13 Jan 2025 01:32
Replied by Cant do this anymore bye all on topic Real-time kerel not detected on patched 6.12
To be perfectly honest I can't recall any instability or kernel crashed in the last 10 years. If I have had any it would be down to myself doing something silly to cause it. In using Linux, specifically Mint, as a daily driver I haven't seen any stability issues. I use Linux exclusively, except for the rare occasions I need to use my Needham Eeprom programmer then I pull out an old Thin client running Win98.
To be fair I'm not one that has to be "on the bleeding edge", so I don't try and push the envelope. Up until 3 years so ago my file server\media server was running Slackware 14.2. I changed to Ubuntu as it doesn't take a whole day to build packages to install something like gitlab on Ubuntu.
Once again you've been a true gent and really patient during this discussion, and after sometime you showed me the way. Even tho I was wrong I feel more educated on the subject.
Cheers
Rob
13 Jan 2025 01:18
Replied by Cant do this anymore bye all on topic RPi 5 with 6.12 PREEMPT_RT = Using POSIX non-realtime
Category: Installing LinuxCNC
Perhaps a unified test platform for the "sysgen" aspect would help.
Tom
Tom would you like to elaborate on what you mean ?
  • peterdownunder
  • peterdownunder
13 Jan 2025 01:12 - 13 Jan 2025 02:08
Replied by peterdownunder on topic Jog not working on new install
Category: Plasmac
Also the thing that sticks out is that the step-gen is also removed, as this is done on the weeny card, but cannot see anything that is needed to enable that (and the homing works ok)
I will post the working gmocappy that worked originally
  • peterdownunder
  • peterdownunder
13 Jan 2025 01:09
Category: Plasmac
That is sort of what I tried. Unfortunately the new configs can only be made for a parallel port or a Mesa card.
Since this is a raspberry pi the parallel port won't run. I do have another working CNC that is running a Mesa, but that is operational and in use at the moment.
What I attempted here was to use the sample config I had to get a working gmoccapy, which worked fine, including jogging.
I then ran the wizard with the par_port option and qtPlasmac as the front end to create a default plasmac config.
I then replaced the par_port and associated hal nets, mainly just the joints and limits with the ones from the working gmoccapy config.
Unsure if there is a better way to achieve this.
13 Jan 2025 00:53
Replied by tommylight on topic Jog not working on new install
Category: Plasmac
Make a new QtPlasmaC config, make sure it works properly, only then try to do modifications.
13 Jan 2025 00:47
Replied by tommylight on topic cnc sur bordeaux
cnc sur bordeaux
Category: Français
From google translate
people in Bordeaux and surrounding areas to exchange, share and discuss on LinuxCNC with a beer
  • peterdownunder
  • peterdownunder
13 Jan 2025 00:46 - 13 Jan 2025 00:48
Category: Plasmac
The commented out jogs are from the sample that comes with the card I am using.
Am trying to jog using the arrow keys on the qtPlasmac GUI.
The startup shows these as disabled as expected, and when each axis homes they become active.
If I press one the the axis value increments, and the display show the head moving in the corresponding direction, but the motors do nothing.
MDI command like G0X100 do the same
13 Jan 2025 00:46
Replied by tommylight on topic Everlast supercut 50 wiring
Category: Plasma & Laser
Open it, take some pictures on the inside, post them here ...........
  • PCW
  • PCW's Avatar
12 Jan 2025 23:49
Replied by PCW on topic Building a chain driven Plasma table.
You likely need to disable IRQ coalescing as described in the hm2_eth manual page
man hm2_eth
  • car_nut
  • car_nut
12 Jan 2025 23:27
G3 command ignores and resets M67 feedrate?
Category: Plasmac
Hello all, could use some help.  Currently in the final throws of getting a new build up and running:
QtPlasmaC V2.9-238.314
Raspberry Pi5
Mesa IO boards
Sheetcam and associated post processors
I realized that my THC was active on holes, which then led me to see that M67 commands weren't working for my holes.  Further investigating showed the following:
  • M67 is working as I expect it to if G1 linear commands follow in lines below
  • When a G3 is encountered, it resets feedrate to 100% and executes the arc at 100%
  • I didn't test G2 yet
  • If an inline M67 is issued with the G3, it will execute the arc at commanded rate.  For example, have the following as one line of code:
    • G3 X0.0 Y0.0 I-0.2 J-0.2 M67 E3 Q50
  • However, after executing the above correctly it STILL resets feedrate back to 100%
I don't believe this is the expected behavior, my apologies if it is.  If it is the expected behavior, can someone point me to a Sheetcam post processor that would format it as such?
Thank you!
  • Lcvette
  • Lcvette's Avatar
12 Jan 2025 22:39 - 12 Jan 2025 22:41
Replied by Lcvette on topic Probe basic Install errors
Category: QtPyVCP
That's why that's for Developers only that is why it's not running, is setup to run in a virtual environment only, follow the apt install instructions for install and all should work.
kcjengr.github.io/probe_basic/stable_quick_start_apt.html
  • gblcody
  • gblcody's Avatar
12 Jan 2025 22:00
Replied by gblcody on topic Probe basic Install errors
Category: QtPyVCP
I first tried installing using the guide but it seems part of the links are broken. I then eventually found the script to install it on git. github.com/Lcvette/qtpyvcp-bookworm-inst...r?tab=readme-ov-file
So I installed Debian 12 and followed the steps on the git. This is where I know I can get the dev version to launch, but when I set up my machine file, it just never launches. I will join the FB group going forward.
  • eg
  • eg
12 Jan 2025 21:31
Replied by eg on topic 7i96S control HY VFD using RS485
Category: Driver Boards
Yeah, at this point it's not worth my time to look into it, so I just used my USB adapter and it's working perfectly.
I'm planning on upgrading my VFD and spindle to a proper setup in the future, so hopefully I'll be able to use mesa_modbus then.
12 Jan 2025 21:19
Replied by tommylight on topic 7i37 vs 7i48
7i37 vs 7i48
Where can i buy both cards and thcad2 from europe in good prices ?
www.eusurplus.com
www.welectron.com/navi.php?k=324
12 Jan 2025 21:16
Replied by tommylight on topic Maus funktioniert nicht bei Spindel Start
Category: Deutsch
-Get another mouse with better/thicker cable
-Put a ferrite "doughnut" on the motor wires just outside of the VFD
-Put a diode in parallel with the relay coil, mind the polarity
Displaying 20131 - 20145 out of 20280 results.
Time to create page: 0.558 seconds
