- MaHa
- MaHa
23 Mar 2026 11:27
Replied by MaHa on topic Updating Old GladeVCP Files?
Category: GladeVCP
It worked for me in the virtual sim environment, debian 12, glade 3.4 installed and axis.mm sim. It was embedded as sidepanel. And the screenshots made when set example pin true/false.
- meister
- meister
23 Mar 2026 11:14
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
- hitchhiker
- hitchhiker
23 Mar 2026 11:02
Replied by hitchhiker on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Could you please explain how you connect the 7c81 via ethernet?
- backyardengineer
- backyardengineer
23 Mar 2026 10:19
Closed loop - encoder/position not updating while moving was created by backyardengineer
Category: HAL
Hello,
i am currently stuck implementing a direct closed loop (2 axis lathe, parallel port, stepper motor, linear scale for closed loop).
The problem is: I do get the right position feedback, when moving manually (DRO display is correct) and i can see the correct encoder positions (in Hal-Scope: encoder.0.position). However, as soon as i try to move the axis, it starts to move and errors out with following error. If i look in the hal-scope, the "encoder.0.position" does not move one bit during the move (stepper is moving).
--> Why does read out the position while idling but not while moving ?
23 Mar 2026 09:58
Replied by Todd Zuercher on topic Updating Old GladeVCP Files?
Category: GladeVCP
When I tested the above code, it would change the text, but the color stayed black (no color changes)
- grandixximo
23 Mar 2026 08:47
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
Try with synctorefclock false, and see if your reset counter also counts up or not
- TAKUYA
- TAKUYA
23 Mar 2026 08:09
Replied by TAKUYA on topic Ethercat random jitter fix
Category: EtherCAT
@grandixximo
Sync0shift is set to 300000
23 Mar 2026 07:47
Replied by Aciera on topic Schaublin 125-CNC retrofit.
Category: Turning
Note that LinuxCNC only supports Python3/Gtk3 from version 2.9.x so if you are using any custom python or glade code you would have to port those files to python3/gtk3.
In my opinion you'd be better off getting a second ssd and do a fresh install of 2.9.8 on that. Once you get that installed port your config files from the current drive to the new one.
- Hakan
- Hakan
23 Mar 2026 06:23 - 23 Mar 2026 06:26
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
Did you say you had changing values on pll-reset-count? That one should stay on 1, not increase.
Can you perhaps record pll-err in halscope and show?
22 Mar 2026 23:47
Replied by tommylight on topic Schaublin 125-CNC retrofit.
Category: Turning
From google:
Debian 10 "Buster" reached its official End of Life (EOL) and concluded Long Term Support (LTS) on
June 30, 2024. After this date, Debian no longer provides official security updates or bug fixes, making systems vulnerable.
Try this at your own risk.
gist.github.com/ishad0w/6ce1eb569c734880...#gistcomment-5812428
Personally, i will never understand why risk a perfectly working system for absolutely no reason, IF there is nothing you absolutely need/require. I have machines with Ubuntu 8.04 still in daily use. No internet, usually, so...
22 Mar 2026 23:35
Replied by tommylight on topic Results of latency test, list of computers tested for use with LinuxCNC
Looks perfectly fine, thank you.
- grandixximo
22 Mar 2026 22:29 - 23 Mar 2026 01:14
Category: EtherCAT
@TAKUYA
Is your
sync0Shift="0"
You should set sync0Shift to 250000 or 500000
sync0Shift to 0 is not correct, as per my understanding of the ethercat DC specifications.
Is your
sync0Shift="0"
- miniwini
22 Mar 2026 21:45 - 22 Mar 2026 21:47
Replied by miniwini on topic Results of latency test, list of computers tested for use with LinuxCNC
this is my actual running system... i´m quite impressed...
What do you think?
cheers miniwini
LinuxCNC pc tests, version 20200930, started 22.03.2026 20:33:53
General info:
ASRock, To Be Filled By O.E.M.
Bios version P3.40, dated 07/17/2019
Chipset: Advanced Micro Devices, Inc. [AMD] 400 Series
Harddisk is rotational
The amount of swap currently used is 0
CPU related data:
model name : AMD Ryzen 5 2600X Six-Core Processor
cpu cores : 6
stepping : 2
cache size : 512 KB
RAM related data:
Maximum Capacity: 128 GB
Maximum Voltage: 1.2 V
Non-Volatile Size: None
Volatile Size: None
Cache Size: None
Logical Size: None
Size: No Module Installed
GPU related data:
product: GK104GL [Quadro K5000]
configuration: depth=32 driver=nouveau latency=0 resolution=1366,768
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 6.1.0-30-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash isolcpus=5 idle=poll"
Cpu idle driver: none
Kernel modules data:
Check if pcspkr is loaded: [0;31mYes, may cause bigger latency.[0m
can be eliminated using:
sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: [0;32mNo, which is good
22 Mar 2026 20:18 - 22 Mar 2026 20:19
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
So I checked and my lathe is running Lcnc 2.8.2 on Debian Buster, with RT 4.19.
Since Buster is still okay per the updating instructions, I thought Id try an update.
I added the repository.
but get errors
I attached the full error log.
Does this mean Buster can no longer be updated?
Cheers,
Mark
but get errors
Cheers,
Mark
Time to create page: 0.557 seconds
