  • scotth
  • scotth
04 Apr 2025 14:57
Replied by scotth on topic ENCODER_RATIO function implementation.
VF induction with a large flywheel to smooth out any variation during the cut.
  • PCW
  • PCW's Avatar
04 Apr 2025 14:11
dead Outputs on Mesa 7i76E and blown up 7i85S
Category: Driver Boards
I don't see that, If you try again, I'll check the spam bucket...
  • unknown
  • unknown
04 Apr 2025 13:55
4-Gang 1-Way Switch To Control 3 Power Supplies and a Router Independently
I probably when OTT with power supplies.
What I did was use some light weight DPDT relays, one set of contacts latches the relay after briefly being energised by a pushbutton and the other set of contacts controls a contactor with a 24v coil. I find this a great because if the power is removed, blackout breaker tripping, and comes back on the power doesn't come back on.
I went with a relay > contactor setup as I wanted to keep the 240 seperated from the 24v control. The only issue is that there is an always on 24v supply dedicated to the relays.
To clarify there's one relay/contactor per power supply. Each power supply can be independently controlled. For wiring the latching relay I had some PCBs made to simplify the wiring.
Bit more involved than a 4 way gang switch. The same thing could be implemented with a NVR switch for each PSU.
Oh I forgot I'm series with each pushbutton is another switch, this is used to turn the relay off and has to be in the "on" position before pushing the button to turn the power supply on. It's kind of like starting a rocket.
  • PCW
  • PCW's Avatar
04 Apr 2025 13:13 - 04 Apr 2025 13:13
Replied by PCW on topic Encoder on 7i95t
Encoder on 7i95t
Also if you use encoder feedback you will need to tune the system
and this requires increasing the following error limits:
FERROR = 0.005
MIN_FERROR = 0.0025
I would increase these to say
FERROR = 1
MIN_FERROR = .25
So you don't get nuisance following errors when tuning
Tuning involves using halscope to plot the following error
It's helpful to plot the joint following error and joint velocity
when tuning.
Note that if you use homing to index, you must connect the encoder
index enable signal to both motion and the PID component.
04 Apr 2025 12:38
04 Apr 2025 12:32
Seems a bit excessive and not very useful.
It is much better to use a single small industrial switch and 4 of automatic fuses inside the control box, you can switch on/off automatic fuses as they can handle a bit of torture although they are not made for it, but since they will be used during testing only, they will be fine.
04 Apr 2025 12:24
Replied by tommylight on topic Encoder on 7i95t
Encoder on 7i95t
P=10 ?
Start from the beginning :
-Make a working config WITHOUT encoders, only after that is working properly with correct dimensions move to enabling encoders and editing other values. The link has everything in metric, adjust accordingly for imperial.
forum.linuxcnc.org/10-advanced-configura...glass-scale-feedback
-then check the homing as described in the link i posted above by lowering the search and latch and final homing velocities to see what is actually happening during the homing procedure. For metric machine use 1, for imperial use 0.04
  • behai
  • behai
04 Apr 2025 12:14
Please help me with the following question regarding a 4-gang 1-way switch to turn on and off 3 power supplies and a router independently.
I would like to set up the circuits in the below diagram:
I am from Melbourne, Victoria, Australia, we are on 240V and 10A.
The 3 power supplies are:
1. 5V 2A ( I already have ): to power my Mesa 7I96S card.
2. 24V 4A ( I already have ): to power the proximity switches.
3. 36V, 800W, 22+A ( I don't have yet ): to power the 4 stepper drivers CL57T-V41 and 4 Nema 23 stepper motors.
4. To power a router to use with the CNC machine.
With a 4-gang 1-way switch, I am able to independently turn on and off any devices I see fit.
If an emergency happens, I will just press the emergency switch and all 4 circuits will just turn off.
I have also the emergency switch, and I've learned how to wire it, I have been able to test the wiring successfully using a microwave fan.
PLEASE HELP:
1. Is this an appropriate set up, please?
2. If (1) is an appropriate set up, can you help recommending a correct 4-gang 1-way switch, please?
I am only able to find light switches, for example:
directwholesale.com.au/products/clipsal-...-white/?gad_source=1
Clipsal Switch 4 Gang 10A Pvc Square Plt White - P2034/2VA-WE
$72.50
And I am not sure if they will work for this set up.
I understand the potential dangers. If it is appropriate and I know of the switch, then I have something to do further studies. I take full responsiblities for what I am doing.
Thank you and best regards,
...behai.
04 Apr 2025 12:10
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
Will try to upload the new build with 6.13 RT kernel later tonight, WiFi works on both of my laptops with it, whereas it did not work with 6.10.
Also, display refresh rate was 60Hz max with 6.10, with 6.13 it's 120Hz as it should.
04 Apr 2025 12:05
Replied by tommylight on topic Custom PC build for my brothers company and more
Category: Show Your Stuff
Due to finances (well, lack of) the B650 and Ryzen 7 7700 will have to wait.
Not happy as the 7700 is 198 Euro right now here so wont last long. :(
  • Z3rni3
  • Z3rni3
04 Apr 2025 11:59 - 04 Apr 2025 12:02
Replied by Z3rni3 on topic Encoder on 7i95t
Encoder on 7i95t
Sorry, I don't really understand what you're trying to tell me with that.
My home search_vel is -0.5 and the latch_vel is -0.25.
And P is set on 10
04 Apr 2025 11:56
PCI and PCI-E add on cards with parallel port that work out of the box
Went today to check for some more of those Sunix cards, nothing yet.
Will report as soon as i get them.
  • jdowsonjr
  • jdowsonjr
04 Apr 2025 11:43
Replied by jdowsonjr on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
i got it! i also found it in the ethercat parameters list
now i need to compile the cia402 component. What is the most up to date method to achieve this, are you using the repo of rodw or marco reps?
Displaying 17431 - 17445 out of 17468 results.
Time to create page: 0.438 seconds
