  • papagno-source
  • papagno-source
22 Nov 2025 16:53
Replied by papagno-source on topic CNC AXIS IN PARKING MODE
Good morning everyone and thanks for the replies.
It's clearly a machine axis, the Z axis.
The machine is old, and in some operations, it's more convenient to be able to drill manually. We're talking about a machine that works with enormous cast iron bases, 10 meters long, so it must have maximum flexibility.
Rown, basically, using your component, I would have:
net Zenable joint.2.amp-enable-out pid.2.enable isfreewheeling
net Zpos-cmd joint.2.motor-pos-cmd pid.2.command
net Zpos-fb joint.2.motor-pos-fb pid.2.feedback
But I don't understand where to connect: pos_fb_out
  • PCW
  • PCW's Avatar
22 Nov 2025 16:46
Replied by PCW on topic CNC AXIS IN PARKING MODE
You don't need a new component for connecting commanded to feedback position
when the joint is disengaged, and the mux component can already do this function.
That is not the tricky part anyway, the tricky part is returning to LinuxCNC control after
the hand motions  were completed.
Ideally there would be a per joint enable signal (that forced LinuxCNCs internal commanded
position to track the feedback position when disabled) but lacking that, a simple hal profile
generator (using limit3 for example) could be enabled to move to the original position
before control is handed back to LinuxCNC.
  • PCW
  • PCW's Avatar
22 Nov 2025 16:05
Replied by PCW on topic 7i76eu steppers don't move
Category: Driver Boards
Are the drives locked?
Note that on many step drives. the "enable" input is actually a disable input
and disables the drive when powered.
For checking outputs without a oscilloscope, you can measure the DIR output and
see if it changes when jogging in different directions
A following error may indicate a setup issue and needs to be resolved.
  • BoMadsen
  • BoMadsen
22 Nov 2025 15:57
7i76eu steppers don't move was created by BoMadsen
I have a DMC2 Mini that I am trying to convert from the Chinese Mach3 board that it came with, to a 7i76eu controlled by linuxcnc.
But I am stuck at getting the stepper motors to move. The DMC2 comes with three Nema23 57-76 motors with built-in controllers, similar to this one:
www.aliexpress.com/item/1005006172891348.html
I have wired the motors like this:
EN-  -> TB2 pin 1 GND
EN+ -> TB2 pin 6 +5VP
DR-  -> TB2 pin 4 DIR1-
DR+ -> TB2 pin 5 DIR1+
PU-  -> TB2 pin 2 STEP0-
PU+ -> TB2 pin 3 STEP0+
But nothing happens when I try to jog the axis. The DRO in the UI change, but the steppers are totally silent. After a while jogging around, I usually get a "Join 0 following error".
I can measure +5v on EN, so I believe that the axis is enabled.
I have just installed LinuxCNC from the livecd, and the configuration is made with pncconf.
Any ideas on what could be wrong, or what I can do to debug it? I don't have an oscilloscope, so I have a hard time actually confirming that the MESA card sends out pulses.
Thank you in advance!
  • PCW
  • PCW's Avatar
22 Nov 2025 15:46
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
The basic issue is that the current firmware is just GPIO (no Step/Dir hardware etc)
There could be a couple reasons for this:
1. The wrong firmware is installed,
2. The card had corrupted firmware so has loaded the fallback firmware (which is just GPIO)
Did the card vendor supply a firmware file?, it does not look like any standard 7I92 firmware to me
If they did supply firmware, I would try re-writing it with:
mesaflash --device 7i92 --addr 10.10.10.10 --write  vendor_supplied_firmware_file_name.bit --reload
22 Nov 2025 14:21
Replied by tommylight on topic StepperOnline A6 Servo
Category: EtherCAT
Where should we move the above reply to?
  • bszoke
  • bszoke
22 Nov 2025 13:43
Replied by bszoke on topic StepperOnline A6 Servo
Category: EtherCAT
I made some comments on this in another thread about the PDO configuration, you are correct, internally it does configure the PDO's and sets the PDO assignment register ONLY if you set configPdos="true".
forum.linuxcnc.org/ethercat/56205-help-w...ives?start=20#338949
  • aDm1N
  • aDm1N's Avatar
22 Nov 2025 13:38 - 22 Nov 2025 20:55
EtherCAT + CiA402 Servo: OP state reached, but axis won’t move (only Following E
Very short explanation of how PV ↔ CSP switching works:
Only one CiA-402 mode is active at any time.
In spindle mode (PV):
- The drive receives only target-velocity.
- HAL forces: pos-cmd = pos-fb (follow-mode).
- So the axis has no position error while the spindle is turning.
When switching to C-axis mode (CSP):
- HAL switches pos-cmd from “follow-mode” to the motion planner.
- Since pos-cmd == pos-fb at the moment of switching, there is no position jump and no torque spike.
Why this is valid:
- PV mode ignores position commands.
- CSP mode ignores velocity commands.
- Therefore the drive never receives conflicting commands.
- This fully complies with CiA-402 behavior.
Status:
This configuration has been tested electrically only.
The motors run and switch modes as expected, but the mechanical connection to the machine is not installed yet.
  • Aciera
  • Aciera's Avatar
22 Nov 2025 12:50
Replied by Aciera on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
At this juncture you all disgust me.
Like so many times before when you noisily left this forum just to reappear a few days later under a different login.
  • unknown
  • unknown
22 Nov 2025 12:45
Replied by unknown on topic PoKeys57CNC HAL component
Category: HAL
Thank you for giving back to the community, it's refreshing to see rather than those that just take take take.
A Tip O The Hat to you sir
  • unknown
  • unknown
22 Nov 2025 12:43
Replied by unknown on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
I still stand by my removed comment.
And I'm very sorry to say but you admins are weak and spineless to allow this buffoon to carry on the way he does.
It's a shame the CoC doesn't cover giving advice to members that is completely useless, a waste of time and potentially to the point of causing harm.
But no, the main point is not to hurt anyone feelings or to cause offense.
Who is going to have the intensal fortitude and read Langdon's the riot act. I tried in the beginning to guide him in the right direction but he would appear not to care.
You admins need to take action, I'm sick to effing death in having to make his posts an issue in the hope something will be done to rectify his behaviour. Until then I will keep raising this issue, or you can just ban me. I don't care much, Ive lost faith in every single one on the Admins on this site. You aren't doing a single thing to protect other forum members, especially new ones from his nonsense. At this juncture you all disgust me.
  • unknown
  • unknown
22 Nov 2025 12:31
Replied by unknown on topic Chinese Mesa 7I92 from aliexpress NEW
You did not buy a Mesa card. You bought a Chinese clone hoping to save some money then expecting help.
The best thing you can do is read the Linuxcnc documentation.
But any of the quirks with the card itself you are going to have get support from the vendor.
Without knowledge of the schematics no one can say whether it will operate electrically as original Mesa 7i92.
What you have done is bought a rip-off and now expecting those that are loyal to Mesa Electronics to dig you out of hole.
And to be perfectly honest there are plenty of threads regarding configuration, plenty of resources on YouTube and plenty of advice in the docs.
  • unknown
  • unknown
22 Nov 2025 12:18
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Until the issue with the 5i25 is sorted no amount of reinstalling Linuxcnc is going to fix the issue.
It's quite apparent that the config was working before. What is stopping it now from working is the error with 5i25.
It's akin to trying to get a car going by replacing the engine when the ROM in the ecu is bad.
  • Muzzer
  • Muzzer
22 Nov 2025 11:58
Category: Gmoccapy
Many thanks for the helpful suggestions! Notwithstanding the ever present Domestic Manager and her task list, I will have a go at those suggestions.
  • Cleaning and reseating the connectors sounds like a good plan. As you say, software doesn't simply evolve of its own accord. My mobo has only one ISA slot.
  • I have a spare SSD, so will do the install on that, leaving the existing system untouched.
  • "Really all you need to port across is your ~/linuxcnc folder" - I will look into this. Presumably that folder contains config data rather than executables etc.
  • If I'm still struggling with the 5i25 bit, I'll post a more focused query and perhaps PCW will be able to point me in the right direction.
Thanks again.
  • Sekai
  • Sekai
22 Nov 2025 11:19 - 22 Nov 2025 11:29
Hi.I bought a mesa card from aliexpress to power my lathe.The board works with 10.10.10.10 it pings and output that gives me with command:sudo mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
configuration Name: HOSTMOT2
  BoardName : MESA7I92
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 2
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       None
14                      1   IOPort       None
 2                      2   IOPort       None
15                      3   IOPort       None
 3                      4   IOPort       None
16                      5   IOPort       None
 4                      6   IOPort       None
17                      7   IOPort       None
 5                      8   IOPort       None
 6                      9   IOPort       None
 7                     10   IOPort       None
 8                     11   IOPort       None
 9                     12   IOPort       None
10                     13   IOPort       None
11                     14   IOPort       None
12                     15   IOPort       None
13                     16   IOPort       None
IO Connections for P1
 1                     17   IOPort       None
14                     18   IOPort       None
 2                     19   IOPort       None
15                     20   IOPort       None
 3                     21   IOPort       None
16                     22   IOPort       None
 4                     23   IOPort       None
17                     24   IOPort       None
 5                     25   IOPort       None
 6                     26   IOPort       None
 7                     27   IOPort       None
 8                     28   IOPort       None
 9                     29   IOPort       None
10                     30   IOPort       None
11                     31   IOPort       None
12                     32   IOPort       None
13                     33   IOPort       None
The problem is i dont know how configure linuxcnc. I have the doc from the seller uploadnow.io/f/9v0gkpb
This is my first time with mesa card.
Displaying 6646 - 6660 out of 16715 results.
Time to create page: 0.327 seconds
