  • cmorley
  • cmorley
07 Jul 2025 00:08
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
pushed the 'last run line' log - see what you think.
  • SjCNC
  • SjCNC
06 Jul 2025 23:54
Replied by SjCNC on topic Please help with adding laser control
Category: Plasma & Laser
I've got to get better at asking the right questions... Using the old config:
signal 'sj'
motion.analog-out-00, and
hm2_7i76e.0.pwmgen.00.value
All these values update as M67 changes the output.
hm2_7i76e.0.gpio.017.in toggles to True when the gcode starts running.
Does everything seem mapped right for the PWM to reach pin 1 on a 5 axis breakout board? Should that be on hm2_7i76e.0.gpio.017.in? Maybe the code is fine, and I should be chasing down a hardware issue?
  • dunnitagain
  • dunnitagain
06 Jul 2025 23:15
Failed Parallel Port on system, Recommended Easiest Upgrade Solution ?
I did find a USB Stick with a full back up set of files. I know the hardware must be fine , I transplanted the computer from the other mill. It would make the steppers at least jump. The computer would not even boot from the ISO so I could reload the OS.
  • cmorley
  • cmorley
06 Jul 2025 23:09
Category: Qtvcp
I wondered if you posted the wrong file :)
I fixed the screenoption colors and axis button LED color on 4th and 5th axis?
I could not get those tool buttons be the same size - ran out of patients!
I agree with Tommy, the one on the right.
Almost got the last line number request done...
06 Jul 2025 22:45
Replied by tommylight on topic Need help with Controller boards
Category: Driver Boards
See the pinned topics at the top of the page, especially the Remora with SPI as it uses 3d printer boards.
See also other topics there, might be something you can find in Turkey.
forum.linuxcnc.org/18-computer
  • 44pixel
  • 44pixel
06 Jul 2025 22:38
Need help with Controller boards was created by 44pixel
Hello,
I just joined the forum since I'm making good progress with my PRINTNC project. I want to use 4 closed loop step motors (2 steppers for z axis). I keep look around but everyone is using a MESA boards or a raspberry pis with some kind of adapter boards for connecting the stepper drivers.
  I live in Turkey and I can't get anything through customs that's over 30 Euros I can't get the MESAs or the adapter boards for raspberry pis (No shipping to Turkey). BUT I have access to 3D printer control boards. like BTT Manta M8P and MKS SKIPR V1 or MKS Tinybee. Is something possible with these?
I would be very glad if you can point me in some direction. Thank you.
  • PCW
  • PCW's Avatar
06 Jul 2025 22:27
Replied by PCW on topic Please help with adding laser control
If you don't want to use your old config, you could simply copy all the
lines from the old hal file that contain 'pwm' and import them into your
new hal file.
  • Benb
  • Benb's Avatar
06 Jul 2025 22:18
Replied by Benb on topic Please help with adding laser control
My suggestion is to use:
www.diffchecker.com/
I tested by cutting/pasting your previous and new files; it shows the difference and it gives you the ability to merge the differences line by line.
06 Jul 2025 22:09
Replied by tommylight on topic Error in tool_offsetview.py
Category: Qtvcp
2
  • 44pixel
  • 44pixel
06 Jul 2025 21:56
Replied by 44pixel on topic Potential All-in-One Single Board Computers
Hi I can give this a try with BIGTREETECH Manta M8P and closed loop stepper motors and drivers. If you can help me with the wiring and everything.
  • MarkoPolo
  • MarkoPolo
06 Jul 2025 21:32
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Recording works fine now, thanks for the fix.
I see a few more wrong button dimensions in the qtdragon vert file, I'll fix that. (I think I didn't send the right file)
Which jog button layout is better?
  • PCW
  • PCW's Avatar
06 Jul 2025 21:26
Adding external switch for emergency stop and feed override
Category: Basic Configuration
The 7I95/7I95T has no analog input so an encoder is probably a better choice
( Using either a high speed encoder or a MPG on the isolated inputs )
Another possibility is to add a 7I73 which has analog/encoder/keypad support
  • SjCNC
  • SjCNC
06 Jul 2025 20:46
Agreed, this has had me stall posting for a few weeks...Pretty sure I was using 2.7.14 when setting up the 7i76e, and 2.8.2 most recently.I've not been great with version control, while moving across computers and machines. These might be the last working files, but unsure...  Laser signal as 'sj' in line 39
  • marked23
  • marked23
06 Jul 2025 19:20
Replied by marked23 on topic Grizzly G1006 with Servos
Category: Show Your Stuff
Servo box inner bits:
Spindle SSR:
Pendant box inner bits:
This whole board, just to read the MPG, and inject some keyboard commands.
Keyboard passthrough:
  • Benb
  • Benb's Avatar
06 Jul 2025 19:15
I think it would be helpfull to mention your previous os version and linuxcnc version, also include hal and ini pre-overhaul when the machine was operating properly.
Displaying 12556 - 12570 out of 17355 results.
Time to create page: 0.397 seconds
