  • kn612
  • kn612
23 Jul 2025 01:49
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
Thank you so much.  I was able to create a 7i97t config.  No errors on starting or shutdown.  The 7i97t stays connected.
23 Jul 2025 01:04
Replied by tommylight on topic RIP
RIP
He was one of the wild ones, RIP.
  • unknown
  • unknown
23 Jul 2025 00:55
RIP was created by unknown
RIP
  • SebastianM
  • SebastianM
22 Jul 2025 21:25 - 06 Aug 2025 19:17
"KeyError" suddenly appears after moving a limitswitch
Category: QtPyVCP
Hey guys!
My linuxcnc / probebasic started to show a weird behaviour today.
After I start the system and home the machine, I get a popup saying "KeyError" _everytime_ when I jog any of the axes.
I can ignore that message, but it comes back everyime I jog again (no matter if via keyboard, softkey or pendant).
BUT - what I found out... as soon as I zero one of the axes (or all three), the error is gone.
I have not changed anything in my (software) config the last week, BUT I have modified my x axis yesterday and therefore moved the limitswitch a bit.
Can this somehow be related? The popup says somewthing with "...active.WCSoffset..."... maybe some cached value doesnt fit anymore after I moved that switch?
Thx in advance!
  • PCW
  • PCW's Avatar
22 Jul 2025 20:07 - 22 Jul 2025 21:49
Replied by PCW on topic How to control brake before moving ?
Category: HAL
net canMove not.0.out => stepgen.3.enable
My guess is that this causes the following error
when motion starts and this is still false.
That is, the commanded position is changing but
the stepgen is disabled so cannot follow ( so the
stepgen feedback is static) so you get a
following error.
Edit:
If linuxCNC is allowed to start motion before the brake is released,
Expanding the following error limits seem like the easiest solution.
However now this joint will lag the others so coordinated motion would
not be possible.
Is there some way to use digital inputs and outputs in the
gcode to manage the brake? That is, use a digital output
to enable the brake and a digital input to signal when the brake was
full applied and fully released. You would do this using M62,M63 and
M66 in the gcode and the hal digital input and output pins.
www.linuxcnc.org/docs/devel/html/gcode/m...e.html#mcode:m62-m65
  • scsmith1451
  • scsmith1451's Avatar
22 Jul 2025 20:06
Replied by scsmith1451 on topic Set program zero using XY positioning laser
If I understand the BUTTON_1_CODE correctly, the G10 L20 P0 coordinate system is always offset to the fixed values defined by X and Y. How does positioning the cross-hairs to a difference starting position translate the offsets to the new location correctly?
  • Aciera
  • Aciera's Avatar
22 Jul 2025 19:00
Replied by Aciera on topic Weird G54 orientation
Well all I can say is that clearly your G54 offset values are wrong. So if those values are set in Fusion then you would need to look there.
Also you have tool offsets not only in Z but also in X and Y which is a bit unusual.
  • vale
  • vale
22 Jul 2025 18:48
Replied by vale on topic Homing Stepperonline A6
Category: EtherCAT
No thanks, i already got it working with the same EL7 homecomp and forgot to update this ;)
Was waiting for the beckhoff modules to arrive and got them today, so i can finally continue now!
  • bladekel
  • bladekel
22 Jul 2025 18:33
How to control brake before moving ? was created by bladekel
Category: HAL
I have an axis that I use with a stepper motor with brake. Before this axis starts moving, I have to disable the brake, wait for the mechanical delay and then move it. And when the movement is finished, I have to activate the brake immediately. I used the following commands to do this.
loadrt ddt count=1
loadrt abs count=1
loadrt comp count=1
loadrt timedelay count=1
loadrt not count=1
addf ddt.0 servo-thread
addf abs.0 servo-thread
addf comp.0 servo-thread
addf timedelay.0 servo-thread
addf not.0 servo-thread
# Joint 3 movement detection
net joint3-pos-cmd joint.3.pos-cmd => ddt.0.in
net joint3-velocity ddt.0.out => abs.0.in
net joint3-vel-abs abs.0.out => comp.0.in0
setp comp.0.in1 0.001
setp timedelay.0.on-delay 0
setp timedelay.0.off-delay 1
net joint3-moving comp.0.out parport.0.pin-14-out timedelay.0.in
net dontMove timedelay.0.out => not.0.in
I can do what I want in manual movement with these commands. But when I use it with mdi commands, it gives “joint 3 following error” error.
How can I solve this?
  • dunnitagain
  • dunnitagain
22 Jul 2025 18:22
Linuxcnc 2.4.5 with Ubuntu 10.04, Correct file path or structure ?
That makes sense , this has Linear Scales for Feedback with Steppers.
  • Todd Zuercher
  • Todd Zuercher's Avatar
22 Jul 2025 17:55
Todd , what do the halscope files do ? Are they a test ? All the Bios settings appear to be correct , to allow the Boot from ISO, tried several times with Tommies advice , still no luck.
The halscope files are saved from the Halscope oscilloscope app. They are merely a record of the scope settings and signals that were being used at the time it was saved. So for example I have some Halscope files saved for the settings I use for tuning each of the servos on one of my machines. Using them makes opening and configuring Halscope quicker when doing something you might need to do the same again later or after a restart. But they certainly are not needed for running Linuxcnc.
  • kworm
  • kworm
22 Jul 2025 17:45
Replied by kworm on topic Servo Driver Plasma Retrofit
Category: Plasmac
You would replace /usr/bin/pncconf with the pncconf.py file, ie "sudo mv pncconf.py /usr/bin/pncconf". You might also need to do a "sudo chmod +x /usr/bin/pncconf". I would suggest making backup copies of those files first just in case.
  • claytoncramer
  • claytoncramer
22 Jul 2025 17:19
Is mini still available? was created by claytoncramer
Category: Other User Interfaces
I just upgraded from 2.7.14.  (No laughing please.)  I find the other supported guis not as friendly.  They have features of no value for a Sherline mill.
  • rubinstu
  • rubinstu
22 Jul 2025 16:51
Replied by rubinstu on topic Weird G54 orientation
Any have any thoughts on this? I'm kind of stuck! Thanks
  • Kieran
  • Kieran
22 Jul 2025 15:49
Fusions CAM drives me crazy - Axis out of bounds
Category: Fusion 360
It sounds like something was up with your offsets. Are you using g54? Make sure to switch into g54 or 55, 56, ect before touching off. That, or maybe you had cutter comp on and a large diameter in the tool table?
Displaying 11881 - 11895 out of 17299 results.
Time to create page: 0.328 seconds
