13 May 2025 02:00
Replied by tommylight on topic Linuxcnc wood lathe insufficient torque
Those drives can not do more than 3-3.5A, but that might still not be the issue, i doubt the new motors are of very high inductance, so can you measure the resistance between the windings?
The old motor, is it unipolar or bipolar? How many wires does it have?
If 5 wires = do not use with new drives
If 4 or 6 or 8, try to use it with the new drives, just mind the windings.
13 May 2025 01:54
Replied by tommylight on topic Moving from Axis to QtDragon?
Category: Qtvcp
Those should be in the ini file, the DISPLAY and TRAJ sections.
  • cakeslob
  • cakeslob
13 May 2025 01:06
hey spyder, the y axis is the one you want to copy, that sounds like the proper one. , so after it homes, i think home offset is where it goes after homing. if you set the home offset to be off the switch, it should be able to home the next one. observe how and where your y axis is going, and copy it to the other axis, it will involve inverting these numbers to be negative or positive. refer to the manual for verification of which direction does what.
HOME_OFFSET = 1
HOME_SEARCH_VEL = -2.0
HOME_LATCH_VEL = -1.0
HOME_FINAL_VEL = -2.0
HOME_SEQUENCE = 1
  • Spyderbreath
  • Spyderbreath's Avatar
13 May 2025 00:37
Replied by Spyderbreath on topic Moving from Axis to QtDragon?
Category: Qtvcp
If anyone thinks this should be in it;s own thread, let me know, but I still have a few questions about the GUI.
There are override sliders for max velocity, rapid, feed rate, and spindle. The max velocity and rapid default at 100%, shiny. The problem is that 100% is about 3X more than my machine can move. It says its 12000 for both. Need to be set at ~3600 each. Been looking through the config files and I am not seeing those numbers anywhere. Where do they come from?
  • jimboh2
  • jimboh2
12 May 2025 23:46
  • jimboh2
  • jimboh2
12 May 2025 23:40
Replied by jimboh2 on topic Linuxcnc wood lathe insufficient torque
Off On Off Off Off Off which is 8 steps as I have it configured in stepconf and max current which i believe is 4.2 A with the TB6600. Nothing gets the slightest bit warm. Original stepper was a nema 23 but round bodied and smaller than the 425ox (I only have one, The guy I bought it from had removed the Z stepper and fitted an electric drill to the shaft).
12 May 2025 23:11
What are the drives set to?
What motors were there originally?
12 May 2025 23:08
Replied by tommylight on topic Homing and limit in one switch.
In the ini file
HOME_SEARCH_VELOCITY
HOME_LATCH_VELOCITY
HOME_FINAL_VELOCITY
Any of those you have, set to some reasonable value in machine units per second.
  • Spyderbreath
12 May 2025 23:06
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I'll try and find my old .hal file for my mill tomorrow , I  got that working with prox and limit switches, I think they were all wired to one input also. It was with a BOB though not remora
I think it homes one axis at a time. Hits the switch backs back off again a set amount. Then moves on to the next axis and so on
Yes, that is how my homing works. Z first (don't want anything attached to the bed to crash into the head, then X, and finishes up with Y. That part works great, with a little odd behavior with the Y as it for some reason hits, backs up and comes at it again real slow, like it's probing, then jumps off a few mm and zeros like the other 2 axis. Attempting to add in the limit sw config, Z will home properly and then reports that a limit switch was tripped and the homing process is stopped dead.
  • PCW
  • PCW's Avatar
12 May 2025 22:56
Replied by PCW on topic Mesa 79i6s CR8 (yellow)
The 7I96S has two internal voltages regulated down from the 5V supply
3.3V and 1.2V The power LED monitors the 3.3V used for most logic.
  • Tom369
  • Tom369
12 May 2025 22:35 - 12 May 2025 22:36
Replied by Tom369 on topic Mesa 79i6s CR8 (yellow)
means all Ok :) Thank you...
but what you mean with 3.3v?
  • Murphy
  • Murphy
12 May 2025 22:26 - 12 May 2025 22:29
  • jimboh2
  • jimboh2
12 May 2025 22:24
Hi
Looking for a bit of help from the more experienced cnc'ers out there.
I am in the process of converting an old Magnum Phoenix EZ CNC wood lathe to linuxcnc. As it was originally fitted with nema 23 steppers I bought a cheap kit off amazon with nema 23 270oz steppers, TB6600 drivers and a 24v supply. Drivers do not seem to have enough torque as it may turn a bit but then just jitters. Woret on the long z axis.  I purchased a 36v supply and a pair of 425oz nema 23 steppers.
Neither increasing the power supply voltage alone or switching to the 425 oz steppers seem to make any noticeable difference. when it is stuttering ie not turning, it only takes a little bit of help by turning the screw with my fingers to get it moving and I don't notice any difference in the amount of help it needs with 24/36 or 270oz/425oz.
I have reduced the velocity and acceleration in stepconf and while slowing it down seems to help it certainly does not fix it.  Only thing i have not changed is the drivers. Is that the next logical step or is there anything in config I may need to look at?
  • PCW
  • PCW's Avatar
12 May 2025 22:23
Which kernel version is best for real time?
When you get an error, what does:
halcmd show param *.tmax
(typed in a terminal)
show?
This will help determine where the fault lies
  • Spyderbreath
12 May 2025 22:21
I think that's explained in the Linuxcnc manual. If you look in that it may explain how to do it. What mill is it ? My .hal file I uploaded a few posts back. Have a look at that. It's a lathe though. I'll be starting my mill with remora next month.  I'm waiting for parts to arrive, to build a circuit to drive the 12v stepper drivers  first. My mill has limits and prox sensors.
If your thinking about here - linuxcnc.org/docs/html/config/ini-homing...witch_example_layout - that seems to be for only one axis. I get that and it works. My question is how do I add 2 more axis with shared limit/home switches onto that one pin. That does not seem to be explained.
Displaying 15016 - 15030 out of 17468 results.
Time to create page: 0.395 seconds
