  • SanzuiWorks
  • SanzuiWorks's Avatar
17 May 2025 09:40 - 21 May 2025 03:45
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
This requires QtDragon to support parsing (MDI_COMMAND, Gxx) output from FILTERs and executing it as an MDI command.
load_wsc_from_ngc.py
import re
import linuxcnc
import os
def on_button_detect_wcs(self):
    filename = STATUS.file
    if not os.path.exists(filename):
        print("G-code file not found.")
        return
    try:
        with open(filename, 'r') as f:
            for line in f:
                m = re.search(r'\bG5(4|5|6|7|8|9)(\.\d)?\b', line.upper())
                if m:
                    g_code = m.group(0)
                    print(f"Detected WCS: {g_code}")
                    c = linuxcnc.command()
                    s = linuxcnc.stat()
                    s.poll()
                    if s.task_state == linuxcnc.STATE_ON and s.interp_state == linuxcnc.INTERP_IDLE:
                        c.mode(linuxcnc.MODE_MDI)
                        c.wait_complete()
                        c.mdi(g_code)
                    else:
                        print("Interpreter not idle. Cannot send MDI.")
                    return
        print("No WCS (G54~G59.3) found.")
    except Exception as e:
        print(f"Error: {e}")
.ini
[FILTER]
PROGRAM_EXTENSION = .ngc G-Code File
FILTER = load_wsc_from_ngc.py .ngc
When you run the program directly, you can obtain the WSC, but it does not run automatically during the NGC loading.
  • aleene
  • aleene
17 May 2025 09:18
Could this board be a contender for a cheap alternative for simple applications?
Category: Driver Boards
Hello
I'm using the same controller and I might be able to assist.
The attached PDF file is all the documentation I received / I could find online.
The board seems to use a custom protocol - not TCP/IP based, I can see the MAC of the controller board.
The current control software is ~ a pain - i need to keep a specific windows 10 virtual machine to run it.
There's no linux support.
I've been thinking for some time to rip it out and replace it with a MESA 7i96S or something similar.
If you think there might  be any interest in this controller, please point me to a list of thing to prepare - protocol capture via wireshark / data dumps between the CPU and the ethernet controller, etc.
  • SanzuiWorks
17 May 2025 09:14 - 17 May 2025 09:17
Category: Qtvcp
This is the first time I've seen the filter function. I need to learn about this first.
  • MarkoPolo
  • MarkoPolo
17 May 2025 09:00
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Maybe leave it as it is now, but add so that radioButton also works with true/false string for backward compatibility ?
  • cmorley
  • cmorley
  • cmorley
  • cmorley
17 May 2025 06:24
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
I did update the docs but..
Maybe I should set true/false to be radio buttons too and add buttontrue/false.
  • cmorley
  • cmorley
17 May 2025 06:09
Replied by cmorley on topic QTDragon and DTG readout
Category: Qtvcp
You can use an MPG to scroll the gcode graphics and gcode editor and other widgets.
Set the button, touch the widget, the border should change, then it will scroll
You can check it out with the QtDragon_lathe sim
  • cakeslob
  • cakeslob
17 May 2025 04:39 - 17 May 2025 05:34
hey Scott, my homies and i have the environment switching working, but we did a messy job to support a different board we were testing
github.com/cakeslob/Remora-STM32H7xx-PIO/tree/h723
  • cmorley
  • cmorley
17 May 2025 04:09
Category: Qtvcp
overlay DRO can be selected from the options button
  • cmorley
  • cmorley
17 May 2025 04:09
Category: Qtvcp
As a quick solution pull again:
  • djdelorie
  • djdelorie
17 May 2025 03:08
Two switches/sensors for tool length and 3d touching into motion-probe-in? Howto
I would avoid the mux option unless you're VERY comfortable with your programming skills. I used a mux on mine, and the first time I did something unusual with the toolsetter I broke it off because it hadn't been enabled.
I still use separate inputs, but now it's so I can apply a different software noise rejection on each input (the toolsetter tends to trip from the tool change)
  • epineh
  • epineh
17 May 2025 02:40
Hey Ollie, with Riocore I've got 4 axis closed loop to the controller going on my mill, well only one axis for now but I've tested the other 3 will work, so thanks heaps for that !
The only issue is that if you use line reciever ic's (26LS32) and RJ45 sockets it all takes up a lot of PCB real estate. I'm thinking of utilizing an off board encoder solution. The LS7366 chip looks like a good candidate, its a 32 bit quadrature counter that will decode at 20 MHz at 3 volts. (40MHz at 5V)
This chip uses SPI, which I honestly know nothing about, my question is if I was to make a seperate 8 axis encoder board to cover all the axis's MPG, spindle etc, would that work with your existing SPI plugin ? And I'm not sure if the LS7366 will daisy chain or if there needs to be an additional IO pin per device, in which case it may not be worth the overhead.
Cheers.
Russell.
  • MarkoPolo
  • MarkoPolo
17 May 2025 00:58
Category: Qtvcp
Great.
Everything works fine, that's what I wanted. Thanks a lot.
It would be good to update the documentation, because old ngc files with "MACRODEFAULTS=true,false" settings will stop working for some users after updating "MacroTab".
Marek
  • Benb
  • Benb's Avatar
16 May 2025 23:58 - 17 May 2025 00:15
Replied by Benb on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
Your amd pc is a new hardware and you might need debian 13 Trixie but again you did not have problems loading debian bookworm mistry! If you want to try Linuxcnc rip installation which might work with your amd pc since its compiled. I have atttached is a step by step procedure. It worked for me using i5 mini pc with debian 12 bookworm RT with xfce option for desktop environment.
edit: Once linuxcnc installed follow this procedure to instal qtpyvcp
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • Doc_emmet
  • Doc_emmet
16 May 2025 23:39
Replied by Doc_emmet on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
Hello, it looks like I've found the error.
It's related to my Mini PC
GMKtec K11 AMD Ryzen 9 Gaming Mini PC 8945HS(8C/16T, up to 5.2GHz),
32GB DDR5 4800MHz RAM 1TB PCIE Mini Computer, Oculink,
Dual NIC 2.5GbE LAN/HDMI/USB 4.0/WiFi 6/BT 5.2/DisplayPort/USB4*2
When I install the software on my old Intel i7 4 cores,
there are no error messages and the jitter is also better.
But it won't install on a new AMD Ryzen 9 PC.
Thank you very much for your help.
Displaying 14866 - 14880 out of 17400 results.
Time to create page: 0.387 seconds
