  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 12:09
Replied by jaro_p on topic User name rpi-first-boot-wizard
Category: Installing LinuxCNC
Ok Thank you
01 Dec 2025 12:07
Replied by tommylight on topic User name rpi-first-boot-wizard
Normally this is what is needed to read Mesa boards:
mesaflash --device 5i25 --readhmid
but for SPI i would guess
mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid
should work, and it should be safe to try.
If you do have more questions about Mesa boards, use the "driver boards" section of the forum.
  • unknown
  • unknown
01 Dec 2025 12:07
Replied by unknown on topic User name rpi-first-boot-wizard
After looking at the arm64 Trixie repo it appears there are no packages available for mesaflash.
One option would to be build from source.
Or to manually download the bookworm version and install that.
As it is almost 12:00 am I fear I may not be able to respond in a timely manner.
  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 12:01
With Imager version 1.9 it's ok.
Can I also ask what is the replacement for mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --fallback --write.
I found:
halrun
halcmd: loadrt hostmot2
halcmd: loadrt hm2_rpspi
for reading (readhmid).
Or should I ask in a new forum?
  • timo
  • timo
01 Dec 2025 11:53
Replied by timo on topic Probleme beim Bohrfräsen
Category: Fusion 360
Ich verstehe nicht. Wenn der Nullpunkt bei beiden Setups auf der selben Position ist, dann "müsste aber" :-) alles normal funktionieren. Wenn der Nullpunkt für G54 für beide setups unterschiedlich ist (meine Beispielbilder oben) dann wäre es ja richtig, wenn die Maschine falsch fährt.
Ist hier bei dem "operations" tab was verstellt?
  • abs32
  • abs32
01 Dec 2025 11:49
Replied by abs32 on topic Issue with G38.5
Issue with G38.5
Verified - adding the code M66 P0 L0 around all G38 did not eliminate the error. 2.9.7
  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 11:40
So after booting without a password it is also not possible to change anything. But I will try an older version of Imager. Otherwise it offers an update to the new version quite aggressively.
  • unknown
  • unknown
01 Dec 2025 11:25
As I said it can also be set via the first book wizard, but I'm at a loss as why RPi image doesn't allow you to set the customisations, all the while I have been building the various version that has never happened, I had to download the latest version on my Debian Dev machine.
  • unknown
  • unknown
01 Dec 2025 11:21
Replied by unknown on topic Is the wiki down?
Is the wiki down?
http is fine
https does not appear to work
Well from my location on an island somewhere near the Indian Ocean/South Pacific Ocean.
  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 11:15
Thanks for the answer, but that is not possible. Option Customisation is greyed out and inactive in RPi Imager version 2.0. ISO image was :image_2025-11-10-raspios-lcnc-2.9.7-6-trixie-arm64.zip
  • unknown
  • unknown
01 Dec 2025 10:44
Replied by unknown on topic The Current Bread & Butter Setup?
Ah I see, I was some what interrupted by The Hound whilst reading and responding, my apologies sir.
  • unknown
  • unknown
01 Dec 2025 10:42
As per instructions you either set the password or username prior to writing the imagery via RPi-imager or you set the user name and password via the first boot wizard, exactly the same process as you would go through with a stock raspios image.
The change in the way the image was built was to make it easier for a user to setup thier wifi and locale, and to allow the user to select a username and password to their liking.
  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 10:38
User name rpi-first-boot-wizard was created by jaro_p
After a few years I pulled out my RPi4 and Mesa 7c81 from the drawer again. I tried to install raspi os 2.9.7... And that's it. After a while of inactivity my screen locked and I was done. I searched the "entire" web, but I couldn't find the password for that awesome username anywhere.
  • gooose
  • gooose
01 Dec 2025 10:20
Ich brauche eure Hilfe beim Tausch meines Boards
Category: Deutsch
Entschuldige bitte das ich gefragt habe.
Nicht jeder ist ein Genius wie du...
  • vibram
  • vibram
01 Dec 2025 08:49
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
Hello,
Not sure to understand correctly:
You can have both TIM2 and TIM5 32bits encoders running in the same time right?
But it has to be on a custom board
Displaying 6061 - 6075 out of 16956 results.
Time to create page: 0.335 seconds
