  • xenon-alien
  • xenon-alien's Avatar
01 Jan 2026 00:16
Replied by xenon-alien on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Category: HAL
Thank you for the files!
That is not a documentation, only a lot of not really understandable words.
The connection and reading I have tested.
Now i have to figure it out how to scale it correctly and how to transfer to the VFD the input commands.
  • nwallace
  • nwallace
31 Dec 2025 23:54
Replied by nwallace on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Category: HAL
Sorry, I am definitely not an expert in this. You can take a look at my config and the documentation here:
linuxcnc.org/docs/html/drivers/mb2hal.html
Attached is my mb2hal ini file and the spindle bits from my hal file. I am not an expert but I was able to figure it out just with the VFD manual and the documentation.
  • grandixximo
  • grandixximo's Avatar
31 Dec 2025 23:53
Replied by grandixximo on topic How to fix "Queue is not empty after probing"
I just checked master has new option for
[TRAJ]
NO_PROBE_JOG_ERROR = 1
in the .ini file, you could use that to check if the issue goes away?
you have to make sure your version supports this, it's just been added 4 months ago
31 Dec 2025 22:58
Replied by tommylight on topic Fusion 360 Win 10 EOL
Category: CAD CAM
Yeah, sorry, might have mixed you with PhillC, i have a very nasty habit of messing up names... and most probably you would too if you lived here where every person has one of 15-20 names used here. I was convinced this is my problem till about 15 years ago when i noticed i have no issues with complicated names that are not common here, but still the habit lingers ...
Also a non drinker.
23:58 here and the fireworks started....
Happy new year to all.
  • unknown
  • unknown
31 Dec 2025 22:11
Replied by unknown on topic Fusion 360 Win 10 EOL
Category: CAD CAM
Not I, I'm Linux only. Also a complete non-drinker, I had my share enough in my teens and early 20s.
31 Dec 2025 21:20
Category: CAD CAM
With that said I am sure it is already January 1st somewhere in the world . Has any one tried seeing if
Fusion 360 still works for them on Win 10?
RodW and "unknown" are in Australia so they are already in 2026, and i think both used Fusion360 at some point in time, and they both monitor the "recent topic" section of this forum, so maybe they chime in, granted new years day so might, might be hangover ... :)
  • grandixximo
31 Dec 2025 21:01
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
Yes, it is there, unfortunately to test the original code you have to have subpar CPU latency, have some glxgears running, and halscope to simulate/induce bad latency, then you probably have to restart a whole bunch of times, in my case I methodically restarted 100's of times, moved and checked the ferror while moving for the grinding, the better your latency is the less probability you will land on the bad window randomly, by inducing some strong latency on my system running graphical processes which I know give me spikes, I was able to get grinding in the ferror about 20% of the times, without purposely inducing latency I would see it 5% of the times, and I'd really have to look for it with halscope, because opening halscope and plotting the ferror would actually make the latency worse, and the consequently I spotted it more often, without halscope running I could potentially see it only once every 100 restarts if ever, which makes the issue incredibly rare with good latency, the original code was good at syncing, but phasing was random so if you ever were to end up in the grinding window, a restart would have fixed it almost always, phasing was random as far as I tested before my fix.
  • PCW
  • PCW's Avatar
31 Dec 2025 20:46
Replied by PCW on topic 7i97t Mesaflash Problem
Hard to tell whats going on could be you have the wrong output
or there's a hal or hardware issue. To determine whats going on,
can you run LinuxCNC, enable motion, and then in a terminal window run:
halcmd show all | grep pwm > pwm,.txt
and then post pwm.txt here
31 Dec 2025 20:35
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
Category: Milling Machines
Do you have the schematics for the drives?
This is just thoughts on how i would go about checking this, might be OK now that i had some time to analyze the symptoms :
-first check the power going to EXE boxes, is it the same voltage on all 3 or 4 of them?
-is the power for the EXE coming from the Indramat drives?
-if yes, are they all powered from the same rail or do each have it's own power regulator?
Assumption: given the info i would check the Indramat drive for rust on the EXE power rail, it is just to convenient given X is fine, Y faults at the end (meaning a bit lower voltage so accumulating PID error), and Z faults immediately, this also assumes the voltage regulator to be near the X axis drive/feedback and furthest from Z axis drive/feedback
-All of the above is valid if drives/motors use tachos, so same checks on the tacho feedback voltage regulators.
Stopping here for now, to much assumptions and unknowns that need confirmation or denial! :)
  • Robin123
  • Robin123
31 Dec 2025 20:34
Replied by Robin123 on topic 7i97t Mesaflash Problem
But no matter what the value is set to or how I change the scale, the Mesa only ever outputs ~0.35V. Or are there jumpers or something similar on the Mesa hardware that I need to adjust?
Thank you so much for your help! I really appreciate it.
  • PCW
  • PCW's Avatar
31 Dec 2025 20:29 - 31 Dec 2025 20:31
The output voltage should be PWMvalue/PWMscale
So if PWMscale is 10 the output voltage=PWMvalue
  • my1987toyota
  • my1987toyota's Avatar
31 Dec 2025 20:26
Replied by my1987toyota on topic Fusion 360 Win 10 EOL
Category: CAD CAM
So it's December 31st 2025 and I am curious if Fusion 360 will actually stop working on my Windows 10
machine at 12:00am January 1st 2026.  As I write this message it's 3:20 pm and currently Fusion 360 is
still operational.  I will keep it logged on to Linuxcnc and Fusion 360 and update on my findings.
  • Surmetall
  • Surmetall's Avatar
  • Thllll
  • Thllll
31 Dec 2025 20:14
Freelancer wanted to get tool sensor working (software)
Category: User Exchange
Still looking for a freelancer to help get a tool sensor setup in software
  • RotarySMP
  • RotarySMP's Avatar
31 Dec 2025 19:56
Thanks guys. I am collecting up the wisdom of the crowd, and will try to work through everything systematically.
Displaying 4891 - 4905 out of 16967 results.
Time to create page: 0.275 seconds
