  • kubes
  • kubes
23 May 2025 18:10
Replied by kubes on topic Setting started modification Probe Basic
Category: QtPyVCP
Thanks. I was overthinking it.
For part of this I want to connect LEDs to hal pins. I have IO pins and based on their status high/low to enable the led. Much like Hal Show. I assume this is what HalLedIndicator is for? How do I "connect" the led to a pin? Rules? How are the hal pins named?
Examples of some pin I want to connect:
lcec.link-up
lcec.0.Z.din.1
lcec.0.Z.limit-neg
  • MarkoPolo
  • MarkoPolo
23 May 2025 17:39
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
I found another problem with the MacroTab Widget related to the recent checkbox element improvement.
The checkbox element is not taken into account when numbering variables. All elements below the checkbox are shifted. #4 has value #5 etc. Two checkbox elements will shift everything below by 2, as in the screenshot.
  • PCW
  • PCW's Avatar
23 May 2025 17:00
Protecting My Mesa 7i76EU: Wiring Questions for Home Sensors and Touch Probe
Category: Basic Configuration
Yes, the touch probe should be fine as long as it can be wired this way.
Note that many touch probes have a contact closure to ground, so be careful...
  • PCW
  • PCW's Avatar
23 May 2025 16:20 - 23 May 2025 16:58
Replied by PCW on topic Index homing Heidenhain ls 403/exe602
It seems the machine originally homed this way, but yes, you need to
guarantee the you are 2 index marks away from the end stop before
starting homing.
  • besriworld
  • besriworld
23 May 2025 15:39
Replied by besriworld on topic Index homing Heidenhain ls 403/exe602
I believe there's no way to avoid using a home sensor. Because if the machine is left at the last index on the encoder line, when searching for the next index marker, it might hit the limit switch. But when you have a home sensor, it's much easier—you only need to check the first, closest index marker.
  • npostma
  • npostma's Avatar
23 May 2025 15:34
Thanks. Yes mine are of the PNP type. And same goes then for the input of the Touch sensor? This is not a PNP. This acts more like a mechanical switch.
  • PCW
  • PCW's Avatar
23 May 2025 15:28
That looks basically OK
If you have PNP type sensors, you do not need any additional interface components
that is the sensor output goes directly to the 7I76EU input.
7I76XX inputs are quite rugged, they need no additional protection.
  • npostma
  • npostma's Avatar
23 May 2025 15:13
Hi All,I’d like your input on my planned setup.
As I mentioned in my previous post, the latency on my new machine was so high that I had to switch from the parallel port to a Mesa card. Earlier this week, I received a Mesa 7i76EU board. It looks awesome—if a bit overwhelming at first glance!My plan:
  • Motors:
    I’m using 3x Longs DM542A stepper drivers, which I plan to connect to Stepper 0/1/2 outputs on the Mesa board, using what I believe is called a “single-ended” wiring configuration. My plan is to connect +5V to the ENA+, DIR+, and STEP+ on each driver, and wire the ENA (5V), DIR-, and STEP- of each driver directly to the corresponding outputs on the Mesa card.
  • Spindle:
    I have a Huanyang VFD 1.5KW for spindle control. For now, I’ll keep my Modbus-over-USB setup, which seems to work well enough. I’ve read that getting Modbus running directly on the Mesa board requires a bit more advanced configuration, so I’ll save that for later.
  • Homing Sensors (Capacitive, 3x):
    My plan is to connect the +24V supply to the positive (brown) wire, and field ground to the negative (blue) wire of each sensor. I intend to connect the sensor output (black) wires to Input 1, 2, and 3 on the Mesa card.
Questions:
  1. Current-limiting resistor for home sensors:
    For the capacitive homing sensors, do I need to add a resistor between the output pin of the sensor and the Mesa input to protect against overcurrent? In the past, I’ve blown a few sensors and started using resistors to protect them, but those were cheap sensors—the Mesa card isn’t!
  2. 2-wire touch probe:
    For my two-wire touch-off probe, I plan to connect one side to +24V field power and the signal wire to Input 4. Here too, should I add a resistor to avoid potential shorts or overcurrent situations?
Bonus questions:
  • Any recommendations for best practices when wiring sensors and stepper drivers to the Mesa 7i76EU?
  • Are there things I should definitely avoid to protect my Mesa card or improve reliability?
  • For those who have set up Modbus on the Mesa board, how steep is the learning curve compared to using Modbus over USB?
Thanks for your advice and experiences!
  • snowgoer540
  • snowgoer540's Avatar
23 May 2025 14:57 - 23 May 2025 15:35
Replied by snowgoer540 on topic M62-M68 codes not working
Category: Plasmac
The code (at least the code in your first post), works fine on 2.10.008.064.  I realize you are on some version of 2.9, just was easy for me to test on that.
Can you state the specific version of 2.9 you are on (like above, as taken from the window title with QtPlasmaC open)?
Back when, there was a commit that temporarily broke feed reductions, but it was fixed. I honestly can’t remember if it was in 2.9 or master or both, but perhaps you have an older version that has the bug.
  • Lcvette
  • Lcvette's Avatar
23 May 2025 14:30
Replied by Lcvette on topic Setting started modification Probe Basic
Category: QtPyVCP
the best way to do this is to use the provided usertab, this way your edits remain with your config folder and do not get overwritten during updates (which a couple big ones are getting ready to drop). what you definitely do not want to do is edit the main probe basic because then you become the developer for any and all future updates which is not ideal for an end user.
to edit a user tab, open a terminal, type in:
editvcp
a dialog will pop up, in the dialog, find your machine config directory, typically it will be
/home/(your_pc_name)/linuxcnc/configs/(whatever_you_named_your_machine)/user_tabs/template_main/template_main.ui
in the file type drop down at the bottom of the dialog, make sure the type is set to VCP UI Files (*.ui)
this will show you the file :
template_main.ui
select it and click the open button.
Here you can add and edit it as you desire. when done, click save.
check your ini file and make sure that user tabs path is active under the display section:
[DISPLAY]
USER_TABS_PATH = user_tabs/
this activates the user tab and loads on probe basic start up.
enjoy!
  • PCW
  • PCW's Avatar
23 May 2025 14:25
Interpolation accuracy with Delta ASD-B3 EtherCAT servo drives
Category: EtherCAT
If it was working and then changed I would expect that's more likely
to be a mechanical issue (loose coupling etc).
  • MARTCENT
  • MARTCENT
23 May 2025 13:48
Replied by MARTCENT on topic Retrofit SODICK A320D
Two PCs were used in those machines.
NEC 9801UF / NEC 9801UV11
Thank you
  • Aciera
  • Aciera's Avatar
23 May 2025 13:01
Replied by Aciera on topic comp confusion
comp confusion
Category: LinuxCNC Documents
'comp' is listed twice. The first entry is correct:
The second is the wrong one.
  • PCW
  • PCW's Avatar
23 May 2025 12:47
Replied by PCW on topic comp confusion
comp confusion
Since that's a list of hal components, the link is correct
but the description is not.
  • PCW
  • PCW's Avatar
23 May 2025 12:45
OK, That's entertaining...
It should be possible to home by using a component that
measures the distance between index's and only arms
the actual index logic by simulating home switch detection
when the correct inter-index distance is measured.
Displaying 14461 - 14475 out of 17469 results.
Time to create page: 0.709 seconds
