  • slowpoke
  • slowpoke
29 Jun 2025 19:25
Emulating lathe compound angle via manipulation of X & Z drives
Category: HAL Examples
I have not used the anglejog component other than playing around with the sim config. As I understand it the 'scale' factor is used to avoid stair stepping in the tool path. Maybe the original discussion can give you some more clues:
forum.linuxcnc.org/38-general-linuxcnc-q...mode?start=10#253252
[edit]
I would tend to use the default values used in the sim config and adjust the
'max_vel',  'max_accel' pins (and possibly 'accel_fraction_in' for fine tuning)
Thanks for your help. I should play with the sim config, I'm not sure how to do that?
Okay, figured out what I was doing wrong (anglejog.N.iscale-factor), so I now have angle jogging working.
Thanks for all your help!
  • JT
  • JT's Avatar
29 Jun 2025 16:37
Replied by JT on topic Mesa Configuration Tool
Category: Configuration Tools
I was generating the bit string backwards which only worked right if all output types were the same. I just fixed that with PCW's help. The inputs and outputs hal has just been fixed as well.
JT
  • PCW
  • PCW's Avatar
29 Jun 2025 16:26 - 29 Jun 2025 16:27
homing with Phase Z encoder on MESA 7i96s
OK that means that index is working as expected, so if homing
to index fails, its likely a homing setup issue.
  • SebastianM
  • SebastianM
29 Jun 2025 16:10 - 29 Jun 2025 16:14
Replied by SebastianM on topic Mesa Configuration Tool
Another remark.. not sure if that me misunderstanding anything or if its another bug, but witih MesaCT I generated a config to set my outputs 0-7 to sinking and 8-15 to sourcing.
This were the generated lines:
setp hm2_7i76e.0.7i76.0.0.output_sink 0xff00
setp hm2_7i76e.0.7i76.0.0.output_source 0xff
isnt this "the wrong order"? imho this sets 0-7 to source and 8-15 to sink.. right?
  • kn612
  • kn612
29 Jun 2025 15:34
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
Yes.  Here is a schematic that goes from the interface PCB to the hypertherm microedge for the drives.  I'm only familiar with stepper motors at this point so this is a little overwhelming.
  • SebastianM
  • SebastianM
29 Jun 2025 14:30
Thx JT for the quick reply!
  • besriworld
  • besriworld
29 Jun 2025 14:27
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
Hello again, it's been a while. I'm now back working on the lathe machine. I connected the Modbus to the X and Y axis servo motors and also to the spindle – all working fine. I can read the load values from the servo motors without problems. But there is an issue with the spindle load display. Sometimes it shows too many zeros after the decimal point. I tried to fix this with Python code to cut the extra zeros, but I couldn't make it work. Has anyone had this problem before?
What is the easiest way to fix it?
  • JackRay
  • JackRay
29 Jun 2025 14:07 - 29 Jun 2025 16:23
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
so I tested it and switched the red button to yellow. and it turned red at the same position when I turned my encoder.
  • PCW
  • PCW's Avatar
29 Jun 2025 14:03
setp [HMOT](CARD0).encoder.00.index-enable true
This is wrong and should be removed
Also: Is the encoder position cleared to 0 when you set b-index-enable?
(set in the halshow:watch tab)
  • Silverback
  • Silverback
29 Jun 2025 13:16
[qt_dragon_hd] auto tool probe and gcode display issue
Category: Qtvcp
I am not sure what you mean by simulate the auto tool config.
Is that in a simulation config? I have never messed with those.
Sorry to be such a neophyte.
  • slowpoke
  • slowpoke
29 Jun 2025 12:51 - 29 Jun 2025 12:57
[edit]
  • JT
  • JT's Avatar
29 Jun 2025 12:45
That's a bug with the 7i76eu I/O section. I'll fix that.
JT
  • kubes
  • kubes
29 Jun 2025 12:16
User error or a strange event on probing. Broken ruby tip.
Category: QtPyVCP
Is there any logging behind the scenes to know that really happened? As this was working reliably in the past, I was not 100% focused on watching it. It would be good to know when it was tripped and what the feed rate and direction were.
  • RNJFAB
  • RNJFAB
29 Jun 2025 10:24
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
Machine is going great and now its time to start adding more.
So firstly - ohmic sensing with the 7i96 board?? i'm sure i have see how this connects, but for the life of me cant work it out. Hookup is simple enough, configuration is what's got me.
Secondly - Air scribe. Hardware is all together. just need to get the post to work for it in sheetcam.
Links to help if you have them please.
& Video's for when you are bored.
www.youtube.com/shorts/XuxqHAO2k5w
  • aeth
  • aeth
29 Jun 2025 10:06
Why does motion planning use linear interpolation instead of b-splines?
I see, but for cutting aluminium (i.e. my machine runs at 4000mm/min with a 8mm tool) and high speed machining applications, I'd say this probably starts to play a much bigger role?
Displaying 12826 - 12840 out of 17371 results.
Time to create page: 1.165 seconds
