  • Rkatts
  • Rkatts
10 Nov 2024 00:38
Ethercat installation from repositories - how to step by step
Category: EtherCAT
"If you have Secure Boot enabled (can be checked with mokutil --sb-state),..."
nc:~$ mokutil --sb-state
EFI variables are not supported on this system
  • PCW
  • PCW's Avatar
10 Nov 2024 00:37
Replied by PCW on topic Suggestion for a PCI EPP card for 7i43
Could also be an almost dead short on the 3.3V rail.
If you have a lab supply you could set it to 3.3V,connect
it to the 3.3V rail and ramp up the current to see what
part(s) get(s)s hot.
Where are you located?
  • Rkatts
  • Rkatts
10 Nov 2024 00:29
Category: EtherCAT
So I ran the following and still failed.
nc:~$ sudo apt install ethercat-master libethercat-dev linuxcnc-ethercat
[sudo] password for aa:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed: autoconf autoconf-archive automake autotools-dev ethercat-dkms libethercat libltdl-dev libtool m4
Suggested packages: gnu-standards autoconf-doc libtool-doc gfortran | fortran95-compiler gcj-jdk m4-doc
The following NEW packages will be installed: autoconf autoconf-archive automake autotools-dev ethercat-dkms ethercat-master libethercat libethercat-dev libltdl-dev libtool linuxcnc-ethercat m4
0 upgraded, 12 newly installed, 0 to remove and 126 not upgraded.
Need to get 2,444 kB/5,394 kB of archives.
After this operation, 86.6 MB of additional disk space will be used. Do you want to continue? [Y/n] y
Err:1 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-dkms 1.6.0.g8330bca-1+3.1 404 Not Found [IP: 195.135.223.226 80]
Err:2 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-master 1.6.0.g8330bca-1+3.1 404 Not Found [IP: 195.135.223.226 80]
Err:3 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ libethercat 1.6.0.g8330bca-1+3.1 404 Not Found [IP: 195.135.223.226 80]
Err:4 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ libethercat-dev 1.6.0.g8330bca-1+3.1 404 Not Found [IP: 195.135.223.226 80]
Err:5 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.39.0.g4299f7a-0 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/all/ethercat-dkms_1.6.0.g8330bca-1%2b3.1_all.deb 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/amd64/ethercat-master_1.6.0.g8330bca-1%2b3.1_amd64.deb 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/amd64/libethercat_1.6.0.g8330bca-1%2b3.1_amd64.deb 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/amd64/libethercat-dev_1.6.0.g8330bca-1%2b3.1_amd64.deb 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/amd64/linuxcnc-ethercat_1.39.0.g4299f7a-0_amd64.deb 404 Not Found [IP: 195.135.223.226 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
  • mBender
  • mBender
10 Nov 2024 00:23
I am trying to get Classicladder to work. When I start the machine, I get the following error. I can confirm that Classic Ladder on the same PC in my old LinuxCnc configuration (parallel port instead of FPGA) works. I even tried to copy all the classicladder lines from the parallel port .hal file, but still get the same error.
Shared memory conflict or RT component not loaded!
ERROR CLASSICLADDER- Ladder memory allocation error
  • juliankoenig87
  • juliankoenig87
10 Nov 2024 00:02
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Ok. To me it looks like that the voltage regulators are fried. Maybe an overvoltage damage.
  • Adam_C
  • Adam_C
09 Nov 2024 23:42
  • lgrfbs
  • lgrfbs's Avatar
09 Nov 2024 23:40
Z axis goes in the wrong direction, so after home-all
Category: StepConf Wizard
I did as you wrote, however I needed to change two more things:
Now is ‘Home all’ works as it should.
Do you usually change directly in the INI file or is the GUI wizard the best way?
THANKS for all the help.
  • juliankoenig87
  • juliankoenig87
09 Nov 2024 23:37
Checked with ice. Maybe U9 gets a little to hot. Dont know yet.
  • juliankoenig87
  • juliankoenig87
09 Nov 2024 23:25 - 09 Nov 2024 23:27
I dont know. I bought it used.
U6 aprox. 1,23V
U10 aprox. 0,60V
Supply each 4,87V
3,3 V header also 0,6V.
So yes. Looks like a short in any chip.
  • Rkatts
  • Rkatts
09 Nov 2024 23:22 - 10 Nov 2024 00:33
Category: EtherCAT
I installed LinixCNC 2.9.3 (Debian 12) using the ISO from the downloads page.  Then I tried using the instructions of this thread to install ethercat, but I'm getting errors.  I have tried several different suggestions, but none worked.
nc:~$ sudo apt update
Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:5 https://www.linuxcnc.org bookworm InRelease
Hit:4 https://repository.qtpyvcp.com/apt develop InRelease
Get:6 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease [1,575 B] Err:6 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
Fetched 1,575 B in 2s (1,019 B/s)
126 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease: The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
W: Failed to fetch http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/./InRelease The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
W: Some index files failed to download. They have been ignored, or old ones used instead. nc:~$ sudo apt install linuxcnc-ethercat
The following additional packages will be installed: autoconf autoconf-archive automake autotools-dev ethercat-dkms ethercat-master libethercat libltdl-dev libtool m4
The following NEW packages will be installed: autoconf autoconf-archive automake autotools-dev ethercat-dkms ethercat-master libethercat libltdl-dev libtool linuxcnc-ethercat m4
0 upgraded, 11 newly installed, 0 to remove and 126 not upgraded. Need to get 5,372 kB of archives. After this operation, 86.5 MB of additional disk space will be used. Do you want to continue? [Y/n] y
Get:1 http://deb.debian.org/debian bookworm/main amd64 autoconf-archive all 20220903-3 [775 kB]
Get:2 http://deb.debian.org/debian bookworm/main amd64 m4 amd64 1.4.19-3 [287 kB]
Get:3 http://deb.debian.org/debian bookworm/main amd64 autoconf all 2.71-3 [332 kB]
Get:4 http://deb.debian.org/debian bookworm/main amd64 autotools-dev all 20220109.1 [51.6 kB]
Get:5 http://deb.debian.org/debian bookworm/main amd64 automake all 1:1.16.5-1.3 [823 kB]
Err:6 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-dkms 1.6.0.g8330bca-1+3.1 404 Not Found [IP: 195.135.223.226 80]
Get:7 http://deb.debian.org/debian bookworm/main amd64 libtool all 2.4.7-7~deb12u1 [517 kB]
Get:8 http://deb.debian.org/debian bookworm/main amd64 libltdl-dev amd64 2.4.7-7~deb12u1 [164 kB]
Err:9 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-master 1.6.0.g8330bca-1+3.1 404 Not Found [IP: 195.135.223.226 80]
Err:10 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ libethercat 1.6.0.g8330bca-1+3.1 404 Not Found [IP: 195.135.223.226 80]
Err:11 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.39.0.g4299f7a-0 404 Not Found [IP: 195.135.223.226 80] Fetched 2,951 kB in 0s (6,985 kB/s)
[code][code]
[/code][/code]
09 Nov 2024 22:50
[SOLVED] Rigid tapping problem - tristate_bit and index-enable?
I recall you (i think it was you) having issues with carousel component and/or orient, not sure exactly, so if this is the same thing here it would be nice to also update that topic, if not = i will retreat in my comfy chair and continue reading/watching.
  • Jeff in Wa
  • Jeff in Wa
09 Nov 2024 22:33
Replied by Jeff in Wa on topic Conditional block - Probing routine
Category: O Codes (subroutines) and NGCGUI
I just added this:
(debug,Probing result: #<_current_tool>)
O120 IF [ #5400 EQ 99 ]
G53 G1 F[#<_TravelFeed>] Z[#<_TravelZ>] ; Move Z0 for traveling
G53 G0 X[#<_ProbeStandOffX>] Y[#<_ProbeStandOffY>] ; Move to probe stand-off position
ELSE
G53 G1 F[#<_TravelFeed>] X[#<_ToolChangeX>] Y[#<_ToolChangeY>] ( Moves to tool setter for manual tool change )
O120 ENDIF
The message result was Probing result: 0.000000
I'm beginning to think, either I don't have access to the tool when entering M6 T(tool number), or there is a different way to do this.
  • spumco
  • spumco
09 Nov 2024 22:28
@Tommy,
This is the same mill I've been trying to sort out ever since I started fiddling with LCNC.  Like 4 years since it's worked properly.
I had a minor ATC crash late summer 2023 as I was about finished with the rebuild due to some issues with carousel.comp and my config.  And before I could get back in to troubleshooting the mill, I got a long-term, complicated paying project that took priority until we delivered the machines last May.
And the CNC lathe I'm building has been waiting on some parts to be machined by a friend since May 2023.  Those were mostly done as of a week or two ago.
So priority 1 is finish the mill.  And then finish the lathe.
  • Jeff in Wa
  • Jeff in Wa
09 Nov 2024 22:24
Actually, I just tried adding this and it worked:
(debug,Probing result: #5061, #5062, #5063, #5400)
Now I know why the top section isn't working:
Proving result: -1.28423, 1.042565, -54.0855234, 0.0000000
So, #5400 isn't passing what is in linuxcnc.var file #5400
Great...
  • PCW
  • PCW's Avatar
09 Nov 2024 22:23
If you don't get a power LED at 5V, that's not a good sign
as it may indicate a 3.3V power issue (bad chip?)
Displaying 18151 - 18165 out of 24291 results.
Time to create page: 0.391 seconds
