  • Lcvette
  • Lcvette's Avatar
31 Jan 2026 15:40
Issues setting up Tool setter / manual tool change
Category: QtPyVCP
what version of probe basic? how did you install it and when did you install it?
  • tjtr33
  • tjtr33's Avatar
31 Jan 2026 15:21
Sinker EDM machine based on diy pulse generator
some good reads on edm p/s
langfordw.pages.cba.mit.edu/desktopWEDM/electronics/
github.com/Bijoo/EDM-pulse-generator
oshwlab.com/ehdesignlabs/wire-edm
the G-EDM project looks good
there have been a few updates/chgs to design
Usimg an inductor is reminiscent of the Charmilles P25
github.com/G-EDM
tomp
  • NT4Boy
  • NT4Boy
31 Jan 2026 14:07
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
After some more studying, I realise that the mux2 doesn't have an output.
Not sure even now I have done that correctly.
I think I am now closer. After issuing M19 R45, the mux switches, but the spindle-output  isn't being populated.
Odd as the spindle still runs with M3 command.
File Name: spindlecon...1-31.hal
File Size:4 KB
  • meister
  • meister
31 Jan 2026 12:31 - 31 Jan 2026 12:31
Replied by meister on topic 7i92 cnc motion controller from aliexpress?
Category: Driver Boards
you can use the cheap 5Axis-BOB's
Firmware: 5ABOBx2D
  • Stephan@work
  • Stephan@work
31 Jan 2026 11:26
Configure Mesa 7i96s and pktuart with Omron MX2 (wj200)
Hey Guys,
this is Stephan from Germany. A 39 years old HW/SW Engineer without any clue about LinuxCNC.
I retrofitted my old Gravorgraph VX92 with a Mesa 7i96s and a Vdf Omron MX2 ( similar to Hitachi WJ200).
LinuxCNC was working with some USB/RJ485 Dongle, and i was able to run my Vdf without any issues.
Thank you for all these comments in this message board. Without your help with other peopleś issues, I would still have to operate my milling machine by hand.
I tried to connect my Vdf without these ModBus USB-Dongle and connected it to the Vdf.
After wasting days to get it running, i decided to write my first question in a forum.
I took my oscilloscope to measure the output of the mesa 7i96s (modbus_mesa.png, not connected with the Vdf this time).
The signal looks pretty fine, but compare to the USB/RJ485 Dongle signal (modbus_USB.png),
I saw only a few packages every 20 seconds.
The Signal of my USB/RJ485 was running every ~10ms (not connected with the Vdf either).
HAL:
SPINDLE <--->  MODBUS <---> MESACard
loadrt   wj200-vfd ports=hm2_7i96s.0.pktuart.0
addf     wj200-vfd.00 servo-thread
setp     wj200-vfd.00.address                  1
setp     wj200-vfd.00.baudrate                9600
setp     wj200-vfd.00.parity                      0
setp     wj200-vfd.00.update-hz               0.1
mod file:
The format of the channel descriptors is:
{TYPE, FUNC, ADDR, COUNT, pin_name}
TYPE is one of HAL_BIT, HAL_FLOAT, HAL_S32, HAL_U32
FUNC = 1, 2, 3, 4, 5, 6, 15, 16 - Modbus commands
COUNT = number of coils/registers to read
#define MAX_MSG_LEN 16   // may be increased if necessary to max 251
static const hm2_modbus_chan_descriptor_t channels[] = {
/*  {TYPE,     FUNC, ADDR,   COUNT, pin_name} */
    {HAL_BIT,   5,   0x0001,    1,  "run"},
    {HAL_BIT,   5,   0x0002,    1,  "reverse"},
    {HAL_BIT,   1,   0x0014,    1,  "is-at-speed"},
    {HAL_BIT,   1,   0x000F,    1,  "is-running"},
    {HAL_BIT,   1,   0x0018,    1,  "watchdog-out"},
    {HAL_FLOAT, 3,   0x1003,    1,  "motor-current"},
    {HAL_FLOAT, 3,   0x1019,    1,  "heatsink-temp"},
    {HAL_FLOAT, 6,   0x0001,    1,  "commanded-frequency"},
Does anyone knows these issue ?
Thank you so much !
Best Regards,
Stephan
  • Aciera
  • Aciera's Avatar
31 Jan 2026 10:57
Replied by Aciera on topic Strange preview for circular arc (G2/G3)
Category: G&M Codes
Testing on current 2.9.8 with the G0 move commented give me this, which is not quite correct but it's not as wrong as what you got:
  • rodw
  • rodw's Avatar
31 Jan 2026 09:06
Stepperonline Y series/ YAKO YKD2608PE configuration
Category: EtherCAT
yes you need to write an XML file now
  • masawee
  • masawee
31 Jan 2026 08:30
Replied by masawee on topic 7i92 cnc motion controller from aliexpress?
has anybody build hardware to mesa 7i92 board, how has made all input optocoupler board and output safety wiring to stepper drivers, i think if can build own output safe board to connection port 1 and all input pin optocoupler board connection 2, and were found bit file were have all output at connector 1 and all input have at connector 2, then have logical perfect all in/out pins configured.
  • masawee
  • masawee
31 Jan 2026 08:12
Replied by masawee on topic Adding USB Keypad
Adding USB Keypad
how can add my linuxcnc 2.8.4 V whit mini usb wireles keyboard controll select continue or 1mm, 0,1mm not need go to display select this whit mouse, lot easy if can remote controll this scale or continue selection on to table i setting bit zero point.
  • rodw
  • rodw's Avatar
31 Jan 2026 06:40
PLC + LinuxCNC for industrial machine with simple HMI (non-G-code operators)
I don't think many people use a PLC in conjunction with Linuxcnc. There is an Ethercat master we have a driver for so getting IO and the like is pretty easy. Stick to Beckhoff for best support but making a custom XML driver for other IO and drives is pretty simple. Whilst people have mentioned Ladder Logic which is available, the secret magic nobody seems to mention is you can write hal components which when built and installed with a 1 line command : sudo halcompile --install mycomp.comp. Once these are built, they are treated exactly as if they are part of the core program and run in real time.
I do know a guy who has retrofitted a lot of big machines and recently on one big 5 axis machine with 100 tools and multiple pallet changers, the ladder wasn't doing it for him so he learnt a smattering of C and knocked out his working high speed tool changer component over a weekend.
  • rodw
  • rodw's Avatar
31 Jan 2026 06:25
How to update QtDragon_HD to latest version?
Category: Qtvcp
you have it. Best to build from source. then  Just do a git pull and make again  for the absolute latest I did a video recently on my @MrRodW youube channel
  • NWE
  • NWE's Avatar
31 Jan 2026 05:32
This is similar to how many industrial robotic cells are structured, where a dedicated motion controller handles paths, and a PLC controls the cell logic and operator interaction.
So the question is not whether LinuxCNC can do everything, but how others have structured a clean responsibility boundary between a real PLC and LinuxCNC in production machines.
Any practical examples along those lines would be appreciated.
I think of this: LinuxCNC has capability to be operated by the user, entirely using keyboard+mouse+monitor, at opposite extreme it can have external I/O wired to physical buttons, switches and dials for operator control without any keyboard+mouse+monitor if you wish.
I'm thinking wire connections from your PLC I/O to LinuxCNC I/O to "drive by wire"? Cycle start, Feed hold, etc. maybe also jogging, whatever you need can be brought out on a wire and connected to your PLC.
The Fanuc 6-axis robot bag palletizer I've been reprogramming lately is connected to an Allen Bradley PLC via ethernet/IP. I have never heard the words "LinuxCNC" and "ethernet/IP" in the same sentence, but I've been meaning to explore the possibilities. I have about $1500 usd worth of new Beckhoff ethernet/IP remote I/O hardware on the shelf for nearly a year now, that I plan to connect with LinuxCNC. My big hurdle has been my nil experience with ethernet/IP. Now on this Fanuc I got an idea what ethernet/IP configuration looks like...
  • NWE
  • NWE's Avatar
31 Jan 2026 05:05
Admittedly, the Click PLCs are fairly 'low-end', so higher-end PLC's likely have more sophisticated onboard motion control features.
I've always had good results with AutomationDirect's Click PLC's. But I've been disappointed with the reliability of their Productivity 2000 and also their BRX models. Maybe it was just bad luck. I've finally retrofitted most of my higher end AutomationDirect PLC's but those Clicks sure don't seem to make much trouble. Still I don't care for ladder logic.
The very first project I sold containing a Productivity 2000 quit about a week after it was out the door. I tried reprogramming it, also tried updating its firmware, no go. I was able to read out some error logs. Automation tech support told me it is bricked, and that they have been having that trouble with that one firmware version. I have to return it for warranty. They gave me a choice of sending back the bricked plc then after they have it back, they send me a replacement. Or I can buy a new plc and they refund me when they get the broken one back. So I bought the new one and got the refund later because the customer was in a hurry. This was a $1200 USD PLC about 7yr. ago. (CPU + base + PSU + motion I/O) Even the base was bricked, that contained a CPLD on its motherboard.
  • NWE
  • NWE's Avatar
31 Jan 2026 04:34 - 31 Jan 2026 05:34
Just to be clear, in your setup you are using Beckhoff EtherCAT I/O as remote I/O, but without a Beckhoff PLC runtime (e.g. TwinCAT PLC), correct?
Yes, I'm using Beckhoff I/O strictly as remote I/O, all my logic exists in the pc running LinuxCNC
31 Jan 2026 03:14 - 31 Jan 2026 03:39
First conversion, Axiom CNC Router with RichAuto controls
Category: Show Your Stuff
Sorry i had no time to watch this, will do very soon.
Thank you.
OK, watched it, left a comment, nicely done and very detailed.
Displaying 3061 - 3075 out of 17272 results.
Time to create page: 0.464 seconds
