  • FPVUALAB
  • FPVUALAB
29 Dec 2025 00:48
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Category: Driver Boards
Hello. I need a breakout board for a Chinese circuit board (Mach3 interface board) 5Axis Breakout Board.
  • JT
  • JT's Avatar
28 Dec 2025 23:22
Replied by JT on topic Disable pushbutton
Disable pushbutton
Category: Flex GUI
Let me verify how to do that, it should be simple but I want to test first.
JT
  • MaHa
  • MaHa
28 Dec 2025 23:17
Replied by MaHa on topic Disable pushbutton
Disable pushbutton
Category: Flex GUI
With function mdi and command M66E0L0 the button is disabled while running a program and that doesn't affect its initial functionality. But still hoping there is another way to do that.
  • PCW
  • PCW's Avatar
28 Dec 2025 21:50
LinuxCNC + Mesa 7i43 – Axis A stepper (stepgen), error
Category: HAL
By error I mean:
What does LinuxCNC report?
Can you post the complete hal file?
  • manny
  • manny
28 Dec 2025 21:45
Category: HAL
I meant it as an error — I’m not sure how to configure it, what I’m doing wrong, and why the AXIS_A code is written incorrectly. please
  • Thllll
  • Thllll
28 Dec 2025 21:11
Replied by Thllll on topic Probe Error causes Jog lockout
Category: QtPyVCP
Axis works fine, QT dragon also works fine. Its just Probe Basic
  • Thllll
  • Thllll
28 Dec 2025 21:01
  • andypugh
  • andypugh's Avatar
28 Dec 2025 20:28
Replied by andypugh on topic Probe Error causes Jog lockout
Category: QtPyVCP
I don't see this in 2.9.7 with Axis (I don't have a Probe Basic setup to test with)
Can you see if you see the same issue in Axis with one of the sim configs? (This won't affect your real config)
  • MaHa
  • MaHa
28 Dec 2025 19:01
Disable pushbutton was created by MaHa
Disable pushbutton
Category: Flex GUI
I am looking at disable a pushbutton during program runtime. No idea how to do. It is connected to python module, and should not
be enabled during runtime. Is there a setting, it gets greyed out, eg. like mdi-button?
  • cmorley
  • cmorley
28 Dec 2025 18:45
Replied by cmorley on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
What version of linuxcnc are you using?
  • cmorley
  • cmorley
28 Dec 2025 18:17
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
There is a version of nativecam in a linuxcnc branch that mostly works.
It's a work in very slow progress. It's based on Qt.
github.com/LinuxCNC/linuxcnc/tree/qt_ncam
There is also another project I've seem on the forum that keeps it gtk based and just updates it to python3 and whatever pygtk is called now.
But I would suggest you just finish what you have built, as it seems you are pretty far along.
You could always convert it to another platform later.
  • RotarySMP
  • RotarySMP's Avatar
28 Dec 2025 17:12
How to install simplescreenrecorder on old version of Debian?
Thanks guys.
I did do:
apt-get update
before I started.
I just ran it update again to check, and the distro is wheezy.
I watched Rods video, but don't want to update to LCNC 2.8 or above as I have had a working system, and don't have the time to play around getting it configured again for the joints change, mesa card latency etc.
Cheers,
Mark
  • Thllll
  • Thllll
28 Dec 2025 16:52
Freelancer wanted to get tool sensor working (software)
Category: User Exchange
Mr.Rodw big fan of your work! I wouldnt disagree with that however if there is solution to continue to use ER16 tooling (I should have mentioned that in the og post) then I would rather do that then invest in a TTS spindle and TTS collets. I know there is a solution to this
  • PCW
  • PCW's Avatar
28 Dec 2025 16:40
  • aDm1N
  • aDm1N's Avatar
28 Dec 2025 15:38
Category: Qtvcp
NativeCAM is an interesting project, but it has a fundamental issue today:the codebase is very old (Python 2, GTK2/PyGTK) and has not been actively maintained for quite some time. I have taken a closer look at the project locally and am currently trying to get it running on a modern system (Debian 13, Python 3, LinuxCNC 2.10). At the moment it already fails at the basic dependency level, since Python 2 and PyGTK are essentially unavailable on current distributions. Before discussing any functional extensions, a significant porting effort is required (Python 3, GTK3/gi).Only if NativeCAM can be made stable on a modern system does it make sense to consider whether and how the lathe functionality could be extended or reimplemented. For now, my focus is not on new features, but solely on determining whether the project is still technically viable as a future foundation.
Displaying 5071 - 5085 out of 16972 results.
Time to create page: 0.379 seconds
