  • gravedigger
  • gravedigger
18 Dec 2025 06:47
Replied by gravedigger on topic MVO to RO
MVO to RO
Category: Gmoccapy
  • rodw
  • rodw's Avatar
18 Dec 2025 03:03
Replied by rodw on topic MVO to RO
MVO to RO
Category: Gmoccapy
Its really important to read the instructions for the version of LInuxcnc you are using. Often a Google search will display dated info
  • PCW
  • PCW's Avatar
18 Dec 2025 02:23
Replied by PCW on topic MVO to RO
MVO to RO
Category: Gmoccapy
Instead of rapid.rapid-override, it should be rapid-override.
What manual is this in and what LinuxCNC verison?
(the current halui man page does not have this error)
  • cmorley
  • cmorley
18 Dec 2025 02:18
  • frayja2002
  • frayja2002
18 Dec 2025 01:18
Replied by frayja2002 on topic USB pendant button to zero axis
Thanks for that.
With a bit of fiddling I have some code that is doing the job....
My halui was set up like this
[HALUI]
# add halui MDI commands here (max 64)
MDI_COMMAND = O<b01-go_to_switches> call
MDI_COMMAND = O<b02-go_to_wco> call
MDI_COMMAND = G10 L20 P0 X0 # zero x axis
MDI_COMMAND = G10 L20 P0 Y0 # zero y axis
MDI_COMMAND = G10 L20 P0 Z0 # zero z axis
and the code for the buttons ended up looking like this...
# Buttons to zero the axis of the machine.
addf AND-zero-x servo-thread
addf AND-zero-y servo-thread
addf AND-zero-z servo-thread
net zero-button <= input.0.btn-base3 => AND-zero-x.in0 => AND-zero-y.in0 => AND-zero-z.in0
net x-btn <= AND-zero-x.in1 <= input.0.btn-trigger
net y-btn <= AND-zero-y.in1 <= input.0.btn-thumb
net z-btn <= AND-zero-z.in1 <= input.0.btn-base
net zero-x <= AND-zero-x.out => halui.mdi-command-02
net zero-y <= AND-zero-y.out => halui.mdi-command-03
net zero-z <= AND-zero-z.out => halui.mdi-command-04
I'll post the files for anyone who is interested.
Alex
  • NWE
  • NWE's Avatar
17 Dec 2025 23:46 - 18 Dec 2025 04:28
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
Another mystery solved: My 7i54 pwm output to the proportional valve was extremely erratic, like all over its output range. I was ready to blame RFI/EMI interference problems, except only that channel was affected, everything else is very stable. I finally traced it to the snubber circuit on the solenoid coil. I removed that, then it worked fine. Now I have the ram jogging up and down open loop. It appears this rc snubber was messing with the current regulation. Attached a picture of it. It was sandwiched between the connector on the solenoid coil and the Hirschman plug. With that installed, its LED indicator flickered like a candle flame in a breeze whenever pwm output was live. The Ursviken schematics indicate the circuit contains a flyback diode, but I could not find any, neither does it seem to show up when I reverse the h-bridge. The snubber is unnecessary in this instance, I am powering it with an h-bridge designed for DC servo motors. A DC servo motor would not have this additional snubber anyway.
My suspicion has been confirmed: The 2 servo valves set the speed and direction of each ram cylinder. The proportional relief valve sets the tonnage. 0% pwm = no pressure, 100% pwm = max pressure.
I will edit my first post with this info. Once I have a complete working config, that will also be attached to the first post.
17 Dec 2025 22:11
Replied by tommylight on topic MVO to RO
MVO to RO
Category: Gmoccapy
What inaccuracies? In the documentation?
  • abs32
  • abs32
17 Dec 2025 21:54
How to fix "Queue is not empty after probing"
I conducted a large series of experiments with different sensor settings and different ini + hal settings.
First, I achieved smooth operation of the sensor (of my own design) in version 2.8.4. The Chinese sensor could perform 40,000-50,000 continuous measurements (with 38.5 disabled). My sensor completed the entire task, more than 500,000.
That is, it has been established that the quality of the sensor directly affects the appearance of the error “Probe tripped during non-probe move”.
And with the same settings in version 2.9.7, the error “Queue is not empty after probing” recurs. That is, the appearance of the error does not depend on the sensor. The question remained: does this error appear during the working stroke 38.2-38.3 and the reverse?
I disabled the “until open” movement option, as in version 2.8.4, and the error “Queue is not empty after probing” did not appear. Previously, it was not possible to obtain more than 25,000 measurements. The experiment was interrupted at 40,000. Consequently, the error “Queue is not empty after probing” occurs when executing g38.5, during execution. After g38.3, I have a G1 up command.
To disable the possibility of 38.4-38.5 on the defunct Russian forum (к сожалению, я не помню имени автора решения, но честь ему и хвала), such a modification of hal was proposed and tested by me over hundreds of hours of work and hundreds of thousands of measurements -
	#датчик probe
	net probe-in        <= parport.0.pin-13-in-not
	#net probe-in => motion.probe-input (это в случае работы с G38.5)
		#здесь пытаемся убрать ошибку "probe tripped during non-probe mode"
			#https://www.cnc-club.ru/forum/viewtopic.php?f=15&t=31612
			# Загружаем компонент select8
				loadrt select8 count=1
				addf select8.0 servo-thread
		    ## Сигнал от датчика подаем на вход разрешения select8
				net probe-in select8.0.enable
		    ## Номер режима ведем на вход выбора
				net motion-mode motion.motion-type select8.0.sel
		    ## Выход 5 select8 - ко входу для датчика
				net probesel select8.0.out5 motion.probe-input
  • Hakan
  • Hakan
17 Dec 2025 21:08
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
Yes, I thought you wanted to use it in linuxcnc. That's how.
I'll tell you about dc synchronization tomorrow. It's a bit more writing and more code.
  • Todd Zuercher
  • Todd Zuercher's Avatar
17 Dec 2025 20:55
Replied by Todd Zuercher on topic USB pendant button to zero axis
I don't think you want to use the Mux4 component. It is for setting an output to one of 4 numeric values. I think you would want to use multiple And2 components. Also you have the the Halui MDI Hal pin names wrong. To call the first Halui MDI command in your INI file's list the Hal pin name should be "halui.mdi-command-00" and the 2nd would be "halui.mdi-command-01"...
To do it you'd need to put the following lines in your hal file.  Assuming your button output pin names are "input.0.btn" for the zero button, "input.x.btn" for the X button, "input.y.btn" for the Y button, and "input.z.btn" for the Z button.  And since your INI file already has 6 Halui MDI commands listed, adding 3 more to zero each axis would be.
loadrt  and2  counts=3
addf  and2.0  servothread
addf  and2.1  servothread
addf  and2.2  servothread
net zero-btn  <= input.0.btn  =>  and2.0.in0  =>  and2.1.in0  =>  and2.2.in0
net x-btn  <=  input.x.btn  =>  and2.0.in1
net y-btn  <=   input.y.btn  =>  and2.1.in1
net z-btn  <=  input.z.btn  =>  and2.2.in1
net zero-x  <=  and2.0.out  =>  halui.mdi-command-06
net zero-y  <=  and2.1.out  =>  halui.mdi-command-07
net zero-z  <=  and2.2.out  =>  halui.mdi-command-08
That said, if you are wanting to use a button input that is already used elsewhere in your hal file that is ok.  Simply either use that hal signal name to connect the appropriate and2.N.in1 to it, or add the and2.N.in1 to the existing net line.
  • vibram
  • vibram
17 Dec 2025 20:31 - 17 Dec 2025 20:32
Category: EtherCAT
It's already working in free run mode, I can see my encoder value in twincat such as in your 3rd video :)
ethercat-conf.xml
You mean the linuxcnc file?
  • Cena
  • Cena
17 Dec 2025 20:23
Remora 1.1.0 + BTT Octopus – jog overshoot and joint following error
Are you using a MOSFET to heat the wire from the SKR? If so, I suggest reducing the PWM duty cycle and seeing what happens. First of all, try connecting the resistance wire directly to the power supply — reminder: this might help — and check whether the “Bad SPI Payload” messages still occur. You may also want to consider powering the resistance wire from a completely separate power source.
  • gravedigger
  • gravedigger
17 Dec 2025 19:48
MVO to RO
Category: Gmoccapy
I was very close to replacing the Linux CNC with a different system.
The small inaccuracies make it very difficult for a newcomer.
  • gravedigger
  • gravedigger
17 Dec 2025 19:45 - 17 Dec 2025 19:46
MVO to RO was created by gravedigger
MVO to RO
Category: Gmoccapy
I've spent several hours trying to get rapid override working. I happened to read about the change in the designation from MVO to RO. The Mesa Config program doesn't recognize this yet.
Then I noticed that the manual has the wrong name.
I have now entered the following manually and it finally seems to be working.
# ---max Geschwindigkeit Neufestsetzungs-Signale an Mesa Encoder - mpg (rapid override signals to mesa encoder - mpg)---
net ro-count     <=  [HMOT](CARD0).7i73.0.0.enc3.count
# verbinde max Geschwindigkeit Neufestetzung Inkrement - MPG (connect rapid override increments - MPG)
    setp halui.rapid-override.direct-value false
    setp halui.rapid-override.scale 0.01
    setp halui.rapid-override.count-enable true
net ro-count            =>  halui.rapid-override.counts
  • nanowhat
  • nanowhat
17 Dec 2025 18:44
Replied by nanowhat on topic Unsupported access to an object
Category: EtherCAT
That did it. I didn't specify a subindex, since the drive manual said there isn't one for 0x607C. However, at least in this case, ethercat download doesn't work without it.
'ethercat download -p2 -t int32 0x607C 0 35951' works as expected.
Displaying 5446 - 5460 out of 16967 results.
Time to create page: 0.342 seconds
