85S
It worked! I don't have much time right now to play with it, but I was able to manually turn on the stepgen index-enable and it turned off and zeroed the stepgen count with the index signal. Thanks so much for your help with this, it's very much appreciated.
  • PCW
  • PCW's Avatar
25 Aug 2025 03:21 - 25 Aug 2025 03:34
Sorry,  I got the stepgen version wrong, will retry.
Try this:
File Name: 7i76eu_7i8...8-24.zip
File Size:302 KB
Displaying 10696 - 10710 out of 17135 results.
Time to create page: 0.412 seconds
