  • my1987toyota
  • my1987toyota's Avatar
30 Jul 2025 21:01 - 30 Jul 2025 21:14
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
Yes that may prove very valuable. The worst part I see is that this isn't a single country problem it's spreading
everywhere. It seem the powers that should never be don't like it when people don't follow the pushed narrative
or the easy in which things can be fact checked independently.
I guess it's just another day in mouse utopia.
30 Jul 2025 20:51
Replied by tommylight on topic ARE YOU KIDDING ME YOUTUBE !!!
It all started with websites like Quora and User Benchmarks back in the days and the subsequent invasion of blogs.
Now this is just a fallout form that as when so called AI hit and started multiplying like viruses, there is no going back to Wikipedia actually being very useful ever again.
While thinking about this, does anyone else think it is a good idea to make a topic about useful websites and video channels here on the forum? It might help a bit to slow down the extreme misinformation going on.
  • my1987toyota
30 Jul 2025 20:26 - 30 Jul 2025 20:26
ARE YOU KIDDING ME YOUTUBE !!! was created by my1987toyota
So I just came across this . All I can say is The internet is loosing it's usefulness.
  • Murphy
  • Murphy
30 Jul 2025 19:12
It's in the image you downloaded. Look for the components folder I think it was called. Open that, you should see the Eth files. Open the terminal(command line) from here and run the halcomplie command that's in step 8 of the instructions.
  • richcolvin
  • richcolvin's Avatar
30 Jul 2025 18:46
Replied by richcolvin on topic I seemed to have borked my GTK/Glade installation
Category: GladeVCP
What did you do to fix it?
  • PCW
  • PCW's Avatar
30 Jul 2025 18:45
Problem setting up with inputs on 7i96s. Potential Electrical cabinet problem
7i96/7I96S isolated inputs not working properly
usually means that the isolated input common
is not connected. (or connected to the wrong thing)
  • michaelvdberghe
  • michaelvdberghe
30 Jul 2025 18:44 - 30 Jul 2025 18:45
Replied by michaelvdberghe on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
hi, i'm new to this cnc building and followed your guide on page 165 and was able to flash the firmware to the ec500v5 board but i'm a bit stuck at the moment.
i'm tring to complete step 8 install eth component but i have abolutely no clue what you mean with this step nor where to find the folder.
  • xlordofpainx
  • xlordofpainx
30 Jul 2025 18:21
Hey group,
Thanks for the help so far. I rewired my setup so that it looks nice now, but I have stumbled upon an interesting problem. Here is the description:
I added an earth connection to the power supplies and inside my breaker box. I rewired everything, and it was time to wire the home switches. Previously, I had wired them on the power supplies, which were for the motors, but now I got an extra power supply for them specifically (24V).
I wired them 24 from the power supply to the normally closed AZ7121 home switches and from there to the Mesa 7i96s inputs (the optically insulated ones with the LED). For some reason, they were very dim, and the home switches were not working during home all. I started checking connections, and it seemed to be an Electrical problem.
First i found out that if i distributed how i wired them and placed them on multiple power supplies they lit up better.
Next i saw that the Init LED on the mesa card (RED LED) was on
Next i realized that if i took all of the input wires except one (the wires that went to the inputs of the card for the limit switches) the one input LED became dim, But if i simply plugged in another wire from another home switch into another input (but disconnecting it from its power supply, simply leaving it hanging) the LED on the input lit up (dimly) as well.
Next, I opened the breaker box for the CNC machine and saw that the Earth connection was touching the metal rail on which the breaker is connected. Now, there was no visible connection of a Line wire to the rail, but when I moved the Earth away from the rail and restarted the Mesa card, The RED INIT LED stopped.
Now, potentially, the earth touching the rail on which the breaker was connected somehow was a problem. (Don't know why)
But right now I still have the same problem where the input LEDs are properly ON, only when I have 4 Home switches connected to 4 different power supplies.
Also, measuring from Line to the Earth shows 18V, if that means anything.
It definitely seems that I have done something wrong, but Nothing seems out of order. If anyone has experienced something similar or has any ideas I am open to trying.
  • Aciera
  • Aciera's Avatar
30 Jul 2025 16:46
Replied by Aciera on topic Touch off don`t work "file not open"
Category: AXIS
I did try to follow the trail:
The error string displayed in the pop up comes from here:
github.com/LinuxCNC/linuxcnc/blob/master...cripts/axis.py#L1715
which calls
github.com/LinuxCNC/linuxcnc/blob/master...cripts/axis.py#L1579
The actual error is returned from 'gcode.strerror(result)' which seems to be this c++ function:
github.com/LinuxCNC/linuxcnc/blob/master.../gcodemodule.cc#L964
Why a user entry for a float value would be passed through all of that, I have no idea.
  • djdelorie
  • djdelorie
30 Jul 2025 15:51
Replied by djdelorie on topic Probe tripped during non-probe move deadlock
I had similar problems with my toolsetter, and initially used an AND gate - until the time I forgot to enable it (I used a manual signal, not motion.*) and crashed my toolsetter.  Then I tried smoothing, which worked OK.  It turns out the toolsetter is a good seismic monitor, and trips when I have issues with toolchanging ;-)
However, my comment here is... have you considered using a dummy probe move to retract the probe?
  • tuxcnc
  • tuxcnc
30 Jul 2025 15:43
Replied by tuxcnc on topic SpindleETH
SpindleETH
Category: Driver Boards
Cheap chinese magnetic encoder E6B2CWZ6C, 2500 P/R (10000 quadrature counts), spindle speed ~1400 rpm at left and ~60 rpm at right. Halscope shows velocity in rotates per second.
  • CNCGOOS
  • CNCGOOS
30 Jul 2025 15:12
Replied by CNCGOOS on topic Probe tripped during non-probe move deadlock
This is indeed a much neater method, great! I also solved it quickly and durty with an AND gate. But creating your own component is much nicer in the Hal code.
If I have an evening off, I'll play around with creating a comp.
  • andypugh
  • andypugh's Avatar
30 Jul 2025 14:56
Replied by andypugh on topic Touch off don`t work "file not open"
Category: AXIS
Which LinuxCNC version? Not that it probably matters as I don't see much difference in this area.
I think that the dialog box is created here:
github.com/LinuxCNC/linuxcnc/blob/master...cripts/axis.py#L1643
With some TkInter stuff in the backgorund that I don't really understand.
But, I don't see where "file not open" comes from. There isn't normally anything in that area of the dialog, I don't think? (unless you know better?) so I can't even find a hint of which file isn't open.
  • andypugh
  • andypugh's Avatar
30 Jul 2025 14:20
Replied by andypugh on topic Probe tripped during non-probe move deadlock
Thanks for your analysis. If you feel so inclined, feel free to add this to the issue tracker: github.com/LinuxCNC/linuxcnc/issues
It would be even better if you could work out a fix :-)
  • andypugh
  • andypugh's Avatar
30 Jul 2025 14:12
Replied by andypugh on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
I adapted it for myself, but I just wanted to ask if there was a specific reason why the order was chosen that way.
I just hadn't noticed as I don't have a tool-changer. It's that simple. No considered policy decision.
Displaying 11581 - 11595 out of 17284 results.
Time to create page: 0.510 seconds
