  • zzrzzr
  • zzrzzr
26 Jul 2025 13:49
Replied by zzrzzr on topic PlasmaC Voltage Divider
Category: Plasmac
Thanks. I bought the Stahlwerk 70 P Plasmacutter.
Would this resistor also be possible (Mouser wants 20€ shipping) ?
www.reichelt.de/de/de/shop/produkt/wider...7_250_mw_0_1_-237509
Inside a box outside the pasma-source to avoid warranty-loss (7 Years warranty on the machine).
  • hitchhiker
  • hitchhiker
26 Jul 2025 12:06 - 26 Jul 2025 12:07
ECMO VMC100 Retrofit with Carousel/Toolchanger
Category: Milling Machines
Hi guys!
I get a VMC-100 as gift from a school.
I owm a F1P which i retrofit to LINUXCNC years ago. works perfect.
Same Machine as the VMC-100 but with manual Toolchange.
Now the VMC-100 has a carousel as Toolchanger.
This carousel have 4 proximity switch to operate the Toolchanger.
Sensor1 is a sensor to reference tool 1.
Sensor2 counts a hole in a parallel gear. is it counts 2 times the next toolslot is reached.
Sensor3 tells that the tool is engaged.
Sensor4 tells that the tool is disengaged and the mainspindle can rotate the carousel.
Main issue for me is that the carousel works above the Z reference sensor.
At Z reference positon the Carousel begins to disengage the tool and when sensor 4 is reached the carousel can rotate.
Does someone ever retrofit this in Linuxcnc and can share his experience?
I searched a bit arround but found only some videos with MACH3 and some dead threads.
I will use the orignial maindrive which has a encoder on it at the beginning.
the maindrive works with step/dir signals.
On my f1p was the same maindrive which i use to tap threads.. spindle orient is used for this but iswitch to a 1kw servo.
this time i will use everything orignial because i have 3 orignial stepperdrivers for the 5 phase steppers. later i would change to nema23 2 phase.
Main focus is to bring everything back to live without changing to different steppermotors or maindrive.
The maindrive is working and the encoder counts.
Steppers working.
all proximity sensors are working.
thanks for any help :)
the pictures are taken from youtube
  • ChironFZ16
  • ChironFZ16's Avatar
26 Jul 2025 11:33
Replied by ChironFZ16 on topic Fehler Upgrade
Fehler Upgrade
Category: Deutsch
Einfach sudo dpkg -P raspi-firmware eingeben ;)
  • scsmith1451
  • scsmith1451's Avatar
26 Jul 2025 11:25
Replied by scsmith1451 on topic Set program zero using XY positioning laser
Attached are the requested files.
I have not made any manual changes to either of these files. They are both output from pncconf.
Kind Regards
  • SwitchWitch
  • SwitchWitch
26 Jul 2025 10:43
Tuning of OMC Stepperonline A6 Servos was created by SwitchWitch
in my eyes the related software (ancdevicestarter) for the stepperonline A6 Servos is a bit confusing in terms of Autotuning.
The manual of the servos and the manual of the software are confusing for me.
Is there any video or tutorial out there bringing light into the darkness or is there anybody who could just give a short goto?
thx in advance
best
Kai
  • BlownCorona
  • BlownCorona
26 Jul 2025 09:44 - 26 Jul 2025 09:49
Replied by BlownCorona on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
Good evening Tommy
Can i please get a copy of the 19.3 iso? I have finally gotten myself a touch screen for my project mill and ofcourse, it doesnt work as it turns out to be some funky Quanta OpticalTouchScreen device with a ViewSonic sticker. research suggests other linux (not LCNC) users have used this monitor just fine on older kernel builds so im hopefull the 19.3 iso and associated older RT kernal will work.
  • hitchhiker
  • hitchhiker
26 Jul 2025 08:20
Replied by hitchhiker on topic Rotary Encoder to adjust Jog-Speed?
i use a mpg and i add more smaller step scales. like 0.001 0.005. i was on the wrong way! sry!
  • _skinner
  • _skinner
26 Jul 2025 06:54
Auto mode, reaching first point of coord then "reading" state, no movement
Hello,
I was trying figure it out and find answer but without success.
Have You know why in auto mode and MDI sometime machine stuck in reading state without execution of program? Just simple turn off and on again LinuxCNC is helping, but it is not a solution. In machine status I didn't find any interesting thing. Every parameter look same when working normally and when stuck in reading state.
For example if first line is G01 Z5 F100, and when I manually move axis to Z10, then first line of program will be executed, and machine stuck, next line is simple G01 X1 Y1 F100. MDI commands not working then also.
Thank You in advance
  • nanowhat
  • nanowhat
26 Jul 2025 06:15
Replied by nanowhat on topic Controlling existing motors with resolvers
Category: Driver Boards
 i have resolvers that do not work with 7i49,
your particular resolver type.
How can I tell what type of resolver I have?
  • AkkiSan
  • AkkiSan
26 Jul 2025 03:30
Probe tripped during non-probe move deadlock
Hi all,
I am running 2.8.4 and only recently noticed that none of my
(indeed very old) touch probe scripts/o-codes do run nowadays.
With this "new" (v2.8) probe behaviour, which seems to be activated
all the time - how am I supposed to move the probe, including bouncy
ones, off the material after it triggered?
As long as the probe is activated, all (G00/G01) commands fail and
immediateely abort the program.
That also was recently added to the repo tracker (not by me though :)
github.com/LinuxCNC/linuxcnc/issues/292
This behaviour makes it basically impossible to probe more
than one time, e.g. a grid etc.
Is there any workaround or am I missing something (new)?
AS
  • Benb
  • Benb's Avatar
26 Jul 2025 03:07
there are DMC2 31025P for sale on eBay but they are no cheap. As an alternative the Copley Controls Xenus servo drive. they take resolver input but you would need to have look at the manual (manual is online) and determine if it does accommodate your particular resolver type.
  • PCW
  • PCW's Avatar
26 Jul 2025 03:03
Replied by PCW on topic limit switch problem
Not sure if this is a pncconf version issue but current pncconf does this:
# external input signals
# --- HOME-X ---
net home-x     <=  [HMOT](CARD0).inm.00.input-00
# --- HOME-Y ---
net home-y     <=  [HMOT](CARD0).inm.00.input-01
# --- HOME-Z ---
net home-z     <=  [HMOT](CARD0).inm.00.input-02
From this:
In your hal file you have# --- MIN-X ---
net min-x <= hm2_7i96s.0.gpio.000.in_not
but net-min-x is not connected to anything so is not functional
the actual signals connected are these (also from your hal file)
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
so if you changed
# --- MIN-X ---
to
# --- MIN-X ---
net x-home-sw <= hm2_7i96s.0.gpio.000.in_not
you should get some function
(I am glossing over the difference between the INM inputs and GPIO inputs
as they can be used interchangeably on the 7I96/7I96s, that is GPIO 0..10
behave the same as INM 0..10)
  • nanowhat
  • nanowhat
26 Jul 2025 02:25
It seems that Glentek makes servo drives that can take input from resolvers for commutation, and emulate a quadrature encoder for other uses.
I've sent them an RFQ.
26 Jul 2025 01:40
HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
Category: Show Your Stuff
It cuts metal pipes/tubes/profiles using a 4KW laser.
Sorry if i was unclear.
I will fix the tittle now, thank you for pointing it out.
  • jmelson
  • jmelson
26 Jul 2025 00:36
Replied by jmelson on topic Controlling existing motors with resolvers
Pico Systems has a small board that converts a resolver to look like a standard quadrature encoder. Unfortunately, it can't provide commutation signals, but does provide an index pulse. This board will not work with variable reluctance resolvers, but is designed for "brushless" resolvers such as those made by Harowe Controls and Singer Kearfott. See:
picosystems.store/product/resolver-converter/
for more info.
There are AC servo drives that can operate without the commutation signals, these are often called "sensorless drives".
Jon
Displaying 11761 - 11775 out of 17293 results.
Time to create page: 0.442 seconds
