  • JamesHoward
  • JamesHoward
05 Aug 2024 11:28
Replied by JamesHoward on topic Is a parport fast enough?
Yes, they do! As do VFD's.
  • RLA
  • RLA
05 Aug 2024 11:16
Hardware needed to switch from mach 3 6 axis to linuxcnc 9 axis
Mesa 7i96S can do 10 axis just by adding a simple BOB (it can do without BOB, but wiring must be careful).
If you do not need much input/output pins, go for that one, later you can add whatever you might need, like 7i85S or 7i84 or even analog servo drives with 7i83.
Hi..thanks for reply....I am not really clear about exactly I will need so this looks like a good start that sets up for anything in future..some of what is foggy at this time is the difference between mach 3 and lcnc...obviously 9 axis are available in lcnc and not mach 3 but also different board is needed to match up  right?...then is BOB an extension of 7i96s? as opposed to mach3 goes to BOB first ,then ESS?...Thanks!!,
Rick
05 Aug 2024 10:29
Replied by tommylight on topic linuxcnc 2.9.2 ethercat problem
Category: EtherCAT
Anyone against deleting this topic?
05 Aug 2024 10:28
Replied by tommylight on topic Is a parport fast enough?
Plasma makes a lot of noise...
And so do servo drives, but not nearly as much as plasma cutters.
  • meister
  • meister
05 Aug 2024 10:21 - 05 Aug 2024 10:21
  • rodw
  • rodw's Avatar
05 Aug 2024 10:13
EtherCAT i/o board for spindle, estop and mpg
Category: EtherCAT
I thought so but not sure how that maps to A+ and B+
  • avive
  • avive
05 Aug 2024 09:34 - 05 Aug 2024 09:40
Category: EtherCAT
In case anyone needs it, here is the current link to the product:
aliexpress.ru/item/1005007328938566.html
And also attached the archive with documentation I found:
www.gzyanwei.com/upload/Files/2022/11/21/Ecat-IO_V2.zip
This board has one input for the encoder and two inputs for counters. The first input will definitely be occupied by the spindle. Do you think it is possible to use the counter input for the MPG?
  • meister
  • meister
05 Aug 2024 09:00
Hi Russell,
you just have to pay attention to the HDMI pins and the 1.8V output on BANK3 (you can use it for 3.3V input)
the capacitors on the HDMI output can be remove, but than, you can not use the HDMI-Port anymore on the TanNano9k board.
if you need more pins, you can use shiftregister's, bud not for Highspeed-Encoder or pwm generation (including dir-pins), the shiftregs are very fast but produce some jitter.
@cornholio
thanks for testing, sounds good :)
  • avive
  • avive
05 Aug 2024 08:45 - 05 Aug 2024 08:52
Category: EtherCAT
CATIO-A
Thanks! Looks like I found it.
  • rodw
  • rodw's Avatar
05 Aug 2024 08:38
Category: EtherCAT
Odd, it works for me CATIO-A
  • meister
  • meister
05 Aug 2024 08:36
pyvcp xml-parser - small test to display pyvcp xml files in pyqt5
Category: Other User Interfaces
not perfect, but maybe a starting-point for other developer
python3 pyvcp-parser.py /usr/share/doc/linuxcnc/examples/sample-configs/apps/pyvcp/pyvcp_demo1.xml
  • epineh
  • epineh
05 Aug 2024 08:31
Hey guys awesome work so far, I would like to make a PCB for the Tang Nano 9K to plug into, basically a pin for pin copy of meister's Tango board, but with provision for a few extra bits that I'd like. Mainly provision for closed loop control of brushed DC servos.
My plan is to basically copy and paste the line receiver circuitry of my existing servo drives that I've been using for years and use that for the encoder feedback.
My question is which remaining pins on the Tang Nano are best suited for this task ? If possible I'd like a minimum of 5 axis so thats 10 inputs, 15 if we bring a Z pulse for homing/spindle/threading per axis. I realise there's only so many pins to go around but I'd drop a couple of standard inputs off the board if it meant it would all fit.
Also I'd be happy to post the layout once its finished/working and tested for others to use, but be warned I am going to use through hole parts as much as possible, I am old, have bad eyesight and have found out the hard way that through hole PCB's are more resilient to harsh climates, temperatures/humidity etc than PCB's with tiny surface mount parts.
Cheers.
Russell.
  • Aciera
  • Aciera's Avatar
05 Aug 2024 08:28
Replied by Aciera on topic Trajectory Planner using Ruckig Lib
However, best is to send just the coordinates to a servo drive. That saves the pc a huge ammount of
calculation time over 9 scurve axis.
I was under the impression that most of this could be done outside of the realtime thread. The filleting algorithm for example, couldn't that run before actual gcode execution?
  • avive
  • avive
05 Aug 2024 08:13
Category: EtherCAT
I think this would be a good I/O module but you would need to create the generic xml which is not hard There may be an xml file here somewhere.
www.aliexpress.com/item/1005004377766525.html
Could you please write the name and model? There is no product at the link.
  • avive
  • avive
05 Aug 2024 08:11
Category: EtherCAT
You need el5102 module with two encoder interfaces, one for spindle and one for handwheel AB phase
Yes, I can assemble everything I need using Beckhoff modules, but it will be very expensive.
Displaying 24376 - 24390 out of 24521 results.
Time to create page: 0.509 seconds
