  • NT4Boy
  • NT4Boy
02 May 2025 19:03
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
I think I have the system in control now, and have reached the point where I want to add an encoder to the spindle for rigid tapping and better speed control.
My plan had been to add a toothed wheel with a pair of hall effect sensors, one a few teeth away, but half a cycle out of phase for quadrature, and a third for an index. Then connect these directly into the 7i77 channel 5 encoder inputs. (some biasing resistors maybe required also)
The maximum spindle rpm is 3500. I was proposing 40 teeth, but on say an M6 thread with 1mm pitch, I think that's a possible pitch error of .00625mm, which is pretty small, but I guess 100 would be better. I'd appreciate others opinions on this choice please.
Secondly, because of the belt run and lack of clearance around the belt pulley, putting the index tooth on is a much bigger mission than I was expecting.
Can I simply delete it and use a missing tooth, or pair of missing teeth as the index?
What looks to me like it might not so simply work is the encoder quadrature when it reaches the missing tooth, or am I over thinking this?
  • Hakan
  • Hakan
02 May 2025 19:02 - 02 May 2025 19:42
Replied by Hakan on topic General Questions about using ethercat
Category: EtherCAT
Maybe lcec doesn't find the device or it doesn't go to OP.
From "ethercat slaves", are they in OP?
In halshow, can you see the pin lcec.0.0.statusword?
Any clues from "sudo dmesg", the last say 50 lines are of interest.
Edit. I looked a bit closer at the ethercat-conf.xml file.
You have double info, which I haven't seen before. Where does the info in that file come from?
I am not used to see a lot of PDOs in syncManager 0 and 1, but always have the PDOs
in SM 2 and SM 3. And you have the info there as well.
Can you test to replace the contents in ethercat-conf.xml of the clients with this
    <slave idx="0" fill in the rest in this line
      <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
      <syncManager idx="2" dir="out">
        <pdo idx="1600">
          <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="controlword" halType="u32"/>
          <pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32"/>
          <pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
          <pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
      </pdo>
      </syncManager>
      <syncManager idx="3" dir="in">
        <pdo idx="1a00">
          <pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="statusword" halType="u32"/>
          <pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32"/>
          <pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32"/>
        </pdo>
      </syncManager>
    </slave>
  • Aciera
  • Aciera's Avatar
02 May 2025 18:48
Replied by Aciera on topic Axis Position Logger
Category: AXIS
you need to execute 'lcnc_logger.py' with linuxcnc running. This can also be done using a custom mcode as outlined here (note that the file has since been renamed to 'lcnc_logger.py') :
forum.linuxcnc.org/21-axis/30986-axis-po...gger?start=60#294514
  • PCW
  • PCW's Avatar
02 May 2025 18:43
Dual control setup - comms between 2 systems- 7i94 bin file?
Category: Driver Boards
I can make a configuration with UARTs but there is no direct hal support
for communication between two systems.
What other I/O do you need on the 7I94Ts?
How much data needs to be exchanged?
  • xlordofpainx
  • xlordofpainx
02 May 2025 18:26
Replied by xlordofpainx on topic Set static IP address for mesa 7i96s
i get command not found on many of the commands from the text tutorial :(
  • Henk
  • Henk
02 May 2025 18:26
Tomorrow I would like to get the 2 7i94ts to connect using a mesa uart connection. Not sure which firmware to flash. Had a look through the available ones but there isn't an obvious choice.
PCW, is there one available, if so which one?
Henk
  • PCW
  • PCW's Avatar
02 May 2025 18:17
Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
Yes, in most cases, mesaflash is not needed as the installed firmware is sufficient.
  • Adam Maszynotwór
  • Adam Maszynotwór's Avatar
02 May 2025 18:04
Yes. Current stable version 2.9.4 ISO
I think that mesa and linuxcnc card experts may not have even noticed this. because they either knew where and how to download the updates without a problem. or they skipped this step altogether and did the configuration right away.
  • fery15sty
  • fery15sty
02 May 2025 18:00
Replied by fery15sty on topic Axis Position Logger
Category: AXIS
how to run lcnc_logger? what to add in .ini file?
  • Tntmold
  • Tntmold
02 May 2025 17:59
Replied by Tntmold on topic General Questions about using ethercat
Category: EtherCAT
Thanks for the reply but I believe I made all those changes and it made no difference, did I do it wrong or is the problem something else?
  • besriworld
  • besriworld
02 May 2025 17:58
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
The HAW show shows that automatic tuning is not enabled.
What can I test? The problem I have is serious.
  • Aciera
  • Aciera's Avatar
02 May 2025 17:57
popup entry keyboard, no minus and decimal ?
Category: Plasmac
Changed topic title to something a little more verbose.
  • PCW
  • PCW's Avatar
02 May 2025 17:22
Yes, a fairly ancient version of mesaflash (3.4.9)  is included with the
LinuxCNC 2.9.4 ISO, this is supposedly fixed for later releases.
Displaying 15781 - 15795 out of 17470 results.
Time to create page: 1.190 seconds
