  • RotarySMP
  • RotarySMP's Avatar
03 Jun 2025 18:54
Replied by RotarySMP on topic Index homing Heidenhain ls 403/exe602
Category: Basic Configuration
Mine are old, so just basic LS403's with a single index. Sorry for that confusion.
Mark.
  • PCW
  • PCW's Avatar
03 Jun 2025 18:31 - 03 Jun 2025 18:32
Replied by PCW on topic Servo tuning Step/Dir
Typically there is not much advantage in using encoders on step/dir systems
unless you have linear scales.
If you get following errors, I would first increase this number:
setp hm2_[MESA](BOARD).0.dpll.01.timer-us -50
to:
setp hm2_[MESA](BOARD).0.dpll.01.timer-us -200
Also check that the stepgen maxaccel values have sufficient headroom
from the joint and axis maxaccel values.
The stepgen values should be at least 25% greater than the joint/axis
values if no backlash compensation is used and at least 225% of the joint/axis
values if backlash compensation is used.
Also check
hm2_7i95.0.packet-error-total
To make sure no packets are being dropped due to network timeouts.
  • Sternfox
  • Sternfox
03 Jun 2025 18:16
Servo tuning Step/Dir was created by Sternfox
Hi Guys,
I have a converted hass mini mill running 1kw Ac servos, I am using them in Step and Direction mode. At the moment, they are not feeding back into my Mesa 7i95T.
First question is there any benefit to feeding the encoder back to the controller?
And can/should I tune the PID? im at the understanding that this is only for analogue drives?
I am getting the occasional follow error, Im set at 1 and 0.5 which is really high. and im only running at 6000mm/s
Any advice would be great.
Tnanks
  • PCW
  • PCW's Avatar
03 Jun 2025 18:15 - 03 Jun 2025 18:17
Servo Oscillation Issue at ±6.6V 5i25 + 7i77, Analog Control
Does the division change the point at which you get oscillations?
Did you check that the  7i77s 5V is stable?
625 counts per mm is certainly low enough ( < 100 KHz count rate at 8.3 M/min )
  • Traken
  • Traken
03 Jun 2025 17:40
What division do you propose, I tried the lowest 625 per mm.
  • Groovecooper1
  • Groovecooper1's Avatar
03 Jun 2025 17:19
Replied by Groovecooper1 on topic Need help with Linux 2.5 on a CNC lathe
Hello got everything up and running the machine will home. I keep getting the same error and I’m not able to run a program. I am not skilled at writing G code, but hopefully this is a quick fix. Any assistance is greatly appreciated
  • Sternfox
  • Sternfox
03 Jun 2025 17:17
Replied by Sternfox on topic Cant get spindle RPM to display
Category: QtPyVCP
amazing it works thank you, just need to change it so its not a minus sign before the reading
  • alexandrap
  • alexandrap
03 Jun 2025 17:16 - 03 Jun 2025 17:18
Replied by alexandrap on topic Updating pncconf for 7i95t
Category: PnCConf Wizard
I don't have a Mesa CT2 file created yet - I'm still hoping to find a "pure" way to create it via pnconfig in one step - without inserting lines.
I have a small lathe that I would like to use in 3 configurations - as a lathe, as a milling machine (I have a milling attachment for the lathe) and as a rotary table, when the additional spindle (which will be classically driven via an inverter) will be on the support.
my machine:
www.youtube.com/channel/UC_zOVvs96VKX6R_DIO5KyJg
  • Aciera
  • Aciera's Avatar
03 Jun 2025 16:56
Replied by Aciera on topic xml and hal - I am lost
Category: EtherCAT
There is a tutorial to get a working config for the EK1100. Maybe that is something to start with:
github.com/pklopping/linuxcnc-ethercat-b...asic_digital_outputs
For the drives there is this example config:
github.com/dbraun1981/hal-cia402
  • Kieran
  • Kieran
03 Jun 2025 16:41
Replied by Kieran on topic xml and hal - I am lost
Category: EtherCAT
Im in the same boat. I have stepperonline A6 servos showing up as slave devices. now have no clue what to do next.
  • Kieran
  • Kieran
03 Jun 2025 16:33
GUI that somewhat resembles haas or fanuc workflow.
Im thinking I can send-cut-send a panel, with switches as desired, and use a keyboard USB "brain" to read them. then basically map them however needed at that point. that's the easier part for me. Learning the computer/software GUI stuff is gonna be a learning curve.
  • juliankoenig87
  • juliankoenig87
03 Jun 2025 16:30
Replied by juliankoenig87 on topic EasyProbe + PGFUN 3D probe
The drives are 33 years old and the machine was in service till this year on a nearly daily basis. And again. The drives are known for having problems with the tantals. I dont want to have problems later on which I could had easily avoided.
  • Hakan
  • Hakan
03 Jun 2025 15:20 - 03 Jun 2025 20:16
Replied by Hakan on topic Ohmic sensing with IPTM-60
Category: Show Your Stuff
Schema here
  • PCW
  • PCW's Avatar
03 Jun 2025 15:03
Replied by PCW on topic Cant get spindle RPM to display
Category: QtPyVCP
One way:
in the main hal file add:
net spindle-vel-rpm hm2_[MESA](BOARD).0.encoder.00.velocity-rpm
in the gui hal file delete:
net spindle.0.revs  => qtpyvcp.spindle-encoder-rpm.in
and add:
net spindle-vel-rpm  => qtpyvcp.spindle-encoder-rpm.in
Displaying 13936 - 13950 out of 17425 results.
Time to create page: 2.025 seconds
