  • andypugh
  • andypugh's Avatar
19 Nov 2025 10:29
Replied by andypugh on topic ISEL CNC/IMC4 programming language
I think you might be misunderstanding what LinuxCNC does. If the machine responds to low-level commands through the serial port then I think that the CNC controller is on the machine side of the serial port. LinuxCNC is a CNC controller, so that is where half of LinuxCNC would go too.
  • Fixenty
  • Fixenty
19 Nov 2025 10:22
Touch resizing of gcode preview was created by Fixenty
Category: Gmoccapy
Hi, I have an issue in Gmoccapy.When I try to click on “Clear Toolpath” or “Jog Speed –”, the cursor automatically grabs the edge of the preview window. Instead of clicking the button, it starts resizing the preview window.It feels like the preview window border has priority over the buttons, so I can’t reliably click them. Has anyone experienced this, or knows how to fix it?
  • vibram
  • vibram
19 Nov 2025 08:59
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
@Hakan certainly a stupid question but I did not understood why you did not managed to get the encoder work on the ethercat devboard here?
I wanted to test the encoder on the devboard before doing a custom board
Thank you for the clarification
  • unknown
  • unknown
19 Nov 2025 06:26
Replied by unknown on topic program exceeds machine maximum
I have my MAX-Z-LIMIT set at 20mm & MIN-Z-LIMIT set at -255
Usually when I run a program, as I set home and stuff like that manually I'd home to a mark on the column, then bring the tool down to a height of 6.35mm above the stock, set by a pin, touch off at that height. Which sets the Z zero on the stock.
  • unknown
  • unknown
19 Nov 2025 06:16
LinuxCNC 2.9.3 .xz image for RPi 5 is not available in the ISO directory
Unfortunately the 2.9.3 image you refer to has been removed from the server.
There is a new image that has 2.9.7 and is much more raspios like.
The thread is here which has one image suitable for both the 4 & 5:
forum.linuxcnc.org/9-installing-linuxcnc...trixie-images#338181
As this is an experimental image I would be very interested in feed back.
If you need to install probe basic there are 2 extra packages to install after following the Probe Basic install instructions:
forum.linuxcnc.org/38-general-linuxcnc-q...-launch-issue#338654
If you are not installing Probe Basic there is no need for these packages.
  • farmer_mike
  • farmer_mike
19 Nov 2025 05:06 - 19 Nov 2025 05:10
program exceeds machine maximum was created by farmer_mike
Hi, this is my first post outside of the Ethercat section.
I'm getting beat up by a z axis travel limitation, although I did somehow get the program to run once. My understanding of the problem is that my g54 is in the wrong spot.
Fusion 360 says the max Z height is 0.6", so I moved my Z axis almost all the way up, then set the G54 Z position to 0.6". I did have the program run once, but then I stopped the program. When I go to re run the program I keep getting the same z axis error.
I've attached some phone pictures.
  • gravedigger
  • gravedigger
19 Nov 2025 04:55
Replied by gravedigger on topic 7i73 MPG Input MaxVelOverride
Category: PnCConf Wizard
And one more question. Can I use the same encoder for both feed and MaxVel? I don't really like the two-button operation for feed control
  • gravedigger
  • gravedigger
19 Nov 2025 04:52
7i73 MPG Input MaxVelOverride was created by gravedigger
My maxveloverride isn't working. It's on enc3, and spindle override and feedrate override work there, but not maxveloverride. Is this due to gmoccapy? The entries in the HAL file look the same as for spindle and feedrate.
  • Hakan
  • Hakan
19 Nov 2025 04:51
problems with Y-Axis, elliptic deviations after several changes -Probe Basic V.5
Category: QtPyVCP
Ok 500 is fine. I knew it is 1000 for 1 ms but not how it scaled.
I was looking for a reason for the following error.
Since the feedback comes from the step generator and not the actual machine,
it seems to me the step generator is to blame.
You get following error even when running in air, right?
Basically linuxcnc, or perhaps the step generator, generates the wrong tool path in Y.
Unfottunately I don't know how to fix it.
  • 4ashishkr
  • 4ashishkr
19 Nov 2025 04:40 - 19 Nov 2025 04:40
This image was previously available, but when I tried to reinstall it, I couldn't find the specific "
.xz" file anywhere in the ISO index.
  • tcbmetalworks
  • tcbmetalworks
19 Nov 2025 03:48
Replied by tcbmetalworks on topic Automatic band saw marvel v10a
Category: CNC Machines
Interesting I will give it a shot repairing the hydraulic system before abandoning it.
  • tcbmetalworks
  • tcbmetalworks
19 Nov 2025 03:37
Looking for a freelancer to assist in drawing schematics for cnc plasma table
Category: User Exchange
Here is a link to the thread of me documenting the process of building the table to get to where it is right now. Yes the motors are overkill but they are not really too big of a form factor and the gantry estimated weight is 400-800lbs. I have the machine geared to run 700ipm rapid if I remember correctly. Alot of force required to rapidly change directions at fast cut speeds on a gantry this large. And yes the list is long. Really I need help documenting and planning this project to speed things up. Draw a wiring diagram and point me in the right direction for parts. I want a diagram so its easy to fix for the next guy, and I can make sure then that everything is properly grounded/bonded and resistant to interfearence. The only thing I forgot on that list is a circuit for e stop maybe using a saftey relay and I may add in a lube pump to pump oil into the tracks and rollers.
  • unknown
  • unknown
19 Nov 2025 03:27
I would like to know how to connect GPIO to LinuxCNC’s E-Stop chain.
Category: Basic Configuration
Personally I would have the estop connected via Normally closed switch, and the estop is signaled via opening connection. This way if, for whatever reason, the estop wire is broken or falls off either connection the machine will go into an estop condition.
The way you have your schematic, you'll only know that something is wrong with the estop when you go to use it.
I'd rather a failing estop not let the machine run.
19 Nov 2025 03:10
Depends on what the machine has for an e-stop chain and that is wired, but for small machines that can not do much harm, a simple and single input and a single output are all that is needed:
# --- ESTOP-EXT ---
net estop-ext <= [HMOT](CARD0).7i84.0.2.input-14
net estop-ext => [HMOT](CARD0).7i84.1.1.output-08
That will just loop back the e-stop signal from the button to whatever is connected to the output pin. This works perfectly well on most machines (example is from my 3.5 ton Mazak lathe) as the output is wired to existing e-stop loop on the machine.
That will not allow the machine to come on when the button is pressed and will allow enabling the machine when button is reset.
E-stop latch should be used only when more logic is required by LinuxCNC, and/or more inputs and outputs.
Displaying 6901 - 6915 out of 16702 results.
Time to create page: 0.505 seconds
