  • Soccer Kid
  • Soccer Kid's Avatar
03 Jun 2025 07:36 - 03 Jun 2025 07:37
Replied by Soccer Kid on topic ethercat-conf.xml pdoentry limits?
Category: EtherCAT
The PDO entries of the EtherCAT master are 128 in number. Any error will occur if the number exceeds this limit. For the same type of enumerated points, you can use the abbreviated form for writing. For example:<pdoEntry idx="6000" subIdx="01" bitLen="32" halPin="bit-in" halType="bit"/> Here, an input point with a sub-index ranging from 1 to 32 is declared.
  • Soccer Kid
03 Jun 2025 07:06 - 03 Jun 2025 07:07
resolved-- Regarding the data reading offset issue of the ether cat IO module
Category: EtherCAT
Dear friends, hello everyone. Regarding this issue, due to the busy work, it has been a week since then. Currently, we have basically understood the problem. I extracted two different Ethercat master station data from Wireshark and conducted a comparative analysis. From it, we can see that the entries of the PDO have a slight difference in the arrangement order. The main difference is reflected in the two special status words, namely " {0xf200, 0x01, 16}," and  {0xf100, 0x01, 16}. We are currently in contact with the manufacturer to confirm these two PDO entries. These two entries are used for a special design. Additionally, there is a problem with the parsing data of the data sent from IGH to PDO by the IO module!
  • Traken
  • Traken
03 Jun 2025 06:30
Servo Oscillation Issue at ±6.6V 5i25 + 7i77, Analog Control
Category: Basic Configuration
After a long break I'm back to the topic. I did some research, tried to swap the wires between the mesa and the servopack, but no changes. It's not a problem with the analog voltage as in the topic because if I set P=0 I can normally drive at high speed without a closed loop.
What should the encoder accuracy be set to?
Maybe I have set the scale too large or too small?
But I tried changing it to less and it didn't have any effect.
I'm still wondering if the analog wire can go parallel to the encoder wire, maybe it creates some interference.
  • Tom369
  • Tom369
03 Jun 2025 06:14
Problem: Analog jog via gamepad does not move axis in LinuxCNC
Hello do you mean that instruction:
Simple Remote Pendant using a $10-20 joypad with halui and hal_input
The .zip downloadlink sdly doesent work anymore.
  • jtrantow
  • jtrantow
03 Jun 2025 02:54
I use analog jog on all three of my machines with 2.9.4. Quite a while ago, I updated the wiki for remote pendant including .hal files you can include.
  • spumco
  • spumco
03 Jun 2025 01:26
GUI that somewhat resembles haas or fanuc workflow.
You don't need to make a custom keyboard, a standard keyboard has losts of "useless" keys which you can repurpose for your needs.
"Need" has nothing to do with it.  GUI's and physical interfaces are deep in to the realm of personal preference... so there is no right answer for everyone.
If a body wants a user interface - screen and physical - which mimics typical industrial control panels then there is a certain layout, workflow, and feature-set they're likely to prefer.
I suspect that repurposing some keys on a standard keyboard is unlikely to tickle thier fancy.
Of course, everything I've posted above is based on my own preferences regarding CNC interfaces.
  • spumco
  • spumco
03 Jun 2025 01:11
My Bosch cooktop freaks out with a drop of water; it's really annoying.
AFAIK, touchscreens basically work by detecting the water in your fingers (fingers, like most of the body, contain lotsa water); so actual water can triggger them.
However, water will likely break a mechanical keyboard/switch if not dried promptly.
(Membrane keyboards are probably fine.)
Resistive touchscreens have an outer flexible panel, a sheet of invisible contacts, and an inner glass layer.  When you press the outer surface the contacts in that location are physically closed and the computer registers a touch.  They generally can't do multi-touch, but they do work with gloves of any type and require a firm enough press that anything bouncing, hitting, or splashing on the screen is unlikely to activate it.
The other nice thing about resistive screens is that you can tape a sacrificial piece of clear plastic over the top to protect it.  Once that gets scratched or dirty, replace... and the touch function still works.
A membrane keyboard is certainly water/coolant resistant, but even if the contacts are rated for a billion presses the overlay wears out and then the whole thing is junk.  Also they may not have a great tactile feel, especially for typing.
There are some rather good waterproof panel-mount keyboards available these days, either from ebay or Aliexpress. Many configurations - with/without touchpads or trackballs, stainless fronts, different key combos.  The one I got recently has a stainless face and keys, but the actual tactile switches are under a continuous sheet of rubber - no water ingress.  I wouldn't want to type a novel on it, but it feels quite good for a very robust keyboard.
I have Cherry mx keyboard switches on my mill control panel and have had no issues with coolant or chips damaging the switches.  Unless the switch panel is horizontal (or nearly), any liquid splashing on the panel is likely to drain down before it gets to the switch contacts or mechanism.  What kills mechanical keyboards is dumping a quart of sugary soda on them until the mechanical bits are submerged and they get glued in place.
The proliferation of people making a living banging away on keyboards means there's been an explosion of mechanical keyboard parts, instructions, and related stuff available for a few years to consumers:
  • Sockets for Cherry mx-type switches that solder to a perf board.  Meaning if a switch fails it's extremely easy to replace.
  • Clear switch caps for inserting your own legends
  • Multiple switch 'feel' varieties
  • Aftermarket springs to stiffen up the action (even the stiffest 'stock' switch feels pretty limp compared to industrial pushbuttons)
  • Vendors eager to machine/cast/print custom buttons
  • Online keyboard layout generators with standardized key spacing and templates
02 Jun 2025 23:25
Replied by tommylight on topic Toyota embroidery machine - retrofit
Category: CNC Machines
I think the potentiometer is being used as an absolute position feedback device.
(probably meaning that the long shaft only turns a few times)
+1
  • atrex77
  • atrex77's Avatar
02 Jun 2025 23:18
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
guys, a littlebit of play with the design is get the ninja look. :)
  • PCW
  • PCW's Avatar
02 Jun 2025 22:29
Replied by PCW on topic Toyota embroidery machine - retrofit
  • spumco
  • spumco
02 Jun 2025 22:23
yeah touch screen would work. But what happens when some drops of coolant hit it and it freaks out. my phone is bad enough with a tiny drip of water. :side: I wonder if itd be worth making a custom keyboard and special mapping some keys. QTdragon looks nice. I may give it a try.
Look for a resistive touch screen.  They're a little harder to find nowdays, but they are significantly less likely to trigger from a drop of coolant, errant fly, or other unintended activation.  Downside is they're a little scratch prone and aren't as bright or crisp as the more modern touch tech.
There are no 'industrial' GUI's currently available which mimic Fanuc or Haas interfaces.  The closest I've seen is an unreleased GUI a gent teased the forum with a couple years ago.  He mentioned that he might make it available to the LCNC community, but I suspect he's got enough work in to it that he (or his company) want to keep it to themselves.
forum.linuxcnc.org/show-your-stuff/47118...ing-some-work#254061
Another close GUI (in my opinion) was "Hazzy", but that's been abandoned for quite some time and won't work with current Linux or LCNC versions.  You can find archived Hazzy stuff on github and searching the forum for screenshots...even if only for ideas.
Gmoccapy is pretty close to commercial GUIs in concept with the bottom/side-row softkeys, but there are some features/quirks which deviate from my experience with commercial offerings.
Touchy has no on-screen jogging (nice) and is, I believe, designed for use with hardware controls.  But it's a little dated or sparse for some tastes.
With a bit of effort, however, you can get close(ish) without having to create a GUI from scratch.  Here's a shopping list of user-possible modifications which can make a GUI more commercial-feeling:
  • Eliminate mouse
    • resistive touchscreen
    • trackball/trackpad in a panel-mount keyboard
  • Dedicated hardware CNC function keys
    • Using a Mesa 7i73 and matrix keypad you can have (up to) 64 hardware keys programmed to do whatever you want.  Keys need not be physically in an 8x8 matrix - just electrically.
    • With some relegendable buttons or keys and a 3d printer you can create a CNC panel that's very close to whatever flavor Fanuc/Haas/Siemens you want.
    • There are plenty of other ways to get dedicated hardware buttons, but using the 7i73 means no USB latency and it's very easy to configure.
  • Eliminate keyboard & screen-based jogging/motion
    • Most GUI programs have some ability to edit or restrict keybindings - it's just not obvious without digging.
    • Eliminating on-screen jogging is much harder - that takes editing the interface, although the QT-based screens make it somewhat easier.
    • Be prepared - getting rid of anything on every screen/tab which can cause motion is a monumental effort.  And even when you do get rid of everything, LCNC still doesn't behave like commercial controls.
      • On every commercial control I've used, the machine will not move unless you press cycle start (aside from hardware-button only jogging).  Probing screens, MDI, tool changes, everything... you must press cycle start to make the machine do something.
      • LCNC's ability to accept commands from external sources (python, GUI's, etc) means a GUI author can put a "G0 Z-infinity" button everywhere they want... and pressing that button will make the machine move.
  • Look for a GUI which works with a 4:3 or 5:4 monitor
    • Most commercial GUI's aren't using wide-screen formats, so they don't try to fit everything on a single screen like most 16:9 LCNC GUI's do.  You may be more comfortable with a smaller real estate monitor and more screens to flip through... keeping the essentials on the main page.
  • Tooltable
    • I don't know how to modify all LCNC GUI programs, but I know the QT and QTpy based ones can be modified as to which tool table columns are displayed.
The downside to creating or modifying a GUI is that updating LCNC or the GUI becomes tricky.  And creating a GUI from scratch is a monumental effort.
Hope that helps a little.
  • greg23_78
  • greg23_78
02 Jun 2025 22:07 - 02 Jun 2025 22:09
Toyota embroidery machine - retrofit was created by greg23_78
Hello everyone,
I need your advice on an industrial embroidery machine.
I've managed to recover a Toyota ESP embroidery machine, but it's broken down to the level of the electronic board, I have the impression that it has lost all its parameters, there's a ‘-’ on the screen and then nothing.
I'm going to retrofit it and drive it with linuxcnc.
Following the dismantling of the casings, I have a few questions:
-1: I have a DC 30W servomotor with 500 pt encoder in single ended 5V. and at the end of my axis I have a Copal JC30S potentiometer. Does this potentiometer correspond to a tacho (speed control)?
-2 : On my motor, the maximum voltage is not indicated. To power my machine, I use a power supply that mixes 5V and 24V DC. I assume that its motors are powered by 24V DC, correct? Do you know of any DC driver references for this motor power with tacho (if the potentiometer has one)
  • richcolvin
  • richcolvin's Avatar
02 Jun 2025 22:04
Getting Started with GladeVCP was created by richcolvin
Category: AXIS
I built a few panel using the PYVCP approach, it it seems OK for displaying values but not so good for changing them (e.g., disabling an axis). I think I will need to make the jump to using the GladeVCP, but the manual seems a bit tougher to use for that.  Are there any good references I can use to get started with using Glade?
  • PCW
  • PCW's Avatar
02 Jun 2025 21:38
Mesa card issues Maho MH800E Retrofit Project
In that case you would need
5i25t_7i77_7i74d.bin
firmware
  • Cooped-Up
  • Cooped-Up
02 Jun 2025 20:51
Replied by Cooped-Up on topic Mesa card issues Maho MH800E Retrofit Project
I think I am getting this figured out. I am pretty sure with the loadrt mh2_pci I see it mention the 7i77 now so that should be working I just need to get it to serial mode 3. I also need to figure out how to make the 5i25t communicate with my 7i74 which will be hooked up to the 7i84 and 7i73
Displaying 13966 - 13980 out of 17425 results.
Time to create page: 1.990 seconds
