  • EIRE
  • EIRE
21 Jul 2025 14:51 - 21 Jul 2025 14:52
Replied by EIRE on topic Biesse Rover B2.30 LinuxCNC
I just ran into this very Controller Card:
YASKWA BIESSE HSD CNI P601C H0501D601C + P602C
I thought to make a few comments on your post 5 years later.
This card is on the original PCI Architecture (ie. Not PCI Express) which means that the best computers to use for these are the newest that run the correct PCI voltage, which is the DELL GX520 and the DELL GX620. After that, it seems the voltage changes somewhat in the post 2007 computers.
I have done a fresh install of Windows XPSP1, and BIESSE 2.2 with the SP2 patch
I have slapped on 4GB (3GBmax for win x32) and at some point going to source an IDE SSD drive to speed things up.
I think you will find that XP32SP1 is actually very stable.
There are a few fringe PCI to PCI express converters out there, in order to be able to use newer tech (Virtualisation maybe?) but I am a bit worried that I FRY the YASAKAWA board.
I think in about another 5 years, someone is going to be on here looking for a solution since these 2006 computers are getting a touch harder to find,
  • rocket6delta
  • rocket6delta
21 Jul 2025 14:48
Replied by rocket6delta on topic 7i76EU Hal and Ini File
Category: HAL
Yes I have DMM Dyn 4 servos.
So the drives are disabled when the enable input is powered? This seems backwards to me. So would removing power enable the drives?
  • dunnitagain
  • dunnitagain
21 Jul 2025 14:22
Linuxcnc 2.4.5 with Ubuntu 10.04, Correct file path or structure ?
I used Rufus like you suggested Tommylight. Tried Multiply times.
Is there anyway , you could help me over the phone? I would pay you.
21 Jul 2025 14:02
Use Rufus or Balena Etcher to write the image to USB, those usually work on first try.
21 Jul 2025 14:00
Replied by tommylight on topic Hal Config 5i24+7i52+8i20
Category: Driver Boards
Moved to "driver boards".
  • PCW
  • PCW's Avatar
21 Jul 2025 13:36
Replied by PCW on topic PlasmaC Voltage Divider
Category: Plasmac
The resistor(s) go in series with the plasma voltage  to the negative THCAD input
Safety wise the resistors should be in the plasma source itself.
  • dunnitagain
  • dunnitagain
21 Jul 2025 13:26
Todd , what do the halscope files do ? Are they a test ? All the Bios settings appear to be correct , to allow the Boot from ISO, tried several times with Tommies advice , still no luck.
  • kn612
  • kn612
21 Jul 2025 13:23
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
Thank you for the help guys.  I am still building the computer/cnc.  Wiring the mesa hardware is all that's left.
With that said I am having issues installing Debian 12.  On install I get a bad mirror error.  Once installed sudo apt update gets a few repository errors.  I believe this is all from not being connected to Internet during the install.  Using a USB Wi-Fi dongle that is missing the driver during install, but once booted into Debian 12 is works.  I will try using Ethernet to connect to Internet on the next install.
With that said, are there any eatx or atx motherboards that work well out of the box with Debian 12?  I am using a dell optiplex 9010 motherboard that I put into an old hypertherm microdedge CNC case.
  • jlennox
  • jlennox
21 Jul 2025 13:16
Replied by jlennox on topic Control panel for Gmoccapy
Category: Gmoccapy
Very neat design you have.
What keycaps are you using and how are you doing the symbols / lettering, laser engraving?
  • krille
  • krille
21 Jul 2025 12:45
Raspberry p15 and linuxcnc 2.9.4 spindle speed
Category: Installing LinuxCNC
Hello I have Raspberry pi 5 and byte 2 bot hat on my mill and it works very fine and now i try to convert it to my lathe with a problem with the spindle speed reading and the index and phase a for cutting thread in the lathe . I have tried to read and understand the Hal mystery with a minor of luck . In Hal Meter i there are a signal at => lowpass.0.in but reading zero at  lowpass.0.out  => abs.0.in pyvcp_options.hal . Can somone helpfull help me with this problem / krister
  • stegrg
  • stegrg
21 Jul 2025 12:22
Hal Config 5i24+7i52+8i20 was created by stegrg
Hello,
I'm trying to find a simple HAL file to configure Hudson BLDC motors in qhi mode.  I have them running in h mode and qh mode, but I can't seem to get it running in qhi mode.  When I run it in qhi mode, the motor seems to spin only in h mode and doesn't switch to qi mode.  Does anybody have a simplified HAL file test script similar to the ones used in the following link for qhi mode?
forum.linuxcnc.org/forum/39-pncconf/2721...ting-up-5i257i858i20
Regards,
  • JT
  • JT's Avatar
21 Jul 2025 11:43 - 21 Jul 2025 15:58
Spindle Docs was created by JT
Spindle Docs
Category: LinuxCNC Documents
linuxcnc.org/docs/stable/html/getting-st...tion_files_for_2_9_y
Shows 4 configuration options for the ini file that don't limit the spindle rpm in any way, are these for master only?
4.1. Spindle limits in the INIIt is now possible to add settings to the [SPINDLE] section of the INI file
MAX_FORWARD_VELOCITY = 20000 The maximum spindle speed (in rpm)
MIN_FORWARD_VELOCITY = 3000 The minimum spindle speed (in rpm)
MAX_REVERSE_VELOCITY = 20000 This setting will default to MAX_FORWARD_VELOCITY if omitted.
MIN_REVERSE_VELOCITY = 3000` This setting is equivalent to MIN_FORWARD_VELOCITY but for reverse spindle rotation. It will default to the MIN_FORWARD_VELOCITY if omitted.
JT
  • Aciera
  • Aciera's Avatar
21 Jul 2025 11:08
Replied by Aciera on topic (solved) python error on startup
As the error message indicates:
print "change_prolog: Toolchanger soft fault %d" % int(self.params[5601])
Is invalid syntax for python 3. Possibly you imported the 'nc_files' folder from an older version of linuxcnc?
You might want to replace your "nc_files/remap_lib" folder with the one available here:
github.com/LinuxCNC/linuxcnc/tree/2.9/nc_files/remap_lib
  • Todd Zuercher
  • Todd Zuercher's Avatar
21 Jul 2025 11:02
In the zip file you posted the only "extra" unneeded files I see are all of ones ending in ".halscope". You can safely delete all of those without causing any harm.
As to your issues with booting to live media or reinstalling Linuxcnc. You probably need to turn off those protections in the computer bios, and to do that may require the password to enter the bios editor. If you've forgotten the password, it might be possible to reset this by removing the cmos battery, to return the bios to its default settings.
  • Todd Zuercher
21 Jul 2025 10:30
Replied by Todd Zuercher on topic Axis Modifications
Axis Modifications
Category: AXIS
I've also found the included file browsing/file open ap within Axis to be very limiting to use. The work around we often used was to use the file browser of your choice on your Linux desktop to find the g-code file you want to run, then with a right mouse click use the "axis-remote" command to open to open the g-code file in Axis directly from the file browser. This was especially helpful when wanting to run files saved in network directories that you could not easily find or access using file open in Linuxcnc.
I don't know if this works using other Linuxcnc GUIs or if any of the other GUIs offer an equivalent command to axis-remote that can be used to open a g-code file from another file browser.
Displaying 11956 - 11970 out of 17310 results.
Time to create page: 0.525 seconds
