  • electrosteam
  • electrosteam
20 Aug 2025 09:20
Replied by electrosteam on topic Coordinate Rotations, Subroutines
Thanks Aciera,
That requirement eluded me when researching this subject.
  • Hakan
  • Hakan
20 Aug 2025 09:17
Drive recommendations for rigid tapping 24000rpm pmsm spindle.
I think you can use any spindle with an encoder. The spindle doesn't have to be exact.
The axis follows the spindle (from encoder readings) so a good/normal Z axis is what you need.
  • Hakan
  • Hakan
20 Aug 2025 09:14
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
I could repeat that.
It was MaxAcceleration that had a too low value 1e6, now 1e8.
This only matters if one gets gravel sound from the motors.
Setting MaxAcceleration slightly above real max acceleration reduces that significantly.
Otherwise, there is no harm to set it very high. Set too low and it can't accelerate up to speed fast enough.
Pushed a commit, please update the eeprom. Firmware is the same.
I also added an axis_mm.ini config for metric units for testing.
  • 0x2102
  • 0x2102's Avatar
20 Aug 2025 09:00
Jianken has a servo driver they recommend (pre-program) for this type of spindle. Just ask them for it and if they can offer it with an EtherCAT interface.
  • Aciera
  • Aciera's Avatar
20 Aug 2025 08:11
Replied by Aciera on topic Coordinate Rotations, Subroutines
Subroutines 'may only be called after they are defined'.
linuxcnc.org/docs/html/gcode/o-code.html
  • Daan96
  • Daan96
20 Aug 2025 07:36 - 20 Aug 2025 07:36
Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
Category: Show Your Stuff
For now, I think I'll test it this way.
Later, I can make a support from cut aluminum plates.
I've also ordered the plasma source.
Any other tips and tricks?
  • Rookie0
  • Rookie0
20 Aug 2025 07:17
Replied by Rookie0 on topic SOLVED - LS L7N Servo drives
Category: EtherCAT
statusword is 4647, means the bit4 (Voltage enabled) is 0.
therefore your opmode is not set to be 8.
try remove sdoconfig lines in xml. I'm not sure if that's the reason.
the both ways have the same statusword, but their execution timing may not be the same, I'm not sure ^_^
  • electrosteam
  • electrosteam
20 Aug 2025 07:15
Coordinate Rotations, Subroutines was created by electrosteam
RPI 4B 4GB with Gmoccapy 2.9.4
First efforts at using G10 L2, and subroutines.
The attached code produces two arbitrary short curves.
Simulation only, steppers off.
1) Spent hours chasing down anomalous z value when this code executed.
  It seemed like G10 needed full population of values to avoid ambiguous DRO:
   - G10 L2 P1 x0 y0 z0 R0 to get sensible G54 datum point.
  Is this always the case ?
  Eventually I discovered persistent parameters that had incorrect values.
  Cleared them, and now all good.
  I will ensure in future that the start-up procedure includes a check on parameters.
2) My O100 subroutine must be located prior to what I call the "main".
  The main short x20 y20 move checks that the main executed before the subroutine.
  If I position O100 after main, the Gmoccapy editor refuses to save the file.
  This seems odd to me, but I cannot see my error.
  What is the correct way to use subroutines ?
John.
File Name: G10L2Test2.ngc
File Size:0 KB
  • meister
  • meister
20 Aug 2025 07:07
@mBender
You can simply copy the directory and use it, then enter the updates. It's the same as a ‘do not overwrite’ switch.
If you send me your configuration and your edited files, I can see if there is a way to integrate this into the json-configuration.
  • emresensoy
  • emresensoy
20 Aug 2025 06:35 - 20 Aug 2025 06:36
Replied by emresensoy on topic SOLVED - LS L7N Servo drives
Category: EtherCAT
with these settings, axis moves perfectly,
control word is 1111 = 15
status word is 1001000100111 = 4647,
so they are same
  • emresensoy
  • emresensoy
20 Aug 2025 06:22 - 20 Aug 2025 06:40
Category: EtherCAT
1. they are all in OP state,
2. when I move X axis target position is increasing or decreasing, but actual position is not,
all motors waiting in enabled state
  • cadcam
  • cadcam
20 Aug 2025 04:10 - 20 Aug 2025 14:10
Replied by cadcam on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Hi Giovanni,
I went back to this... and now turning works!
The issue before was it wouldn't allow negative values for E_Z.
I did do the following:
sudo apt update
sudo apt upgrade
dpkg -i  linuxcnc-uspace_2.9.4_amd64.dev
added from ncam import NCam to /usr/lib/python3/dist-packages/gladevcp/hal_pythonplugin.py
So in upgrading from 2.9.3 to 2.9.4 I have no idea what changed, but something did. Sorry for the bum steer.
Thanks for your help. Cheers!
  • cmorley
  • cmorley
20 Aug 2025 03:28
Request for Community Feedback on g-code++ (sterp) Integration with LinuxCNC
What do you mean "imports" ?
I would think that a more modern approach to parsing could be a good thing to get more people interested in working on the code.
Chris
  • CTB_le123
  • CTB_le123's Avatar
20 Aug 2025 03:27
Absoluted Encoder but Move the G53 Origin
Category: Basic Configuration
Hey, I need some help.
   I have configured a machine  using LinuxCNC, and the joints are equipped with absolute encoders. Now, I want to achieve the following: Point A is the zero-count position of the encoder, but I would like to set Point B, which is offset 200mm from Point A, as the G53 origin. How should I configure this?
Here is my ini configure:
[JOINT_1]
TYPE = LINEAR
MAX_VELOCITY = 1200
MAX_ACCELERATION = 2000
#       MIN_LIMIT = -10.0
#       MAX_LIMIT = 10.0
HOME = -10
HOME_ABSOLUTE_ENCODER = 2
HOME_OFFSET = 35
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_IGNORE_LIMITS = NO
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
VOLATILE_HOME = 0
But the problem is when I homing the axis, the joint->motor_pos_cmd whill change suddenly.  which cause the joint move suddenly. It is particularly dangerous.
Thank you for ur help!
  • ihavenofish
  • ihavenofish
20 Aug 2025 02:23
So, Jianken has a permanent magnet spindle with an encoder, and I am trying to figure out what drive I can try with it so I can rigid tap with linuxcnc.
Specs:
4 poles
800hz / 24000rpm base speed
384 pulse ABZ quadrature encoder.
3.7kw S1
Ideally id like an ethercat drive, and tap at up to 2000-6000rpm for tiny threads. Basically this is an AC servo drive as opposed to a VFD needed although there some hybrid ish drives I've seen that might work.
Note most drives in north america will be 599hz restricted, so that's not going to be too helpful.
budget is in the $500 or less range ideally.
Anyone got an idea for what to look at?
Displaying 10846 - 10860 out of 17138 results.
Time to create page: 0.764 seconds
