  • spumco
  • spumco
11 Nov 2024 22:11
probe basic - toolpath/file preview loading error
Category: QtPyVCP
Is there anything further I can post or attach here (or on GH) to assist?
The error Lcvette posted on GH wasn't exactly the same as mine - at least I don't think so.
  • digiex_chris
  • digiex_chris
11 Nov 2024 22:04
I wonder if at that speed you're getting near the max speed of the level shifter? How does the tang look at the same speed as the paraport?
  • Grotius
  • Grotius's Avatar
11 Nov 2024 21:38
Replied by Grotius on topic CNC Control Panel - Winter Project
Category: Show Your Stuff
Very cool guys. .
Excellent work.
Greetings.
  • HansU
  • HansU's Avatar
11 Nov 2024 21:01
Replied by HansU on topic CNC Control Panel - Winter Project
Funny, I just finished my Panel as well:
It communicates with LinuxCNC via Modbus, with a STM32 Nucleo board running a simple Modbus server: github.com/hansu/ModbusIO/tree/devel
  • PCW
  • PCW's Avatar
11 Nov 2024 20:43
Replied by PCW on topic +-10v setup 7i97 & .ini
You will need to widen the following error limits to be able to tune the joints.
  • Sziggy_NC
  • Sziggy_NC
11 Nov 2024 20:15
Replied by Sziggy_NC on topic +-10v setup 7i97 & .ini
Thank you for correcting my mistake. The -10v is gone now.
I still have an issue though. Instead of jumping 0.0100in on enable it is now jumping 0.0015in. It is still enough to trigger a following error. I went ahead and checked voltages just to be sure. Before pressing F2 I am reading 0.008v after pressing F2 I am reading 0.010v. Is the voltage an issue?
  • Lcvette
  • Lcvette's Avatar
11 Nov 2024 19:54
Category: QtPyVCP
im not certain, it may be that it was a molested version. it initially started as an apt install from sudo apt install linuxcnc-uspace-dev mesaflash from the docs instructions and had been updated over the course of that pc build. for now i would say perhaps my install had been modified while troubleshooting dbtools work, so unless it pops up again, i would say assume it is relegated to 2.10.
  • PCW
  • PCW's Avatar
11 Nov 2024 19:45
PWM type must be 1
  • Sziggy_NC
  • Sziggy_NC
11 Nov 2024 19:33
While I am sure that the ini changes needed to be done, they didn't effect the behavior of the analog out pin.
The current behavior is that once F2 is pressed to enable linuxcnc I am measuring -10v across pins 3 & 4. From what I understand this should be 0v until I attempt to jog. Max speed in one direction is -10v and max speed in the other direction is +10v.
I think I have something wrong with my pwmgen.
From reading pwmgen in the docs, I came to the conclusion that for a +-10v servo I needed output-type 2. This is what I have been attempting to use.
Is this correct?
I have tried comparing my hal and ini files to the basic7i97 hal and ini. I'm at a loss for what to try next, but I will keep looking.
  • PCW
  • PCW's Avatar
11 Nov 2024 19:31 - 11 Nov 2024 19:32
Mesa 7i96s connected but inputs not working
Category: Driver Boards
There is a RS-485 port on the 7I96S but its unrelated to the encoder input.
One thing necessary for the encoder input to work with your single ended encoder
is to jumper the 7I96S encoder input for TTL/Single ended signals. This means jumpers
W1,W2,W3 must all be in the left hand position.
  • PCW
  • PCW's Avatar
11 Nov 2024 19:25
Linuxcnc crashing randomly when pressing buttons
Not any real help but
[xcb] Unknown sequence number while processing queue
looks like the cause of the crash, possibly a GUI bug
  • JackRay
  • JackRay
11 Nov 2024 19:17
Replied by JackRay on topic Mesa 7i96s connected but inputs not working
hello ,
your video explains very well the basic connections and it's very welcome because at the beginning it's not easy to understand everything. I've just bought a 7i96s to replace my SV2 card (parallel port) mainly to add position feedback for my axes (encoders). The middle and end of travel connections for my 5 axes are operational and work very well with a Raspberry pi4. Where I'm having a lot of trouble is with the connections and signals from my encoder.
I want to connect the position feedback of my B axis to the only encoder port on the board.
My encoder is type A+,B+,0V,5Vdc . But I don't understand the documentation for the Mesa 7i96s board with TX/RX 422/485 ... I have no signal feedback in the halmeter.
Could you please guide me to the right connections and signals for my configuration? If attached the configuration of my B axis in my . Hal
---closedloop stepper signals---
net b-pos-cmd <= joint.3.motor-pos-cmd
net b-vel-cmd <= joint.3.vel-cmd
net b-output => [HMOT](CARD0).stepgen.03.velocity-cmd
#net b-pos-fb <= [HMOT](CARD0).stepgen.03.position-fb
net b-pos-fb => joint.3.motor-pos-fb
net b-enable <= joint.3.amp-enable-out
net b-enable => [HMOT](CARD0).stepgen.03.enable
setp [HMOT](CARD0).encoder.00.counter-mode 0
setp [HMOT](CARD0).encoder.00.filter 1
setp [HMOT](CARD0).encoder.00.index-invert 0
setp [HMOT](CARD0).encoder.00.index-mask 0
setp [HMOT](CARD0).encoder.00.index-mask-invert 0
setp [HMOT](CARD0).encoder.00.scale [JOINT_3]ENCODER_SCALE
net b-pos-fb <= [HMOT](CARD0).encoder.00.position
net b-vel-fb <= [HMOT](CARD0).encoder.00.velocity
net b-index-enable joint.3.index-enable <=> [HMOT](CARD0).encoder.00.index-enable
net b-pos-rawcounts <= [HMOT](CARD0).encoder.00.rawcounts
# ---setup home / limit switch signals---
net b-home-sw => joint.3.home-sw-in
net b-neg-limit => joint.3.neg-lim-sw-in
net b-pos-limit => joint.3.pos-lim-sw-in
Thank you very much
  • Aciera
  • Aciera's Avatar
11 Nov 2024 19:07
Category: QtPyVCP
 2.9.3-2099-g9f5a1c8f50
What/Where is this? We cannot reproduce this bug building the 2.9 branch of the linuxcnc github repo we can reproduce this only in master.
  • PCW
  • PCW's Avatar
11 Nov 2024 19:01
Replied by PCW on topic mesa 7i96s analog spindle
You can just turn the spindle by hand to check encoder counting,
direction, and scale (one forward turn should advance the encoder
position by 1.00)
Your hal/ini examples do not include the needed PID component/
connections/constants. Also note the the encoder feedback must come
from the -rpm pin as the plain encoder velocity will be in RPS.
  • langdons
  • langdons
11 Nov 2024 18:57 - 11 Nov 2024 18:59
Replied by langdons on topic New basic setup recommendations
I have an extra parallel port card lying around.
Do you want it?
Price is $2. (CAD) ($1.94 for shipping + 6 cents for the card itself)
International shipping extra.
The card works perfectly but it is not power efficient.
(It uses an LM7805 voltage regulator that wastes >7/12 of the power as heat)
Displaying 18016 - 18030 out of 24283 results.
Time to create page: 0.408 seconds
