  • andypugh
  • andypugh's Avatar
28 Nov 2025 21:16
Used Laptops tested with LinuxCNC and Mesa Ethernet boards
FwIw I have succesfully used a Macbook Air (with Linux installed) and a thunderbolt-to-ethernet adaptor to control a Mesa 7i96.
28 Nov 2025 21:04
Replied by tommylight on topic Upgrade advice for ooold system
Category: Installing LinuxCNC
It is Linux so do not worry to much about security, and if you are worried yank out the internet cable.
Normally, if you do not click on some malware links in the browser or open e-mails containing malware, there is nothing to worry about, there are plenty of servers on public IP's that were never upgraded still working running Linux happily.
In short, if the machine works properly = never upgrade.
Long version:
I am fully aware of the psychosis caused by Microshaft spending billions on marketing to prove Linux is not secure, and they miserably failed as all Microsoft servers run Linux.
Windows will be someone else's property in 2 minutes flat if left on public IP.
The extremely bad thing is, that sentiment keeps getting perpetuated by lazy youtubers that play experts on youtube yapping about security being the same on both, it is NOT the same in any way, shape or form, and the worst thing is they talk about browser security that is close enough security vise but still not the same, while utterly ignoring the operating system security that is non existent on windows and extremely good on Linux.
  • andypugh
  • andypugh's Avatar
28 Nov 2025 21:02
Replied by andypugh on topic Schaublin 125-CNC retrofit.
Category: Turning
You probably don't need ladder logic. I would think that it is do-able with HAL components. Maybe latch-on the spindle-enable when spindle commanded-speed is zero until measured spindle-speed is very, very near zero.
Maybe linuxcnc.org/docs/stable/html/man/man9/flipflop.9.html
I would need to experiment, but I am thinking setting "in" permanently to "true", clck being triggered by spindle-on ans reset triggered by spindle-off AND speed ~= 0.
(Spindle-off would be inverted spindle-on, and stopped status would use wcomp. )
  • abs32
  • abs32
28 Nov 2025 20:54
Probe tripped during non-probe move deadlock
This error appeared and continues to appear in versions 2.8.4 and 2.9.4 when executing G38.5. By tricking hal for version 2.8.4, the problem is partially solved.
It is impossible to verify that the problem has been solved in version 2.9.7 because a new error, “Queue is not empty after probing,” appears much more frequently in it (and in 2.9.4 as well) -
forum.linuxcnc.org/38-general-linuxcnc-q...bing?start=10#338958
github.com/LinuxCNC/linuxcnc/issues/3650
  • Dudelbert
  • Dudelbert
28 Nov 2025 20:51
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
I already ordered a tube of Klüber LDS18, according to one of Rotary’s videos, this is the right stuff for the spindle.
It’s really unbelievably helpful to have resources from someone restoring the exact same lathe.
  • andypugh
  • andypugh's Avatar
28 Nov 2025 20:46
Replied by andypugh on topic HURCO KMB-1 Control Update
Category: Milling Machines
You don't _need_ ladder for spindle orient, but you will need, at the least, some HAL logic and a second PID controller for position mode.
  • Lpkkk
  • Lpkkk
28 Nov 2025 20:42 - 29 Nov 2025 01:00
Replied by Lpkkk on topic Huanyang FC01 modbus
Mb2hal version didn't work great. I'm working on python hal component currently.
Meanwhile I made python app to drive FC01 inverter.
Available : github.com/dangervoid12/VFD-FC01-Monitor/tree/main
  • andypugh
  • andypugh's Avatar
28 Nov 2025 20:42
Replied by andypugh on topic Probe tripped during non-probe move deadlock
Do you still get this error without the flipflops and filters etc? Noe of this HAL complexity should be needed.
If there is a problem (possibly with repeated G38.2 commands) than please raise an issue on the Github so that it can be tracked. Not everyone reads every forum post (I don't) and so the forum is not a good place to report issues.
  • andypugh
  • andypugh's Avatar
28 Nov 2025 20:33
Replied by andypugh on topic Is something up with 2.9.7 (joint errors)
That's a relief, I didn't want to think that I had introduced yet another error when fixing something else.
  • andypugh
  • andypugh's Avatar
28 Nov 2025 20:23
Replied by andypugh on topic MTConnect support actively developed?
If you are writing an interpreter to plug into LinuxCNC than it should probably be written in the same language as the existing one. That isn't to say that Python couldn't be made to work (I don't actually know) but there would be more to copy and adapt in C++
  • Dudelbert
  • Dudelbert
28 Nov 2025 19:52
Category: Turning
... Starting over I would probably have just injected a little fresh grease. It is easy enough.
OK, so I can just do that and tell myself I’m not being lazy — it’s science. We’ll make an A/B test and see how the machines behave over the years.
Yes, that sounds like it could actually be a thing.
  • RotarySMP
  • RotarySMP's Avatar
28 Nov 2025 19:20
Category: Turning
It is not difficult to pull the spindle. I just welded up a U frame to pull against and used all thread to draw it out.
Schaublin recommended disolving Kluber in some solvent like trichchlorethane which we cant get. I don't yet know whether I screwed up good bearings or saved them. Time will tell. Starting over I would probably have just injected a little fresh grease. It is easy enough.
If the dovetail fits, you could also just drill and tap the height adjuster holes on the other side.You can never have too many tool holders :)
I wonder why the replaced the X servo, but left the Z one?
  • mark-v-d
  • mark-v-d
28 Nov 2025 18:43
Replied by mark-v-d on topic Incremental Axes U, V, W support?
I've added U and W to the G7x cycles, but those letters cannot be used outside the subroutine interpreted by those G7x codes.
  • Gogonfa
  • Gogonfa
28 Nov 2025 18:08
Troubleshooting ASDA-B3 Following Errors (EtherCAT)
Category: EtherCAT
Thanks ... that confirms what I suspected. I really hope the auto-tuning on the Delta B3 drives works better once they have the proper inertia of the machine. Running them completely without load probably doesn’t give the controller anything meaningful to work with.
I’ll revisit the tuning once everything is mounted mechanically. Fingers crossed that the B3’s auto-tune behaves more reasonably under real conditions.
  • Dudelbert
  • Dudelbert
28 Nov 2025 18:03
Category: Turning
The question about the grease in my head is that the spindle seems properly lubricated right now — no strange feeling, no signs of anything bad. So if I pull the spindle and put it back after installing the replacement belt, I’m hoping I won’t make it worse than it is. When it comes to regreasing these high-precision bearings, I’m hesitant — I’d rather learn on less costly spindles first.
Regarding Mach: the seller provided a copy of his Mach3 folder. I didn’t know this before, but you can just put that folder on the PC and it works—no installation, no configuration, no compiling anything custom.
Displaying 6346 - 6360 out of 16733 results.
Time to create page: 0.490 seconds
