  • workshop54
  • workshop54
28 May 2025 08:08
Results of latency test, list of computers tested for use with LinuxCNC
I just did the latency test on a Fitlet3 after making some changes to the BIOS and running the script from forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity
LinuxCNC pc tests, version 20200930, started 28.05.2025 09:37:54
General info:
Compulab,  fitlet3
Bios version FLT3.TPM.00.09, dated 06/08/2024
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name    : Intel Atom(R) x6425E Processor @ 2.00GHz
cpu cores    : 4
stepping    : 1
cache size    : 4096 KB
RAM related data:
Maximum Capacity: 16 GB
Maximum Voltage: 1.2 V
Non-Volatile Size: None
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Size: No Module Installed
GPU related data:
product: Elkhart Lake [UHD Graphics Gen11 32EU]
configuration: depth=32 driver=i915 latency=0 mode=1920x1200 resolution=1920,1200 visual=truecolor xres=1920 yres=1200
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager       : Xfwm4
Displaymanager      : lightdm
Kernel related data:
Kernel 6.1.0-35-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet intel_idle.max_cstate=0 idle=poll isolcpus=3 nohz_full=3 rcu_nocbs=3 i915.enable_rc6=0"
Cpu idle driver: none
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: No, which is good!
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Logitech Trackball
Mice  attached to USB:
Keyboards attached to USB:
Logitech, Inc. Keyboard K120
LinuxCNC related data:
LinuxCNC version is: 2.9.4
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID
Command for latency test is:
su johan -c  "latency-histogram --nobase  --sbinsize 1000 --nox 2>&1 | tee -a 1748417872.lat &"
Latency testing loop started Wed May 28 09:38:08 AM CEST 2025,
should end after Wed May 28 11:38:08 AM CEST 2025
Manual termination requested at 28.05.2025 09:54:18
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 53.0°C, Tmax: 61.0°C, (high = +105.0°C, crit = +105.0°C)
Core 1: Tmin: 53.0°C, Tmax: 61.0°C, (high = +105.0°C, crit = +105.0°C)
Core 2: Tmin: 52.0°C, Tmax: 61.0°C, (high = +105.0°C, crit = +105.0°C)
Core 3: Tmin: 52.0°C, Tmax: 61.0°C, (high = +105.0°C, crit = +105.0°C)
last latency data is as follows:.
The final output of the latency test:
^C
Stand by and let me stop gracefully...
  970 s  servo min:-409.600 us max: 404.900 us sdev:  15.700 us
  971 s  servo min:-409.600 us max: 404.900 us sdev:  15.700 us
Core 0:        +59.0°C  (high = +105.0°C, crit = +105.0°C)
Core 1:        +59.0°C  (high = +105.0°C, crit = +105.0°C)
Core 2:        +59.0°C  (high = +105.0°C, crit = +105.0°C)
Core 3:        +59.0°C  (high = +105.0°C, crit = +105.0°C)
Cleaning up
terminated latency-test ...
Closing browser firefox with WID of
There are no windows in the stack
Invalid window '%1'
Usage: windowactivate [options] [window=%1]
--sync    - only exit once the window is active (is visible + active)
If no window is given, %1 is used. See WINDOW STACK in xdotool(1)
Done.
Hardware info is logged here: 1748417872.hw.
Full latency-test data is logged here: 1748417872.lat.
Kindly place the contents of "1748417872.hw" here:
https://forum.linuxcnc.org/18-computer/39371-results-of-latency-test-list-of-computers-tested-for-use-with-linuxcnc
Thanks, and good bye.
  • Hakan
  • Hakan
28 May 2025 07:45
Replied by Hakan on topic Modbus via Ethercat (Beckhoff)
Category: EtherCAT
It was mentioned an existing vfd, but to go pure ethercat an ethercat vfd is the way.
It got me to check the manual and yes it is RS-485 Modbus RTU.
  • Aciera
  • Aciera's Avatar
28 May 2025 06:48 - 28 May 2025 06:49
Replied by Aciera on topic woodpecker.ini - cant be loaded
I don't think anybody actively maintains the 'woodpecker' ui. It doesn't run on my 2.9.4 rip install either, fails with a different error.
I wish we wouldn't drag all these broken things along. A while ago I suggested to remove all the broken sim configs but I was not successful.
  • zz912
  • zz912's Avatar
28 May 2025 06:23
woodpecker.ini - cant be loaded was created by zz912
Hello,
I have RIP installation LCNC 2.10
I cannot woodpecker.ini in sim configs.
Is it bug or dont I have some packages?
zdenek@cnc:~/linuxcnc/linuxcnc-zz912$ linuxcnc
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/zdenek/linuxcnc/linuxcnc-zz912/configs/sim/woodpecker'
Machine configuration file is 'woodpecker.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./core_sim.hal
Found file(lib): /home/zdenek/linuxcnc/linuxcnc-zz912/lib/hallib/simulated_home.hal
[QTvcp.QTVCP.QT_MAKEGUI][CRITICAL]  'MachineLog' object has no attribute 'setFrameShape' (qt_makegui.py:213)
[QTvcp][CRITICAL]  Aborted from Error Dialog
 Qtvcp encountered an error.  The following information may be useful in troubleshooting:
LinuxCNC Version  : 2.10.0~pre0
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/bin/qtvcp", line 607, in <module>
    _qtvcp = QTVCP()
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/bin/qtvcp", line 307, in __init__
    window.instance(filename=self.PATH.XML)
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/lib/python/qtvcp/qt_makegui.py", line 202, in instance
    instance = uic.loadUi(filename, self)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/__init__.py", line 241, in loadUi
    return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
    return self.parse(filename, resource_suffix)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 1037, in parse
    actor(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
    self.traverseWidgetTree(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
    handler(self, child)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
    self.stack.push(self.setupObject(widget_class, parent, elem))
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 230, in setupObject
    self.wprops.setProperties(obj, branch)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/properties.py", line 417, in setProperties
    getattr(widget, 'set%s%s' % (ascii_upper(prop_name[0]), prop_name[1:]))(prop_value)
AttributeError: 'MachineLog' object has no attribute 'setFrameShape'
 (qtvcp:557)
'QTVCP' object has no attribute 'panel'
/home/zdenek/linuxcnc/linuxcnc-zz912/scripts/linuxcnc: řádek 990: 14734 Neoprávněný přístup do paměti (SIGSEGV)                     $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS "${EXTRA_ARGS[@]}"
task: 0 cycles, min=0.000005, max=0.010430, avg=-1.000000, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/zdenek/linuxcnc_debug.txt
and
    /home/zdenek/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
  • Aciera
  • Aciera's Avatar
28 May 2025 05:28
Loading different configurations during startup.
Category: Basic Configuration
To load a config you basically execute a command line command. So you could have different Icons on your desktop for all the different setups.
The mesa board does not need to be reprogrammed as you can change things around in HAL.
I have machines with several different configurations (eg vertical milling, horizontal milling, turning, milling with slanted spindle).
  • juliankoenig87
  • juliankoenig87
28 May 2025 05:04
Replied by juliankoenig87 on topic Getting Setup with PC and MESA
Thinkcentre tinys (m73, m93, m710q ....) working great. They have Intel nics.
But also Fujitsu Esprimos working great with Realtek nics. To be honest we encounters over the past year, that realtek working a lot faster. Also pci realtek boards working damn good.
But yes, historically there were problems with realtek nics, so one can have problems. But I personally looking nowadays for realtek instead of intel, but I know what I have to look for.
For a beginner I would say a Lenovo Thinkcentre tiny (maybe with wlan on board) is a really good machie. Look for m73 or m93 with 8GB and ssd and you will be happy. Isolcpus needed! and of course the lines for the intel nic. Other than that no need for tweaking when speaking of 1kHz thread.
  • rodw
  • rodw's Avatar
28 May 2025 02:26 - 28 May 2025 02:26
Replied by rodw on topic Changing MPG step rate with a switch
Category: HAL
There is actually a good MPG example in the docs with xyz axis and scale selection. It uses parallel port pins but it works on any platform.
  • rodw
  • rodw's Avatar
28 May 2025 02:21
Replied by rodw on topic Modbus via Ethercat (Beckhoff)
Category: EtherCAT
Why not use an Ethercat VFD like the Omron MX2 which is supported in the hal driver. I believe internally its a cia402 device since it's essentially a speed control for a motor just like a servo!
  • Soccer Kid
  • Soccer Kid's Avatar
28 May 2025 00:38
resolved-- Regarding the data reading offset issue of the ether cat IO module
Category: EtherCAT
Currently, I have switched to the Codesys platform, and everything is functioning normally. It is similar to TwinCAT.
  • snowgoer540
  • snowgoer540's Avatar
28 May 2025 00:30
Replied by snowgoer540 on topic M62-M68 codes not working
Category: Plasmac
Buildbot2 is correct, you need to sign it though, as per the instructions on the page:
buildbot2.highlab.com/
  • PCW
  • PCW's Avatar
28 May 2025 00:28
  • Muftijaja
  • Muftijaja
27 May 2025 23:26 - 27 May 2025 23:28
Spindle Speed Settings only from file, no MDI possible?
Thanks langdons, that would be the last step if others fails. There are a lot of things i would have to setup again, such as wireless Handwheel, Probe basic, the TooTall18T probing routine and others that work fine at the moment, so I am a little afraid that i get more problems as today. I'm not a coder and not very familiar with all that stuff.
Thanks PCW, I will try that tomorrow and give you feedback.
This file works and let the spindle turn:
M03 S6000 G04 P120
S12000 G04 P120
S18000 G04 P120
S22000 G04 P120
M05
M30
Kind regards!
  • PCW
  • PCW's Avatar
27 May 2025 22:44 - 28 May 2025 00:27
So you are saying that if you enter:
s12000 m3
 (in the MDI tab)
That spindle.0.on remains false?
  • Studio_TC
  • Studio_TC
27 May 2025 22:19
Replied by Studio_TC on topic Getting Setup with PC and MESA
Thanks, just the info I needed.
  • PCW
  • PCW's Avatar
27 May 2025 21:46
Replied by PCW on topic Getting Setup with PC and MESA
Yes, the 7I92XX replaces the parallel port interface.
A 7I92TF will work with the same parallel port cable you currently use.
(male-male IEEE1284 type) so you should not need any additional cables.
A 7I92TM will plug directly into a G540, but that's quite awkward mechanically.
As far as the kernel goes that's included in the LinuxCNC 2.9.4 ISO, so installing
that ISO will install a preempt-RT kernel. (The 7I92 requires a Preempt-RT kernel)
As far as Mini-PCs go, it's better to use one with Intel Ethernet hardware,
as the common Realtek Ethernet chips often have realtime issues.
Displaying 14251 - 14265 out of 17400 results.
Time to create page: 0.351 seconds
