  • Z3n
  • Z3n
27 Nov 2025 06:03
Red Init & Done Lights on 7i92M was created by Z3n
Category: Driver Boards
I'm midway through converting a Brother TC215 to LinuxCNC control (I started a thread here: forum.linuxcnc.org/12-milling/57928-conv...er-tc215-to-linuxcnc ), and I've been learning a lot / things have been going well, but I've gotten to the point where I wanted to test the MESA cards in the mill and I've discovered that when I power up the MESA 7I92M board, the Init and Done lights stay red. It won't respond to ping, and doesn't show a link light via ethernet on either side of the cable.
I saw a post from PCW ( forum.linuxcnc.org/27-driver-boards/4431...-7i96-flashing-error ) that says the Init and Done lights staying illuminated indicate corrupted flash memory. If this is the case, I'm assuming the best option is to get in touch with MESA and see about having them reflash it? Any guidance welcome.
Also, I've got a 7I76 and a 7I77D in the mill, and now I'm concerned that if there's an issue with the 7I92M that there's a problem with those boards as well. If I power those with 5v via the appropriate terminals / jumper settings, will I be able to verify if they work via looking at the lights on the boards?
Thanks for any help / guidance, it's really amazing to have this forum as a resource!
  • Dudelbert
  • Dudelbert
27 Nov 2025 05:44
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Yeah, you’re probably right, and I’m leaning toward LinuxCNC anyway.
  • smc.collins
  • smc.collins
27 Nov 2025 05:08
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
Category: Turning
Personally, I'd just buy a servo and rip oit all the crap on the spindle, you can get a 5kw spindle and drive on Alibaba for $400 shipped or less. That'll give you what you're after for a lot less hassle. Pull out the pulley system and all and just direct drive. Get a 5000rpm servo that should give you way more cut powe than you have.
  • nanowhat
  • nanowhat
27 Nov 2025 02:27
Ethercat drives not responding, mesa error finishing read
Category: EtherCAT
The PLL fault doesn't freeze or kill the process: one drive will stop responding to cyclic position commands. The only reset function I've built into my code so far toggles cia402.x.enable and cia402.x.fault-reset, and that doesn't seem to be enough to reestablish communication with the drive.
  • drdyna
  • drdyna
27 Nov 2025 01:56
Incremental Axes U, V, W support? was created by drdyna
Hi
I'd like to use LinuxCNC to simulate some lathe g-code before I run it on my actual machine.
I have linuxCNC installed, and have the gmoccapy lathe simulations installed, but when I try to run my g-code, I get an error about "invalid character U". My physical machine has incremental axes U and W that correspond to X and Z. U and W are incremental moves, and X and Z are absolute moves. So if you're at X1.0 and you move U3.0, you'd end up at absolute X4.0, or if you're at X1.0 and move U-3.0 you'd end up at X-2.0
Does linuxCNC support incremental axes like U and W? Do I need to set them up somehow in the simulation machine's HAL file?
  • qiwating
  • qiwating
27 Nov 2025 01:45
Replied by qiwating on topic Fanuc encoders
Fanuc encoders
for Fanuc Encoders you can check here panasonicservomotor.com/fanuc-encoder. include code Fanuc code list
  • jmelson
  • jmelson
27 Nov 2025 00:47 - 27 Nov 2025 00:48
Replied by jmelson on topic LinuxCNC Hardware Survey
A google search for servo-to-go comes up pointing to alvarestech.com, that brings up the original servo-to-go main page from 20 years ago. I was real surprised to see that pop up! But, they have been out of the business since about that time. I can imagine there might be some hermit still running an STG card somewhere, but that's a stretch.  (I sold mine 20 years ago!)
Jon
  • andypugh
  • andypugh's Avatar
27 Nov 2025 00:30
Unexpected EtherCAT was created by andypugh
Unexpected EtherCAT
I was trying to find out if the Vital Systems Motenc card is still a current product, and it seems that it is (it's been supported by LinuxCNC since 2005)
But on their web site I found that they also have EtherCAT hardware.
www.vitalsystem.com/motion/ethercat/ECS1.php
  • andypugh
  • andypugh's Avatar
26 Nov 2025 22:58
Replied by andypugh on topic LinuxCNC Hardware Survey
Servo2Go seems to still exist, but I don't see anything like the original Servo2Go ISA bus interface card on their web page
I am not sure if servo2go is the same as servotogo.
The servotogo.com address now seems to redirect to an Indonesian lottery site.
  • Hakan
  • Hakan
26 Nov 2025 22:51
Category: EtherCAT
PLL was documented not long ago. Wasn't aware it can stop linuxcnc, that's a bit excessive.
github.com/linuxcnc-ethercat/linuxcnc-et...istributed-clocks.md
  • RotarySMP
  • RotarySMP's Avatar
26 Nov 2025 22:44 - 27 Nov 2025 17:03
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
This hopefully explains it better...
So per the manual, I have the following control commands: Pin 7 / Pin 8 (Analog in) connected to a Mesa analog output, and jumpered for 0-10V. This is the main control. The VFD doesn't get on/ off commands, it gets speed commands. Pin 9 (Power for a control poti) Unused. Pin 62 (Analog out) Unused Pin 20 (power out for digital inputs) Unused. Pin 28. (Activate VFD) Controlled by Mesa digital output.Pin E4 (Change direction) Controlled by a Mesa digital output.
Pin E3 DC (DC braking) unused.
Pin E2 (Jog at frequency 2) Unused.Pin E1 (Jog at frequency 1) Unused.
Pin 39 (Gnd) Connected. Output Relay
K11 (NO Out) Connected to Mesa inK12 (Common) Connected to Mesa in.
  • jmelson
  • jmelson
26 Nov 2025 22:44
Servo2Go seems to still exist, but I don't see anything like the original Servo2Go ISA bus interface card on their web page.
Jon
  • nanowhat
  • nanowhat
26 Nov 2025 22:40 - 26 Nov 2025 22:43
Category: EtherCAT
Having mostly put the machine together and found ModbusTCP unsuitable, I took another attempt at Ethercat.
  1. I installed LinuxCNC 2.9.4 from the ISO on the nearest available beige box (which has a Realtek ethernet card)
  2. I installed the r8168-dkms driver
  3. I built ethercat from source to exclude EoE as follows:
    1. git clone gitlab.com/etherlab.org/ethercat.git ethercat-master
    2. cd ethercat-master/
    3. git checkout stable-1.6
    4. ./bootstrap (I didn't have autoconf or libtool installed: they are necessary)
    5. ./configure --sysconfdir=/etc/ --disable-8139too --enable-userlib --enable-generic --disable-eoe
    6. make all modules
    7. sudo su
    8. make modules_install install
    9. depmod
    10. exit
    11. sudo nano /etc/ethercat.conf
    12. sudo systemctl enable ethercat.service
    13. sudo systemctl start ethercat.service
    14. sudo systemctl status ethercat.service
    15. sudo chmod 666 /dev/EtherCAT0
    16. sudo nano /etc/udev/rules.d/99-ethercat.rules
    17. sudo udevadm control --reload-rules
  4. I installed linuxcnc-ethercat from the repository
  5. I installed the CIA402 module:
    1. git clone github.com/dbraun1981/hal-cia402
    2. sudo halcompile --install cia402.comp
And it works very nicely most of the time. See attached ethercat xml file.
I see some "PLL error" failures sometimes, which can only be "solved" by restarting the control process. I've tried adjusting refClockSyncCycles and sync0Shift in accordance with some other threads, but I don't understand what those do or what they should actually be.
  • Z3n
  • Z3n
26 Nov 2025 21:44 - 26 Nov 2025 21:50
Replied by Z3n on topic Converting a Brother TC215 to LinuxCNC
Category: Milling Machines
The AC servo drives won't work because the wiring currently is only halfway complete, and I want to have the system documented in the intended state before I power anything.
There's no config loaded on to the Mesa cards yet (or a config between the Mesa cards and LinuxCNC), so after talking to my friend who kicked the project off, I've decided to take a slightly different approach, which is I'm going to set up and configure the EStop switch for LinuxCNC first, so I can verify that each of my components work. I will: Document the wiring, wire the switch, confirm the connections, verify the Mesa card functions, establish the appropriate configuration in LinuxCNC for the EStop switch, and use Halscan to verify it works. Once I've confirmed I can get a functional switch in LinuxCNC, I can start taking on something the servo wiring problems.
That way I'll know the base of the software / hardware stack works well, and I can proceed confidently with wiring the servo drives. It also hopefully gives me a chance to do more research on if my wiring setup will work / get some feedback on my proposed plan of Analog +10v control with the encoder wiring as documented above. Once my documentation is a little more cleaned up, I'll share that too.
Edit: Oh, and I appreciate the advice to focus on what's in use, but I like to see things in the context they exist in, it's helpful for me to conceptualize the whole system - I've already roughly documented all of the existing connections and what they're used for, so it's mostly about trying to figure out how the systems fit together and deciding on the pattern that I want to wire things in to make it so it's easy for me to understand it if I have to work on it in the future.
  • andypugh
  • andypugh's Avatar
26 Nov 2025 21:32
Mesa, Pico, Parallel port and EtherCAT are safe.
It's the other stuff I am really interested in. Can we safely sunset those drivers?
Displaying 6421 - 6435 out of 16728 results.
Time to create page: 0.402 seconds
