  • Hakan
  • Hakan
25 May 2025 18:22
Replied by Hakan on topic help with ethercat and omron drives
Category: EtherCAT
You can go into halshow and look at some of the cia402.x.stat pins like if stat_op_enabled is set.
The drive needs to be in op_enabled to start moving. It should be just to jog and it should move.
You have the position commanded and actual and more there to get the state of the drive.
  • ihavenofish
  • ihavenofish
25 May 2025 17:14
Replied by ihavenofish on topic help with ethercat and omron drives
Category: EtherCAT
Yeah, later today I'm gonna reconnect the omron software and see what's up. its possible they got wiped somehow, but seems unlikely.
I don't really thing there's anything on the linuxcnc side that could be at fault though, its not even commanding a movement yet, just enabling the drives.
  • PCW
  • PCW's Avatar
25 May 2025 17:09
Replied by PCW on topic Threading Index Varies With Speed
Yes, I am using interpolated position (which is very precise with the hardware generated "encoder' signals)
  • Hakan
  • Hakan
25 May 2025 17:05 - 25 May 2025 17:08
Category: EtherCAT
You are right. There is no pid control loop for the axis in ini or hal.
It's all in the servo drive.
It can help to lower P in the servo drive for the noise. But you said you tuned them, so
  • atrex77
  • atrex77's Avatar
25 May 2025 16:56
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
!UPDATE!
the default settings in the code makes the:
4 stepgenerator (up to 512 Khz in 1ms servo thread)
2 quadrature encoder counter (example: 1 for spindle encoder 1 for MPG)
3 digital outputs
1 pwm output (from 1.9Khz - 1Mhz varies from 7bit to 16bit resolution, depends of the frequency)
4 digital inputs
docs how to change this is in progress
  • AndyCNC
  • AndyCNC
25 May 2025 16:56
Replied by AndyCNC on topic Not able to get outputs on GPIO of Raspberry5
Category: Installing LinuxCNC
Thanks for your fast reply.
That's the output of "gpioinfo", looks ok for me:
[color=#55ff55][b]cnc@fraese[/b][/color]:[color=#5555ff][b]~[/b][/color]$ gpioinfo
gpiochip0 - 54 lines:
	line   0:     "ID_SDA"       unused   input  active-high
	line   1:     "ID_SCL"       unused   input  active-high
	line   2:      "GPIO2"       unused   input  active-high
	line   3:      "GPIO3"       unused   input  active-high
	line   4:      "GPIO4"       unused   input  active-high
	line   5:      "GPIO5"       unused   input  active-high
	line   6:      "GPIO6"       unused   input  active-high
	line   7:      "GPIO7"   "spi0 CS1"  output   active-low [used]
	line   8:      "GPIO8"   "spi0 CS0"  output   active-low [used]
	line   9:      "GPIO9"       unused   input  active-high
	line  10:     "GPIO10"       unused   input  active-high
	line  11:     "GPIO11"       unused   input  active-high
	line  12:     "GPIO12"       unused   input  active-high
	line  13:     "GPIO13"       unused   input  active-high
	line  14:     "GPIO14"       unused   input  active-high
	line  15:     "GPIO15"       unused   input  active-high
	line  16:     "GPIO16"       unused   input  active-high
	line  17:     "GPIO17"       unused   input  active-high
	line  18:     "GPIO18"       unused   input  active-high
	line  19:     "GPIO19"       unused   input  active-high
	line  20:     "GPIO20"       unused   input  active-high
	line  21:     "GPIO21"       unused   input  active-high
	line  22:     "GPIO22"       unused   input  active-high
	line  23:     "GPIO23"       unused   input  active-high
	line  24:     "GPIO24"       unused   input  active-high
	line  25:     "GPIO25"       unused   input  active-high
	line  26:     "GPIO26"       unused   input  active-high
	line  27:     "GPIO27"       unused   input  active-high
	line  28: "PCIE_RP1_WAKE" unused input active-high
	line  29:   "FAN_TACH"       unused   input  active-high
	line  30:   "HOST_SDA"       unused   input  active-high
	line  31:   "HOST_SCL"       unused   input  active-high
	line  32:  "ETH_RST_N"  "phy-reset"  output   active-low [used]
	line  33:          "-"       unused   input  active-high
	line  34: "CD0_IO0_MICCLK" "cam0_reg" output active-high [used]
	line  35: "CD0_IO0_MICDAT0" unused input active-high
	line  36: "RP1_PCIE_CLKREQ_N" unused input active-high
	line  37:          "-"       unused   input  active-high
	line  38:    "CD0_SDA"       unused   input  active-high
	line  39:    "CD0_SCL"       unused   input  active-high
	line  40:    "CD1_SDA"       unused   input  active-high
	line  41:    "CD1_SCL"       unused   input  active-high
	line  42: "USB_VBUS_EN" unused output active-high
	line  43:   "USB_OC_N"       unused   input  active-high
	line  44: "RP1_STAT_LED" "PWR" output active-low [used]
	line  45:    "FAN_PWM"       unused  output  active-high
	line  46: "CD1_IO0_MICCLK" "cam1_reg" output active-high [used]
	line  47:  "2712_WAKE"       unused   input  active-high
	line  48: "CD1_IO1_MICDAT1" unused input active-high
	line  49: "EN_MAX_USB_CUR" unused output active-high
	line  50:          "-"       unused   input  active-high
	line  51:          "-"       unused   input  active-high
	line  52:          "-"       unused   input  active-high
	line  53:          "-"       unused   input  active-high
gpiochip10 - 32 lines:
	line   0:          "-"       unused   input  active-high
	line   1: "2712_BOOT_CS_N" "spi10 CS0" output active-low [used]
	line   2: "2712_BOOT_MISO" unused input active-high
	line   3: "2712_BOOT_MOSI" unused input active-high
	line   4: "2712_BOOT_SCLK" unused input active-high
	line   5:          "-"       unused   input  active-high
	line   6:          "-"       unused   input  active-high
	line   7:          "-"       unused   input  active-high
	line   8:          "-"       unused   input  active-high
	line   9:          "-"       unused   input  active-high
	line  10:          "-"       unused   input  active-high
	line  11:          "-"       unused   input  active-high
	line  12:          "-"       unused   input  active-high
	line  13:          "-"       unused   input  active-high
	line  14:   "PCIE_SDA"       unused   input  active-high
	line  15:   "PCIE_SCL"       unused   input  active-high
	line  16:          "-"       unused   input  active-high
	line  17:          "-"       unused   input  active-high
	line  18:          "-"       unused   input  active-high
	line  19:          "-"       unused   input  active-high
	line  20:   "PWR_GPIO" "pwr_button"   input   active-low [used]
	line  21: "2712_G21_FS" unused input active-high
	line  22:          "-"       unused   input  active-high
	line  23:          "-"       unused   input  active-high
	line  24:     "BT_RTS"       unused   input  active-high
	line  25:     "BT_CTS"       unused   input  active-high
	line  26:     "BT_TXD"       unused   input  active-high
	line  27:     "BT_RXD"       unused   input  active-high
	line  28:      "WL_ON"  "wl_on_reg"  output  active-high [used]
	line  29:      "BT_ON"   "shutdown"  output  active-high [used]
	line  30: "WIFI_SDIO_CLK" unused input active-high
	line  31: "WIFI_SDIO_CMD" unused input active-high
gpiochip11 - 15 lines:
	line   0:    "RP1_SDA"       unused   input  active-high
	line   1:    "RP1_SCL"       unused   input  active-high
	line   2:    "RP1_RUN" "RP1 RUN pin" output active-high [used]
	line   3: "SD_IOVDD_SEL" "vdd-sd-io" output active-high [used]
	line   4:  "SD_PWR_ON" "sd_vcc_reg"  output  active-high [used]
	line   5:  "SD_CDET_N"         "cd"   input   active-low [used]
	line   6:   "SD_FLG_N"       unused   input  active-high
	line   8:  "2712_WAKE"       unused   input  active-high
	line   9: "2712_STAT_LED" "ACT" output active-low [used]
	line  12:   "PMIC_INT"       unused   input  active-high
	line  13: "UART_TX_FS"       unused   input  active-high
	line  14: "UART_RX_FS"       unused   input  active-high
gpiochip12 - 6 lines:
	line   0:  "HDMI0_SCL"       unused   input  active-high
	line   1:  "HDMI0_SDA"       unused   input  active-high
	line   2:  "HDMI1_SCL"       unused   input  active-high
	line   3:  "HDMI1_SDA"       unused   input  active-high
	line   4:   "PMIC_SCL"       unused   input  active-high
	line   5:   "PMIC_SDA"       unused   input  active-high
gpiochip13 - 4 lines:
	line   0: "WIFI_SDIO_D0" unused input active-high
	line   1: "WIFI_SDIO_D1" unused input active-high
	line   2: "WIFI_SDIO_D2" unused input active-high
	line   3: "WIFI_SDIO_D3" unused input active-high
And group "dialout" seems to fit also:
[color=#55ff55][b]cnc@fraese[/b][/color]:[color=#5555ff][b]~[/b][/color]$ groups cnc
cnc : cnc tty disk dialout sudo audio video plugdev users input render netdev i2c bluetooth gpio spi
  • CADdy
  • CADdy's Avatar
25 May 2025 16:47
Replied by CADdy on topic Indicators on Push Buttons
Category: Qtvcp
Hi Chris,
how to install this widget? Only copy the file indicatorMixIn.py to /usr/lib/python3/dist-packages/qtvcp/widgets ? Can it then be used with Qt Designer?
Peter
  • bassti
  • bassti
25 May 2025 16:37
Need 8i20 was created by bassti
Need 8i20
Category: User Exchange
Hello everyone,
I fried my 8i20 and Mesa has no cards in stock ....
has somebody one odd for me?
thanx
bassti
  • andypugh
  • andypugh's Avatar
25 May 2025 16:34
Replied by andypugh on topic Threading Index Varies With Speed
Are you using position-interpolated with your 8-count encoder?
Is there any quantisation of the error you see?
I haven't looked at the spindle synch code, but if it tries to "start early" before the index then possibly a low-count encoder will make that more difficult.
  • ihavenofish
  • ihavenofish
25 May 2025 16:28
Category: EtherCAT
Not sure what P value in the ini.would do regarding servo drive tuning. this is position control ethercat.
I don't see any P value.
  • ihavenofish
  • ihavenofish
25 May 2025 16:26
Category: EtherCAT
you shush
:P
  • Hakan
  • Hakan
25 May 2025 16:25 - 25 May 2025 16:25
Category: EtherCAT
The best thing to do is to sit back and wait for a reply that he has fixed it :)
  • andypugh
  • andypugh's Avatar
25 May 2025 16:24
Replied by andypugh on topic versa-probe vs probe_screen_v2.9
Category: Gmoccapy
There is also "psng" and my own fork of psng here:
github.com/andypugh/probe-screen-ng
(My fork is adjusted for Gtk3 and Python3, but isn't currently working for me, I get no graphics in the tabs)
  • PCW
  • PCW's Avatar
25 May 2025 16:22
Yes, you are right, there is no error on multiple constant speed
paths, I had neglected to 0 the q parameter when testing.
This is because the return path has a constant x distance from
the cutting path.
You get the error if you change the spindle speed (or motion constraints)
Basically I would think the the z motion should be strictly geared to
the spindle (+- any deliberate offsets like "q") just like a mechanical
lathe.
  • andypugh
  • andypugh's Avatar
25 May 2025 16:21
Why does it seem like everyone here is Australian?
When I first started with LinuxCNC the vast majority of the developers were in the USA. (with the exception of a Romanian)
There has definitely been a shift to Europe and Australia, though many of the folk here are still in the USA.
FWIW I am in the UK, because my antecedents managed to avoid being transported.
Displaying 14341 - 14355 out of 17460 results.
Time to create page: 0.340 seconds
