  • Hakan
  • Hakan
24 Aug 2025 11:51
Debian tries to connect to the internet on EtherCAT network device?
Category: EtherCAT
That can't be right? Maybe it works, but you normally don't want nor need an IP-address on the ethercat interface.
Here is my config for I226-V in /etc/network/interfaces.
auto enp2s0
iface enp2s0 inet manual
        hardware-irq-coalesce-rx-usecs 0
        pre-up /sbin/ifconfig $IFACE up
        post-down /sbin/ifconfig $IFACE down
The i226 uses the Intel igc driver, the energy-efficient mode is off by default, so the igb.EEE=0 is not needed and also is for the igb driver, not the igc.
You can rename the nic with a .link file, google it the best tip there.
  • thomaseg
  • thomaseg
24 Aug 2025 11:32
Category: EtherCAT
iface eno1 inet dhcp
Ehm.... it worked! Thanks! The networkinterface for EtherCAT is no longer in the list of networks and now the internet connection defaults to the proper interface, and EtherCAT works like a charm now...but....why did that work? :-D I don't understand since nothing in that configuration seems indicate "oh, by the way, this will hide the interface from UI and prevent InternetConnection from trying to use it"...i've looked up the hardware-irq-coalesce-rx-usecs parameter and that only seems to be some sort of tuning, not something that should do what it just did....
Sorry, i'm just trying to understand it... the worst part is when something works, and i don't understand why it works ;-)
PS: I also disabled the power-stuff in GRUB as you suggested. Thanks!
/Thomas
  • meister
  • meister
24 Aug 2025 11:31
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Category: Driver Boards
minimal fpga project, just edit the pins file to match your pinout:
github.com/multigcs/FPGA-blinky/tree/main/Colorlight5A-75E
i can't remember but i think it was already for the v8.2 board
if it works, you can take a look here:
github.com/multigcs/riocore/tree/dev/rio...olorlight5A-75B-v8.0
  • Jonathan_H
  • Jonathan_H
24 Aug 2025 11:29
System hangs repeatedly with certain combinations of operations
That was it, thought I must have missed something.
Creating the spindle-at-speed for a stopped spindle seems to have fixed the issue I was having. I added a delay because I prefer to have the spindle actually stopped (or close to) before the movement happens.
I don't see a way to make the delay time proportional to the starting speed of the spindle, so for now I've set it to five seconds.
  • rodw
  • rodw's Avatar
24 Aug 2025 09:50 - 24 Aug 2025 09:51
Category: EtherCAT
not sure but you could try adding this to /etc/network/interfacesauto eno1
replace eno1 with the NIC name reported by ip a for ethercat
Restart the network
Also add this to your boot parameters using grub-customizer to disable energy efficient internet igb.EEE=0
  • besriworld
  • besriworld
24 Aug 2025 09:08
Replied by besriworld on topic Get rid of username/password?
Category: Basic Configuration
So far it hasn’t complained yet. :side:
Old HDD drives don’t like having their power cut off like that, but modern SSDs don’t really care.
  • thomaseg
  • thomaseg
24 Aug 2025 09:02
Replied by thomaseg on topic Get rid of username/password?
I don't know if it's correct but I directly turn off the main power switch and everything goes off.
hehe! That is one way to do it! But I don't think Linux likes getting the power cut like that? Or is that assumption wrong?
/Thomas
  • thomaseg
  • thomaseg
24 Aug 2025 09:00 - 24 Aug 2025 09:03
Category: EtherCAT
I use a "Odroid H4" as master and it has two network interfaces. Perfect for LinuxCNC with EtherCAT and cabled networking. However, I'm having the issue that both network interfaces shows up as if they both can connect to the internet:
Two things annoy me:
1. Is there a way to rename these devices? The naming is kinda useless as it is and it bothers my OCD, preferably i'd call one Internet and the other EtherCAT or something like that, but i've seem to have tried everything google suggests me to rename them, without any luck...apparently not the correct one yet, ideas?
2. The top network card is the one connected to the internet...but every time the machine starts, it attempts to connect to "Internet connection" via the bottom one. These attempts causes the EtherCAT bus to reset every minute or so...to solve this i have to press "Disconnect" at the lower card and press "Internet connection" at the upper card...at every start of the system :-( Can i somehow mark the EtherCAT card as "hands off!" for internet-stuff? And the internet is automagically connected via the upper one? First i thought "easy fix", i'll just swap cables and use it the other way around....BUT lo and behold, the problem was the exact same, but now the interfaces was just switched around...ideas?
I know this isn't "LinuxCNC and ethercat specifics", but i assume others here have had the same issues, so i hope it is ok...
/Thomas
  • besriworld
  • besriworld
24 Aug 2025 08:54
  • thomaseg
  • thomaseg
24 Aug 2025 08:39
I've been wanting this to, so thanks for the input!....but.... how do you guys handle the shutting down process? Currently i'm quiting LinuxCNC with ctrl+q, going to Application-->Logoff in Debian and clicks Shutdown....waits untill the screen turns off and then flicking the main-switch on the machine.... is there a better way?
  • thomaseg
  • thomaseg
24 Aug 2025 08:35
How to monitor error-pin on 3d probe? was created by thomaseg
I'm trying to setup the  Vers WLR v9 probe  and i got it working fine together with the Vers toolsetter. However, there is a pin out for errors. This triggers if there is issues with the communication for the probe(e.g. if it runs out of battery, is not turned on, communication fails and so), but how to configure this in HAL to halt the probe-cycle? First i thought about making some logic to check if motion-type is "probing" and combine that with the error pin. But the issue is the famous "one pin for all probing", so i don't think i "know" if i'm using the 3D probe and should monitor the error pin or i'm using the toolsetter and the 3D probe is intentional not active(causing the error-pin to trigger!). I've seen several posts about using M-codes to determine which probing cycle to run, but i've also seen people warn about this approach since it requires you to remember to use them each time....
Am i missing something obvious here or have others found a clever solution to this?
/Thomas
  • xenith
  • xenith
24 Aug 2025 06:39
Named subroutines containing probe ops cause backplot errors
Category: O Codes (subroutines) and NGCGUI
I believe that I have figured out my problem, however I don't quite know how to fix it. I'm using subroutines to perform different types of feature probing operations. An example program would look something like this:
preamble
o<probe_z> call [...]
o<probe_xy_boss> call []
end
When I load one of these gcode programs, I immediately get "unknown word starting with c" errors from the 3D plotter. It seems like the plotter isn't recognizing the syntax for named subroutines. If you ignore the error, then the first subroutine will run without issue. After the first probe is completed, the error will appear again for the second o code and terminate the program. I attempted to fix this by wrapping each call in a conditional like this:
o100 if [#<_task> EQ 1]
o100 endif
o101 if [#<_task> EQ 1]
o101 endif
end
This stopped any errors from appearing prior to cycle start. The first subroutine will execute without issue, and then the error will get triggered again immediately after the first probe. Limiting the file to a single subroutine solves the issue. The #<_task> wrapping method doesn't seem to work more than once in a file in this situation. I suspect that this has something to do with the fact that the first subroutine contains a probe operation which limits the lookahead of the controller's planner. Perhaps the backplotter is getting re-triggered after the first probe operation, but the machine is still in automatic mode since it's mid-file? Any ideas would be appreciated. I'm using probe-basic.
  • jorgearma0205
  • jorgearma0205
24 Aug 2025 06:28
displayed axis was created by jorgearma0205
displayed axis
I am updating a grinding machine which only has the y and z axes controlled by a motor, the x axis is hydraulically driven with limit sensors, I already have the machine working with an old 5i23, I configured the x axis to not have errors in pncconf by configuring a linear encoder mounted on the x axis with the intention of being able to visualize them but when running a program it shows me a tracking error obviously given that there is no x movement command and the encoder starts to count, is it possible to disable the hili of the x axis only keeping the encoder count to be able to visualize the x axis on the screen?
  • karlhe
  • karlhe
24 Aug 2025 05:42 - 24 Aug 2025 06:58
Replied by karlhe on topic in linuxcnc freecad 1.0 einbinden
Category: Configuration Tools
Danke tommy,
werde es nachher gleich probieren.
karlhe
Habe ich brobiert, leider nur freecad 0.2, nich 1.0
24 Aug 2025 00:13
Replied by tommylight on topic Need help changing axis home direction?
How did you create the config?
If using the wizard, there is "invert" on the right side of every pin, so check that for direction of the axis you need.
You can also edit the .ini file and add " - " (minus sign) in front of the SCALE value for the joints/axis you need to change direction.
Displaying 10741 - 10755 out of 17135 results.
Time to create page: 1.027 seconds
