  • Finngineering
  • Finngineering
01 Mar 2026 06:51
Replied by Finngineering on topic XHC WHB04B development?
Okay. Once you get a crash, post the output here and we can try to work it through together. Please ensure that you have some print statement in place of the commented out assert call, so if it fails there, we know about it. Something like:
if(r != 0) {
    std::cout << "Usb::setupAsyncTransfer failed with code: " << r << std::endl;
  • Alan
  • Alan
01 Mar 2026 05:43
Blender with FabEx CNC add on Feb 2026
Category: CAD CAM
I am a long term fan of LinuxCNC and FreeCad. Unfortunately I am being forced by a client to try Blender 5.0.1 with FabEX 3.0.1 add on because they like the pretty graphics.  In 50 years of computer work I have never seen such a learning curve  non standard monster....yet nifty graphics. My problem is this: I have watched numerous tutorials, noted all the undocumented hot-key commands and slowly created a simple .blend file to machine a simple cylinder to test the gcode this thing creates. Blender Fabex will not create the toolpath; issues some error about version compatability. Do any of you folks know where I can get a SIMPLE WORKING .blend file example already setup for FabEX to do ANY kind of milling to see if can even get the application to run at all. I am VERY frustrated with Blender.  Thanks in advance.
I
  • rodw
  • rodw's Avatar
01 Mar 2026 03:47 - 01 Mar 2026 03:49
Replied by rodw on topic motion channels for robotic atc library
Because the OP is on the Ethercat bandwagon (as are the commenters),
I have wondered about a seperate Ethercat component that does not consume an axis. I was mostly thinking about spindles but it might be able to morph into something with position control.
EDIT Running it on a seperate thread may give you enough independence...
  • rodw
  • rodw's Avatar
01 Mar 2026 03:37
400V Servo (51 Nm) mit EtherCAT / CiA402 in LinuxCNC – bezahlbarer Drive gesucht
Category: Deutsch
Affordable and 4500 rpm may not go together! Anything over 3000 rpm is hard to find and not affordable by many standards!
  • NWE
  • NWE's Avatar
01 Mar 2026 03:02
Replied by NWE on topic motion channels for robotic atc library
One other possibility I considered, if it is possible to run just one at a time?
Could it then be done pausing the one and temporarily switching kinematics to run the other set of axis... say, toolchanger?
  • NWE
  • NWE's Avatar
01 Mar 2026 02:58 - 01 Mar 2026 03:03
I've been thinking about this for some time.
Obviously the easiest way is probably going to be to run a second LinuxCNC pc. (Assuming I'm doing everything in LinuxCNC.)
Then I was thinking about the possibility of running a custom multi-instance capable tp component consisting of something like:
GUI <-hal-> [tp.0, tp.1, tp.2] <-hal-> [trivkins.0, scarakins.0, scarakins.1] <-hal-> I/O (mesa, lcec, etc)
Definately re-inventing most of the wheel. Can we make it any harder?
  • ihavenofish
  • ihavenofish
01 Mar 2026 00:46
Replied by ihavenofish on topic motion channels for robotic atc library
Thanks, that's basically what I thought
  • Marcos DC
  • Marcos DC's Avatar
01 Mar 2026 00:31
Replied by Marcos DC on topic motion channels for robotic atc library
LinuxCNC has a single realtime motion module (motmod).
All coordinated motion and joint updates go through that one trajectory planner and queue.
Even if you configure additional axes (U/V/W etc.), they still belong to the same motion instance.
There is no concept of a second independent motion channel inside one LinuxCNC process.
Industrial controllers sometimes give the impression that this should be possible because they support true multi-channel motion. For example, platforms like Omron Sysmac can run multiple independent motion groups or program contexts in parallel within the same controller. That capability is built directly into the motion kernel.
LinuxCNC, however, is architected around a single motion instance per process.
If you need the tool robot to move while the main machine is cutting, the practical solutions are:
• Run a second LinuxCNC instance / second controller for the tool robot and handshake via IO/fieldbus.
• Use an external PLC/MCU/drive sequencer for the robot and trigger it from LinuxCNC via M-codes or IO.
A “HAL-only second planner” is technically possible, but then you own all the safety, limits, interlocks and coordination logic yourself — and it tends to become fragile fast.
  • ihavenofish
  • ihavenofish
28 Feb 2026 23:41 - 28 Feb 2026 23:50
motion channels for robotic atc library was created by ihavenofish
So i had a craaazy idea for a little robot tool library.
Wondering how you would implement it in linuxcnc.
So we have our XYZA on our cnc. lets reserve B just in case we ever need a 5th.
That leaves 4 more axes available.
Our little tool robot will have an x2 y2 z2, and a x3 (fixed motion, likely air) and C do pivoting the gripper - again fixed motion.
Basically it is a cnc of its own, and needs to operate while the main machine is cutting so it can sort and stage tools. This is different from using C for an atc platter that is actually coordinated with the main machine.
How could we do this?can we decouple these new axes from the main motion as a "channel" ?
  • Marcos DC
28 Feb 2026 23:37
Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
Category: EtherCAT
I already have a pure SIM validation setup working (HAL adapter + drive stub). The goals there were to make the logic deterministic and debug wiring/handshake issues before touching real EtherCAT hardware. In SIM I’ve validated:
6060/6061 opmode handshake
bit4 start pulse generation
done mask/value detection
stable statusword behavior (no flicker)
basic “homed” behavior (latched)
So the current work is no longer “does it wire up?”, but refining the architecture to match industrial semantics.
@rodw — yes, exactly: your procedure returning 1 at Operation Enabled is the clean gate. I’m using your barebone logic as the base for a dedicated PDS manager layer: until op_enabled == 1, nothing else (homing or motion modes) is allowed to run. Once op-enabled is reached, then we proceed with homing / CSP.
@Hakan — I also really like your point about not blaming the drive for moving during internal homing. That’s actually the main remaining behavior I’m refining now: instead of freezing targets in a hacky way, it seems cleaner to make the controller follow feedback during drive-internal homing.
So while homing is active:
motion/target follows feedback (pos_cmd := pos_fb)
when homing completes, CSP can resume with zero discontinuity (no jump)
Next steps:
implement the separate PDS manager (based on rodw’s barebone + timeouts + fault reset pulse)
implement mode modules (homing/CSP/etc.) gated by op_enabled and 6060/6061 confirmation
once the layers are solid in SIM, re-integrate with lcec + real hardware
If either of you sees a pitfall in the “motion follows feedback during internal homing” approach, I’d love to hear it — but it looks like the cleanest way to avoid discontinuities when returning to CSP.
  • nichtAlex
  • nichtAlex
28 Feb 2026 20:45
Umstieg von LinuxCNC + Mesa auf EtherCAT (Leadshine EL8 / Beckhoff) – Erfahrunge
Category: Deutsch
Das sind die A6-400EC 400 Watt EtherCat Treiber. Laufen mit einphasig 230V AC. Da die das cia402 Profil nutzen lassen die sich ganz normal mit LinuxCNC und der cia402 Komponente ansteuern. Beispiele für die ethercat-conf.xml gibts hier im Forum ja genug zu den A6 Treibern.
An sich stören mich die IOs der Treiber nicht aber ich finde das übersichtlicher/sauberer wenn alles auf die Beckhoff Module geht. Keine Lust da jetzt noch irgendwelche d-sub stecker zu löten für die Treiber. Habe durch mein Bedienpult nen haufen Digitalein- und ausgänge und mit den Beckhoff Modulen hab ich das schön sortiert.
Ich nutze die Treiber im inkrementalen Modus und referenziere nur über linuxcnc und nicht über den Treiber selber
  • Hakan
  • Hakan
28 Feb 2026 20:28
Category: EtherCAT
How about if we don't blame the drive for moving by itself during homing,
and instead make "motion" understand that it should follow the position feedback?
  • Felsenbart
  • Felsenbart
28 Feb 2026 20:28 - 28 Feb 2026 23:06
Replied by Felsenbart on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
For several days now I’ve been getting the error “Motor 0 position error” whenever I try to move Motor 0 (X-axis). At the moment, only this motor is connected.The setup uses a DM556Y driver with a NEMA 23 motor.
I’ve attached the .hal and .ini files.
I hope someone can help me figure this out.
thanks everyone :)
File Name: ec500_2026-02-28.hal
File Size:2 KB
File Name: ec500_2026-02-28.ini
File Size:2 KB
[/code][/code]
  • Hakan
  • Hakan
28 Feb 2026 20:20
Replied by Hakan on topic XHC WHB04B development?
Still trying to learn exactly where in the code it fails.
It doesn't reconnect, that's for sure. If it had, it wouldn't have been an issue.
I overwrite the log and, alas, no saved useful log.
"Unfortunately" I didn't get a crash today when I worked with the machine.
I like the whb04b a lot.It's worth spending some time improving stability.
  • my1987toyota
  • my1987toyota's Avatar
28 Feb 2026 20:16
Displaying 1501 - 1515 out of 17387 results.
Time to create page: 0.850 seconds
