  • 3404gerber
  • 3404gerber
11 Jan 2026 11:27
Edit: Launched linuxcnc on terminal, getting "bad spi payload"
(Bad SPI payload = 32393a38)
The value of the payload is strange; it's almost half value of what you are suppose to get:
#define PRU_DATA            0x64617461     // "data" SPI payload
#define PRU_READ              0x72656164  // "read" SPI payload
#define PRU_WRITE             0x77726974  // "writ" SPI payload
#define PRU_ESTOP           0x65737470  // "estp" SPI payload
I'd try with a lower SPI frequency.
  • RotarySMP
  • RotarySMP's Avatar
11 Jan 2026 11:25 - 11 Jan 2026 11:26
Retrofitting a 1986 Maho MH400E
Category: Milling Machines
The Maho is back up and running again, but I still dont really know what the FError and MinFError "should" be for such a machine.
Thanks for your help.
  • hhscott
  • hhscott
11 Jan 2026 10:49
Startup Question was created by hhscott
Startup Question
Simple question that I cannot seem to locate the answer:
No matter what offset I was using when I shutdown LinuxCNC I want my DROs to read 0 after I restart and then home. I can do this with the Touch-Off button in Axis but how do I set my INI/HAL file to clear offsets when LinuxCNC restarts?
Of is there a mdi input that would have the same outcome?
Thanks,
HH
  • andrax
  • andrax's Avatar
11 Jan 2026 10:36
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Hi, that looks really good.
How stable is your system?
Have you ever had the problem where one of the Y-axes doesn't start moving during homing and the gantry is crooked?
That happens to me a lot. I have to restart the machine and then it works again.
  • dschultz
  • dschultz
11 Jan 2026 01:14
Replied by dschultz on topic StepperOnline A6 Servo
Category: EtherCAT
It's been almost a year since I originally started this thread and thought it might be of interest to give a status update on my machine.It's been humming along without issue powered by the A6 400watt AC ethercat servos.It is a 4x4 size router direct driven with ballscrews on all axis (XYYZ). I highly recommend the A6 servos for simple set-ups. Mine is not a demanding setup but for the cost, in my opinion they are an unbeatable value. Thank-you to those that gave me pointers when I was making the transition from step drive to ethercat!
10 Jan 2026 23:43
Replied by tommylight on topic QtPlasmaC + CoreXY Kinematics
That will most probably require a bit more hand editing as you also need to have some of the contents of 3joint_xyz.hal, but i do not recall exactly what or how, it was a long time ago since i used this.
Did you try changing the kinematics in the in file to
KINEMATICS = corexykins
And did that produce any result?
But first, does the machine have home/limit switches on X and Y ? That is a must.
  • deckname
  • deckname
10 Jan 2026 23:32
QtPlasmaC + CoreXY Kinematics was created by deckname
Hi everyone, i´m new here.I’m having major issues getting my LinuxCNC setup to work with QtPlasmaC and CoreXY kinematics.My setup:
  • LinuxCNC 2.9.6
  • Mesa 7i96s Ethernet + 3 steppers (X, Y, Z)
  • QtPlasmaC GUI
  • CoreXY kinematics (tried corexykins and corexy_by_hal)
QtPlasmaC seems to try to access pins and signals that don’t exist with CoreXY kinematics.
I had previously tried running the machine with SCARA kinematics, but I naively thought CoreXY would be simpler.
Is a setup like this possible for a beginner or should i try a different approach?
Why are kinematics that complicated and troublesome anyways?
Thanks in advance for any help!
10 Jan 2026 22:16
Replied by tommylight on topic Failure to find Named Subroutines
Category: O Codes (subroutines) and NGCGUI
Do those files need to be executable?
  • cnbbom
  • cnbbom
10 Jan 2026 22:01 - 10 Jan 2026 22:52
Replied by cnbbom on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
tommylight post=341235 userid=17274
andypugh post=341234 userid=723... No momento, não consigo visualizá-los.
+1
Peço desculpas, é que eu não gerencio repositórios e não percebi que os links estavam bloqueados.
1 drive.google.com/file/d/1xICFF-2mq_rz-vi...0W8/view?usp=sharing
2 drive.google.com/file/d/1WV1pdWmNyH8BmgD...qg-/view?usp=sharing
3 drive.google.com/file/d/14Z10IOZI5bvgmf_...Rn6/view?usp=sharing
drive.google.com/file/d/1fwGb5Qo9pw8lGLp...LOE/view?usp=sharing
  • Tomatendose
  • Tomatendose
10 Jan 2026 22:01 - 10 Jan 2026 22:13
Commission drive on AX5206) using TC3 to prep for linuxcnc-ethercat
Category: EtherCAT
Yes, you are right — I was able to update the AX5112 to firmware version 2.16. I can now configure it using Drive Manager 2. Thanks.
Now the next problem occurs: “PreOp to SAFEOP failed.”
Do any additional settings need to be made here?
10.01.2026 17:17:32 814 ms | "Antrieb 1 (AX5112-0000-0216)' (1001); 'PREOP to SAFEOP' failed! Error 'check device state for SAFEOP', AL Status Ox0012' read and Dx0004' expected, AL Status Code 0x0045 - MBX SoE'10.01.2026 17:17:32 814 ms | 'Antrieb 1 (AX5112-0000-0216) (1001); state change aborted (requested 'SAFEOP', back to 'PREOP).
An AX5801 industrial safety card is installed in the AX5112. The two safety inputs are currently supplied with 24 V. Could this be causing the problem?
The connected servo motor and resolver are not listed in the database, so we have to identify manually which type of resolver it is (Eco&Logic Syncrotech SY150…). From the old servo drive we know that it is a resolver.
  • MaHa
  • MaHa
10 Jan 2026 21:57
Replied by MaHa on topic Failure to find Named Subroutines
The percent sign %  in the calling routine could cause that error. Capital letters for the naming in the routine, maybe too
  • roycegb
  • roycegb
10 Jan 2026 21:17
Replied by roycegb on topic Failure to find Named Subroutines
tommylight;
The space in the original post was a typo. my file.ngc, no spaces.
MaHa;
I tied identical names with and without the .ngc suffix everywhere with no luck.
The attachment shows the result with all data shown as suggested.
I am suspicious that the program seems to be looking for 'Omyfile'   instead of simply O  'myfile'.  Could it be a parsing problem?
Thanks,
Royce
  • freemoore
  • freemoore
10 Jan 2026 19:59
  • PCW
  • PCW's Avatar
10 Jan 2026 19:46
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
Category: Driver Boards
Yes, you can feed the TTL signals through the 7I42TA
I can build the firmware in the next day or so
Displaying 4396 - 4410 out of 17031 results.
Time to create page: 0.355 seconds
