  • rodw
  • rodw's Avatar
05 Nov 2025 08:02
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
There is a sheetcam setting to set the file extension. I always output .ngc files but you can set linuxcnc to open tap too
  • Allie
  • Allie
05 Nov 2025 07:58
Replied by Allie on topic Suggest RTAI version for me
Thank you guys the wheezy version base latency was in the 30000 - 40000 ns range on multiple tests, and I think that will be fine for me.
  • rodw
  • rodw's Avatar
05 Nov 2025 07:50
Replied by rodw on topic USB activity causes network error
Category: Plasmac
Thanks Rob. So it will make sense then to force the eth0 irq to the last core?
Yes, be guided by PCW there. Thats what he says but a lot of RT stuff I have read indicates it should be on a seperate core. I have wondered about setting the affinity for eth0 to core 6 and the linuxcnc rtapi thread irq to core 7 (given isolcpus=6,7) The latency test is really irrelevant with mesa hardware and you need to focus on network latency.
  • rodw
  • rodw's Avatar
05 Nov 2025 07:32
Replied by rodw on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
@auric, Don't be afraid to ask on your own thread. Sometimes thats best so we can follow your journey.
Some of the Intel stuff is a bit dated now as we worked to make ethercat easier for you. The simplest way to get linuxcnc and ethercat right now is to download the 2.94 ISO from Linuxcnc's download page and install it on a PC from a thumb drive
Then follow the steps in this thread to get linuxcnc and ethercat going. This will give you Debian Bookworm and linuxcnc 2.9.4 which is only missing a couple of minor bug fixes in the latest 2.9.7
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
Today, the linuxcnc ethercat hal driver is hosted on the iGh ethercat repository. There are some licensing reasons preventing us to install the ethercat master on our ISO so we do the next best thing and est up the system files so you can install their ethercat master with a single command..
Anyway, back to hal, Linuxcnc's hardware abstraction layer. Linuxcnc is always the motion controller so it has the full power of your PC st its disposal instead of on an emasculated embedded PC like some other CNC systems on Windows use. This requires using the PREMPT_RT real time kernel. Linuxcnc runs a real time servo thread synced to ethercat which fires 1000 times a second. The hal file  (a text file) defines how all of the parts of a CNC machine are connected together. eg where are estops, home and limit switches connected etc.  The Hal file also loads the ethercat hal driver with  an XML file for ethercat to define your ethercat slaves, PIDs. MIDs etc.  The linuxcnc ini file defines the actual physical hardware. eg how many axes, is it metric or imperial, what gui is opened, encoder resolution per rev, max velocitiy and accelleration per axis, the kinematics model etc.
To see what hal can do, go to our documents  linuxcnc.org/docs/stable/html/ and click on the expand man pages button and review the hal components that can be loaded in your hal file. If that's not enough, you can write your own custom components in a C like environment that can be compiled and installed into linuxcnc with halcompile. Once your custom components is installed it is treated as if its part of the linuxcnc core!
Oh and Sitner's original ethercat hal  driver has been taken over by Scott Laird, modernized and extended including automated build processes that publishes any changes in the code to the iGh repository. Since then, the uptake of ethercat has exploded as its no longer necessary to modify and build anything from source.
  • auric
  • auric
05 Nov 2025 06:44
Replied by auric on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
I apologize for posting here; I couldn't find a more suitable topic, and I was afraid to start a new one. I've become interested in EtherCAT, and I think I've even figured it out at some level. I often work with CNC, but I haven't worked with LinuxCNC yet. I've become intrigued by how users connect the hardware and the CNC itself (after all, EtherCAT has already made significant inroads into drives and other areas). A simple search for "LinuxCNC EtherCAT" yields several interesting topics. First, I wanted to understand the HAL: am I correct in assuming it's a set of specific instructions that configure the CNC itself so that a task is sent to another process that handles EtherCAT? Or is it not just settings, but also a process or driver of some sort?
What is most often used to connect the CNC and the servo drives themselves?
I found this page while searching: eci.intel.com/docs/3.3/development/tutor...enable-linuxcnc.html. If I understand correctly, it suggests using the IgH EtherCAT Master Stack and the LinuxCNC EtherCAT Driver. I'm confused, because the IgH EtherCAT Master is an open-source development from etherlab.org. What does Intel have to do with it, and why is it sometimes referred to as the ECI EtherCAT Master Stack? What does the LinuxCNC EtherCAT Driver (github.com/sittner/linuxcnc-ethercat.git) do in the bundle? And what does Intel Edge Control do then?
  • PCW
  • PCW's Avatar
05 Nov 2025 06:19 - 05 Nov 2025 06:22
LinuxCNC + Mesa 7i92TF + Gecko G540. Docs are useless. Help, Please!
Category: PnCConf Wizard
I would just use pncconf to setup a G540 configuration (config page):
And the setup the pins on the P2 tab:
The main thing that's awkward is the mapping of GPIO pins for things like  limit/home switches
and spindle-on, but you can list the GPIO/G540 correspondence with mesaflash:
something like:
mesaflash --device 7I92T --addr 10.10.10.10 --readhmid --dbname1 g540
ChatGPT is just a time sink here
  • SvenRSA
  • SvenRSA
05 Nov 2025 06:17
Replied by SvenRSA on topic proudly presenting a Maho MH700 retrofit ..
Category: CNC Machines
Hi there. Any chance you still have your ini or HAL?
I’m having issues with my 4 axis with when I release the clamps the table “bumps” abit and then goes into joint error. I’m also not fining any Info on the scale settings for it.
  • mariusl
  • mariusl's Avatar
05 Nov 2025 06:00 - 05 Nov 2025 06:01
Replied by mariusl on topic USB activity causes network error
Category: Plasmac
  • SvenRSA
  • SvenRSA
05 Nov 2025 05:15
Replied by SvenRSA on topic Maho 700C A-axis (rotating table)
Yes I don’t do that. Machine always off.
Yes I’ve done that also in pnconfig. Then you can just select XYZ /XYZA
The TRK6 4-U uses its own internal Tacho system/signal it just receives an external 0-9V signal to power the spindle. Now I don’t know if people tap into that 15V Tacho signal somehow. I know of Marc’s post there was someone that retro fitted an encoder on the spindle motor, assuming that’s for being able
To tap?
  • unknown
  • unknown
05 Nov 2025 04:48
Chat GPT is uesless for more things Linuxcnc related.
Googling "linuxcnc 7i92 g540" (the TF denotes a different fpga but it functions the same)gets me this (possibly the most in depth one, I dont think too much has changed in pncconf since 2023):
forum.linuxcnc.org/49-basic-configuratio...and-g540-combination
This one has some simple hal files to look at:
forum.linuxcnc.org/49-basic-configuratio...indle-encoder-issues
forum.linuxcnc.org/39-pncconf/29692-can-...re-mesa-7i92?start=0
Some of them are a little old, hopefully PCW will chime in with some up to date info.
I think the first link has some screenshots of PncConf.
  • ihavenofish
  • ihavenofish
05 Nov 2025 03:26
Replied by ihavenofish on topic Mini wannabe datron build
chomp
  • Lcvette
  • Lcvette's Avatar
05 Nov 2025 03:10 - 05 Nov 2025 03:11
Probe basic error exceeding axis negative value during calibration
Category: QtPyVCP
Are you using a centered home position with + and - in each axis?
Read the probe help yeah to understand all of they parameters.
  • Route 66 Scott
  • Route 66 Scott
05 Nov 2025 03:09
Hello all. I have been trying to get this setup running forever. I'm embarrassed so say how many hours I've spent googling, typing in terminal commands, letting Chatgpt hallucinate answers, and reading 'official' web pages. The official page for PnCConf shows me completely different screens than the ones I see, with the latest version installed.
Is ANYONE using this configuration? If not, what would you recommend that actually works? I went from Mach3 on an ancient XP machine with a DB25 serial port. I was told this would be the upgrade solution that just works. It's done anything but.
I have the proper firmware flashed to the 7i92TF for the G540. The computer is able to ping the Mesa card.
I cannot figure out how to configure PnCConf for this setup. I cannot find any directions that show me the screens I actually see.
Any help would be immensely appreciated. I am ready to give up and walk away from 2 years worth of design work done during the pandemic, because I cannot get some seemingly simple hardware to talk to each other.
Scott Jennings
Route 66 Guitars
  • ffffrf
  • ffffrf
05 Nov 2025 02:58
Category: QtPyVCP
Solved: MAX X/Y value of 110 was too high for my small machine.
  • ffffrf
  • ffffrf
05 Nov 2025 02:40
Category: QtPyVCP
I was able to do probe calibration by significantly increasing my axis min/max values for X and Y
However, this doesn't solve the issue as I cannot do any regular probing of parts anywhere on my travels without these artificially increased values. Does anyone have any ideas on what offsets might be causing this? My probing was working previously.
Displaying 7621 - 7635 out of 16726 results.
Time to create page: 0.324 seconds
